02-25-2023, 08:50 PM | #331 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
02-27-2023, 07:38 PM | #333 |
Rep 3,286
So, I'm really enjoying the grip/ride of MPS4S 255/35/19 F and 275/35/10 R. However, I have a very transient faint rub at low speeds only while reversing to the drivers side on full lock.
Stock suspension, no spacers. Anything to be concerned about? Otherwise the tires are fantastic.
03-07-2023, 11:27 PM | #334 |
Rep 3,286
Read this if you are considering MPS4S
Public Service Announcement
So as above, with front 255/35/19 MPS4S I was experiencing transient rubbing on 7/10 full lock while reversing to the passenger side left. Turns out the tire was barely rubbing on the "fins" on the front liner on the driver side. I could have filed the liner with a dremel but the space was so tight I had 245/35-19 MPS4S fitted. There was no danger of damage to the tires or the liner, but I didn't want to deal with the noise. Your results may vary (and certainly this may not apply to other brands of tires) but I wish I had heard of this possibility. Fortunately, Discount Tire replaced the tires at no cost.
CSBM52733.00 |
03-08-2023, 09:39 AM | #335 | |
Rep 6,955
Drives: 2018 M2 AW DCT
///MPhatic13937.50 Sebass6.00 |
03-09-2023, 12:18 AM | #337 | |
Rep 237
2021 BMW M2C / AA / Remus / KW
FMOS Racing120.00 |
03-11-2023, 01:38 AM | #338 |
Rep 3,286
Yup, easy fix for it as well. I say if you're not willing to deal with a bit of rub here and there, then stay stock.
Perhaps and lession learned. That said, I am very happy with the rear PS4S 275/35/19s. The grip is fantastic, and I prefer a more straight sidewall rather than the stretched appearance with stock 265/35/19s. Somewhat ironically, I have the same size staggered tires (albeit on 18 inch wheels) on both my E39 M5 and E86 Z4M coupe.
05-26-2023, 09:43 PM | #339 |
Rep 1,389
Anyone find that at cold 35 psi 255/275 is actually really progressive at low speed grip limits for Ps4S?
Ride is excellent but I am thinking of using 34psi day to day as I remember when I had them slightly under (32-33psi) grip was phenomenal. At stock 35psi levels they are fun and very slightly skaty under power (stg 2) a bit like mpss of yesteryear. |
07-07-2023, 10:46 PM | #340 | |
Rep 1,969
I'm tentatively planning on the 255/275 with the PS4S BMW * spec. OG with bone stock suspension/no spacers. (Can't believe I just re-read this whole thread for 2nd or 3rd time). |
07-08-2023, 08:26 AM | #341 |
Rep 6,955
The normal ones is what I got. The 275* was developed as a front wheel for G series Ms.
07-08-2023, 05:12 PM | #342 |
Rep 1,969
Yeah, looking at the specs the BMW star 255 is 3 lbs heavier than the same sized normal PS4S and the star 275 has a 0.7" narrower tread width than the normal 265s (9.6" vs 8.9").
The star spec 255 also has the Limited Edition Blackwall Premium Touch sidewall (at least from TireRack). Even Michelin states it will look "weird" mixing that sidewall with a normal one (no performance difference however). |
07-20-2023, 03:26 PM | #343 |
Flavor of the month
913
Rep 729
Drives: BMW F87 M2C
Yo, I just want a Internet stranger to tell me this is ok:
The car is lowered with the M-perf (KW) coil overs and that’s it. Planning on using the stock 763s with the 255/275 combo with Cup 2s (and stock sizing on the 788s). No spacers. Should that work? Thanks!!!
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
07-20-2023, 04:15 PM | #344 | |
Rep 6,955
///M TOWN20118.50 |
07-20-2023, 05:27 PM | #345 | |
Remove Before Flight
6869
Rep 1,615
I've had 255/275 MP4S's on a set of Apex wheels for street and 255/275 Cup2 Connect on a second set of Apex wheels for track. I LOVE the MP4S's. Plenty of performance for on the street, much better ride than the Cups, and they wear well. They are my go-to street tire. The Cup2's? Were fun on the track, but wore VERY quickly and tended to get greasy at the end of a session. And when they go? They GO-- as in "Why am I suddenly wearing street shoes on an ice skating rink?" They're also noisy as hell-- you will hear EVERY SINGLE rock you drive over as it hits the fender shrouds and underbody. The sidewalls are very stiff-- which makes them sort of unfun on the street. And rain? You're going to die. Bottom line: I'll keep getting the MP4S's for the street. I'm looking at other tires for the track (maybe Falken RT660's or or Nankang CR-S's, although I'd have to go down to stock 245/275 to make them fit the car). R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 Last edited by flybigjet; 08-10-2023 at 08:21 AM.. |
DanG10731.50 TheHunterHofman244.00 |
07-20-2023, 05:29 PM | #346 | |
6869
Rep 1,615
I have a M2C w/ the same M-P suspension, 1/2" wider Apex wheels and 255/275 MP4S's and Cup2's. No fitment issues or rubbing at all and no spacers required. R.
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 Last edited by flybigjet; 07-21-2023 at 08:11 AM.. |
07-20-2023, 11:44 PM | #347 |
Flavor of the month
913
Rep 729
Drives: BMW F87 M2C
Good stuff. Thanks. It’s on its second set of Cup 2s. But didn’t start pulling daily duty until just recently.
05-01-2024, 03:27 PM | #348 | |
Rep 4
Thinking I should send the 275 back and get the 265 which is listed as wider tread than the the 275 on tire rack spec sheet. Appears there is no logic to the size between the regular cup 2, the * spec, and the other variants. Do you have any photos of how stretched the 275/35R19 is on the 10.5 Apex? Tire Rack lists it at 8.9" tread width. I thought this was an error and TR tech thought so too. When the tires arrived they in fact are as narrow as the 255 and ~9in tread width. I was expecting closer to 9.8." |
05-01-2024, 11:34 PM | #349 | |
6869
Rep 1,615
I'll try to pull one down and take a few pics in the next day or two-- the Minister of War & Finance has to go somewhere to get her Miata out of the way first. I'm not sure if she's working downtown or from home tomorrow. R.
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
05-02-2024, 09:17 AM | #350 | |
6869
Rep 1,615
The two last pictures with calipers: The first one is "curb guard" to "curb guard"-- i.e. the absolute maximum width of the tire on a 10.5 rim-- 11.5" The second is "full contact patch"-- i.e. the obvious wear area from track use-- 9.5" Specs are: Michelin Pilot Sport Cup-2 Connect 275/35/19 tires mounted on an Apex EC-7 19x10.5, ET45 wheel. R.
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 Last edited by flybigjet; 05-02-2024 at 10:30 AM.. |
05-05-2024, 09:37 PM | #351 |
Rep 104
Such a good thread. Definitely more educated from reading this and other old Bimmerpost tire threads.
My current setup; Michelin PSS 245/265 on BBS FI-R's wheels, 19x9.5 ET22 / 19x10.5 ET35. Ohlins R&T coilovers. NO camber plates. Spirited street driving, no track, not a daily. Tuned. Most driving is done without traction control/MDM - all about the experience and engagement. Not much driving in rain... will use my brain and slow down, if I do. Considering three options for tires -
Leaning towards bullet one or three. Bullet 1 - will slightest increase in tread width but with a stickier compound, make worthwhile difference in grip? Bullet 3 - would I have a fit issue with A052's? Anyone having fit both 3/3R and A052's and willing to offer comparison commentary? Last edited by Telluride; Yesterday at 06:15 PM.. |
Yesterday, 06:41 PM | #352 | ||
Rep 104
What did you mean, "... go directly to the spacer thread..." to see if you'll experience rub? No luck with my "spacer" thread search. Thank you. |
///MPhatic13937.50 |
