M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > What Tire Size do you have on your OEM Wheels?
View Poll Results: What tire size do you have on your OEM Wheels?
245/35/19 Front - 265/35/19 Rear (OEM) 70 59.32%
255/35/19 Front - 275/35/19 Rear 31 26.27%
265/35/19 Front - 285/35/19 Rear 13 11.02%
Other - I'll Post it! 4 3.39%
Voters: 118. You may not vote on this poll
      04-24-2018, 09:15 PM   #23
M2OG
Drives: a car
who is the one running 265/35 and 285/35? Are you in stock suspension?
      04-30-2018, 10:40 PM   #24
Anthony1s
756
Drives: 2018 Mineral Grey M2
Why not 265/30 285/30? That's what I was gonna get.
      05-08-2018, 01:47 PM   #25
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
+1
That’s what I was thinking to get too. I’d like to know how it is on a slightly lowered car too.
      05-09-2018, 04:23 PM   #26
eeyang92
Drives: LBB M2 LCI 6MT
What to do if you have spacers... I think my fitment is spot on currently with 12mm front 10 mm rear on stock tire sizes lowered with MPS. If I go up to 255/275 I'd probably have to reduce the spacers to 7mm front 5mm rear? I'm not sure if it works linearly like that so correct me if I'm wrong!
In any case, the most common size spacers I found in that range are 6mm so that's probably what I'd have to switch to.
      05-09-2018, 07:03 PM   #27
Anthony1s
756
Originally Posted by 18EM2 View Post
+1
I think I realized why not. There aren't any good matched options available in 265/30 and 285/30 on Tire Rack.
275/30 and 295/30 seem okay, but not sure if they're too wide for our car and wheels. Otherwise 265/35 and 285/65 would be the next best option.
      05-14-2018, 09:59 AM   #28
M2joey
M2joey's Avatar
300
Drives: M2, 335is, X5 M50i
I run RE-71Rs - 255/35 and 285/35. Pretty good setup for the track, no issues. 265/35s are too tall of a tire for the front, they scrape very bad under heavy compression.
If my M2 were more of the street car I would run 255/35 and 275/35 for a little better water / hydroplane resistance.
      05-14-2018, 11:18 AM   #29
18EM2
Public Last Class
18EM2's Avatar
2018 BMW M2  [0.00]
isjoey does it understeer with that setup with the rear 20 over and the front just 10 over?
      05-26-2018, 10:47 PM   #30
Anthony1s
756
I just bought a set of 437m wheels from a M3 with stock Conti 5P's on them, 255/275, and have been running them on my M2 for two days now. The car spins significantly less with them, compared to the stock 245/265 tires. Due to the increase width, but also the tires are a bit stickier.
Before that, I was set on getting 265/285, but now that I'm looking at it, I think I'm gonna stick with 255/275 going forward because they are quite a bit cheaper.
Maybe after more mods and tune (only have eventuri intake right now) I'll switch to 265/285 if I feel they're needed.
KevM2723.50
      05-27-2018, 10:37 AM   #31
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
I'm very surprised not more people are running the 255/275 set up
      05-27-2018, 11:31 AM   #32
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
245/35 (original rubber) front, 295/30 PS4S rears. Going 255 up front next
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      05-27-2018, 08:06 PM   #33
kvndvs
Drives: 2021 HS 6sp
2021 BMW M2C  [0.00]
2019 BMW x3M40  [0.00]
I just installed this size in the PS4S last week. Great choice, should have been the as delivered tire size in my opinion. Also AutoX'ed for two days and great wear pattern on this size.
      05-27-2018, 10:12 PM   #34
18EM2
Public Last Class
18EM2's Avatar
2018 BMW M2  [0.00]
kvndvs do they still have some stretch at that size?
      06-09-2018, 06:27 PM   #35
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Do you mean 265/35 are too wide for the front? 255/35 should be same height as 265/35. Only difference should be width. Is your car all stock suspension with this 255/35 and 285/35 set-up? I am looking to do max tire width on total stock suspension.
      06-09-2018, 06:46 PM   #36
M2audioman
Incorrect. A 265/35 is taller than a 255/35. The "35" refers to the percentage of the overall width. The percentage of the overall width is the height of the sidewall. So the sidewall of the 265/35 is actually 3.5mm taller than the sidewall of the 255/35.
      06-11-2018, 02:21 PM   #37
M-Supra
M-Supra's Avatar
395
Drives: 2018 M2, 2JZ-M5
275/30-19 and 295/30-19
http://f87.bimmerpost.com/forums/sho....php?t=1465661
