01-22-2017, 06:39 PM | #1 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
Ethanol in premium pump gas
The more I mod my car, the more I think about quality fuel. I've been using Exxon 93 since the first fill-up. It's close by and from my understanding, is a good product. It does contain 10% ethanol though. Is there a downside to this? Will my car benefit any more from gas with zero ethanol? If so, where can it be purchased ?
01-22-2017, 07:24 PM | #2 | |
Rep 1,133
You could run a tank by tank comparison to see if you get better mileage with the straight gas and factor in the cost, you can google and see if there is a straight gas dealer near you, it might not be worth it if its far. |
No Boost4027.00 |
01-22-2017, 08:21 PM | #3 | |
Rep 44
Ethanol isn't bad as such. In fact, you could mix some E85 (if you can find a station that sells it) with 93 octane and it will give you an effective higher octane and slightly less miles per gallon. and higher octane allows more boost Just be sure your fuel system can handle it. I think with modern BMWs we would be ok with about 3 gallons of E85 with every full tank of 93 (in our 13 gallon tank). There are some ethanol calculators out there which can help you see how much mixing of E85 you could do and what your new effective octane rating would be. |
No Boost4027.00 |
01-23-2017, 12:51 PM | #4 | |
Rep 3,957
01-23-2017, 02:05 PM | #5 |
Rep 430
If you have a Shell gas station in your area, you can sign up on their web site for a discount card.
http://www.shell.us/motorist/shell-f...-gasoline.html https://www.bmwcca.org/news/shell-v-...r-club-america |
01-23-2017, 03:03 PM | #6 | ||
Rep 796
That's a back to back dyno on 93. 93 made 320-330whp 30whp bump just from octane. |
01-23-2017, 04:00 PM | #7 |
Rep 3,957
Can't even get e85 by me anymore. They all became diesel pumps.
01-23-2017, 06:25 PM | #8 | |
4027
Rep 2,247
01-23-2017, 06:27 PM | #9 |
4027
Rep 2,247
Not even a couple of gallons?
01-23-2017, 09:25 PM | #10 | |
Rep 796
Stock boost e20-e30 is fine. So no more than 2-3.3 gallons, at least that's what I experienced I only started to run into HPFP crashes in 4th gear 6k and up but I was running 4psi over stock. It was fine for the stock boost map. Don't worry about it! E85 is great unless the car will be sitting for a long time. |
FSociety3812.50 |
01-24-2017, 06:28 PM | #11 |
Rep 864
MPG
Here in Alabama we can get 93 Octane Pure Gas -- which I run in all my small engines and have run in my N54 with some improvement in MGP but not sure if I could really notice any performance gain.
. The ethanol does attract water and is known to harm the Piezo injector crystals in the N54. On my N55 similar to your M2 N55 variant - the Bosh injectors are used due to the crappy fuel quality we have in America. . So, you could gain MPGs but the extra cost does not equal the MPGs gained. . . Accordingly, pure gas in a car that will be sitting for long periods of time should use pure gas as well as small engines like a leaf blower where the corrosive nature of ethanol just kills the carburetor. . However, I am a big proponent of high tier gas with quality detergent . Shell & Chevron. Cheers. |
01-28-2017, 01:16 PM | #12 |
Rep 817
02-05-2017, 06:55 PM | #13 | |
Rep 752
If I mixed 2 gallons of E85 with 11 gallons of 91 it gives me about 93.2 octane and E21.5 Is that safe to do and the car won't run lean? What if I wanted to run a map that was designed for 93 octane, would that work safely by using E85 as an "octane booster", since it's such a minimal amount would the car be able to compensate for it? Since E85 has lower energy than gas, it requires higher fueling, without being properly tuned, you'd run lean. But it's only 2 gallons so I'm not sure, along with the 10% of ethanol already in 91 gas in California. Thanks! |
02-05-2017, 07:08 PM | #14 | ||
Rep 796
The fueling problems only begin when your HPFP can't handle the e85 supply. It still targets your target DME AFR's until it crashes. E20-e30 on stock boost won't be a problem. To take full advantage of E85 you would actually want a leaner tune. |
FSociety3812.50 |
02-06-2017, 08:37 AM | #15 | |
Rep 752
That's crazy that the DME can compensate for this. I think I'd like to continue to use this 2 gallon blend just to up the octane to 93, but I'd also like to be tuned on this blend eventually. With a tune usually you have more timing and what not, would it still be safe to use 2 gallons of E85 with a 93 octane tune (91/E85 blend in tank)? No risk to the HPFP? Thanks! |
02-06-2017, 11:10 AM | #16 | ||
Rep 796
So theoretically it could work and it's very plausible, it will have to be just right. Map 1 is an additive map that targets 4psi. Map 2 is the same but targets 6psi over stock. That's around 20-21psi In overboost so we need that E30 blend for knock. I would see crashes in 4th gear around 7k on the e30 blend in map 1 and around 5.5-6k on map2. Pulled like a train though. I'm sure PTF could work out a custom e30 map for you. That's our only way short of port injection right now, DME tunes that alter fuel scalers |
FSociety3812.50 |
02-06-2017, 11:29 AM | #17 | |
Rep 752
02-12-2017, 03:39 AM | #18 |
IG @bmwF9xG80
3813
Rep 7,593
+1 on everything ashburyn54 mentioned
60-130mph 6.5s X4M #HCP
ashburyn54624.50 |
02-16-2017, 11:06 PM | #20 |
IG @bmwF9xG80
3813
Rep 7,593
E85 daily
Boostane on the go if no E stations
02-17-2017, 12:05 AM | #21 |
Rep 752
04-20-2017, 11:31 PM | #22 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
The difference in performance between 91 and 93 octane hardly seems worth the extra cost and effort involved. Cali gas sucks, sorry.
It's been mentioned above, but there's generally no real reason to start blending E85 with 91/93 unless you have a car that's been tuned/mapped to take advantage of it and run higher boost because of the effective higher octane.
