M2 Technical Topics > Suspension | Brakes | Chassis > TCK coilovers/camber plate
      05-07-2022, 03:27 PM   #23
riko///m2
riko///m2's Avatar
Drives: LSB E46 M3, AW F87 M2, Model 3
2004 BMW M3  [9.90]
2017 BMW m2   [9.75]
Originally Posted by wilson kop View Post
Originally Posted by riko///m2 View Post
It sounds like there is some play between the front struts and camber plates. Tighten the top bolts of the Koni struts. Real tight(proper torque). Also, apply few drops of red locktite.
I added helper springs in my set up for tighter fit.
Can you expound on the helper springs you added? From where? What impact do these have beyond tightening up the fit?
We're you getting noise like this prior?
Yes, there were some noise during my test drive after the install but i fixed it after I tighten the top nut, and after applying loctite.
There's no impact at all. The helpers added 1/4" height fully compressed.
I installed the helper springs to preload and to avoid the springs from unseating from the struts collar when the tires go off the ground (when jacking or when approaching driveways at an angle).
Here are the links. Get (2) each.
https://www.summitracing.com/search/...MaAgcfEALw_wcB
https://www.summitracing.com/parts/e...gaAjJTEALw_wcB
I have a white f87 m2 and a blue e46 m3
      05-07-2022, 04:16 PM   #24
Dozer324
I’m starting to think it’s sway bar end link related. Seems to be most noticeable over bumpy slow uneven roads.
I checked the strut top bolt and the shock tower bolts. All seemed to be torqued properly.
      05-07-2022, 04:42 PM   #25
Dozer324
Is there anything special to tightening the top bolt? The one side when I was checking seems to turn and then turn back on itself. Would the entire strut be twisting?
      05-07-2022, 04:57 PM   #26
riko///m2
riko///m2's Avatar
2004 BMW M3  [9.90]
2017 BMW m2   [9.75]
The strut shaft should not turn.
Use a crescent wrench and a 7/16 " socket. Turn the crescent wrench to tighten.
      05-07-2022, 05:57 PM   #27
Dozer324
the strut shaft should not turn.
      05-08-2022, 11:43 AM   #28
Dozer324
Those were tight, I’ll have to check the sway bar bolts next.
      05-08-2022, 10:18 PM   #29
HP Autosport
Drives: F80 M3
The helper simply adds tension to the main spring when the suspension is at full droop.
Still need to check for proper torque on all your strut and end link hardware.
      05-09-2022, 10:53 AM   #30
Dozer324
Found the source of the noise, a stripped lock nut on the sway bar link. Replaced with a nut and blue lock tire for now. Is a self locking nut required?
      05-09-2022, 02:43 PM   #31
Dozer324
https://flic.kr/p/2njyDWR
      05-09-2022, 03:22 PM   #32
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
If this is indeed the problem Rico has a good tip.
Adding Locktite is mandatory on the top nuts, they will back off over the miles.
I had this happen on my 1st kit back in 1999. All of my TCK setups have, or hadlocktite on the nuts.
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      05-12-2022, 05:30 AM   #33
hlm2c
Drives: M2C
Do you have adjustable sway bar end links? Once they were installed the noises started. Nothing seems to be loose.
I don't have adjustable sway bar end links. Mine are OEM
      05-12-2022, 11:12 AM   #34
HP Autosport
Drives: F80 M3
Not all adjustable anti roll bar links are noisy. The rod end versions tend to get noisy over time. OE style ends are just like OE, never noisy unless defective.
      05-12-2022, 02:39 PM   #35
Dozer324
Luckily mine are not noisy either, just a mechanic rushing through a simple job and stripping a nut on the way.
      05-13-2022, 09:04 AM   #36
///393
///393's Avatar
829
Drives: X6
Thanks for sharing your experience. I had to punt install while I wait for the correct camber plates for my OG
      05-31-2022, 06:04 PM   #37
///393
///393's Avatar
829
Drives: X6
Just brought my 2017 home with TCK kit installed and Bimmerworld front monoballs.
I’m also experiencing some noise but not the same as the OP. Mine are at crawling speeds in my driveway as it makes a turn and entering and exiting the driveway which involves turning left.
      08-25-2022, 10:57 PM   #38
PHX102
Drives: BMW M2 Comp
Originally Posted by ///MPhatic View Post
From my research that's more of a specific type of suspension thing, as well as being caused by camber plates. I ended up going with the MPS and have no additional noise, except some clicking upon hard cornering (even though the pinch bolts were replaced and torqued properly).
Are you running stock camber?
      08-26-2022, 06:56 AM   #39
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
My car has some additional camber by virtue of lowering.
LF -1.8° • RF -1.6°
LR -2.0° • RR - 1.8°
      08-26-2022, 04:58 PM   #40
SEAT TIME RULES
1103
2020 BMW M2C  [5.00]
This is most likely the issue your having.
Locktite and proper torque of the top nuts will eliminate the strut moving up and down. The noise your describing is almost 100% caused by the C/O' moving up and down.
      08-29-2022, 04:03 PM   #41
HP Autosport
Drives: F80 M3
Red should be avoided. Green or blue are the best for this type of application.
It is okay to use an impact as long as you know when to stop.
There should be no movement of the shaft once it is fully seated in the camber plates otherwise it will be noisy for sure.
      09-25-2022, 10:41 AM   #42
SCMTX
Drives: F87 M2C, exesE92 M3, F82, F30
Just installed the TCK DA kit on my M2C. I’ve already pulled the rear shocks out once to retighten the shock top bolt, I had used blue locktite as well. Guess I need to go find a nylock nut, the lock washers aren’t enough.
The front WAS quiet, but something up front has worked it’s way lose.
I’m pretty frustrated, BUT the ride is soooo much better than stock! It’s not even close, very supple. However, I’m going to have to get the 400/700 springs, I think the 300/600 isn’t firm enough. I’m not slammed, but I have got tire rub with larger dips in the road. I’m running in between street and track settings for rebound and compression.
      10-02-2022, 11:53 AM   #43
Rumbloki
Rumbloki's Avatar
Drives: Faster than most
Where can I find the proper torque values?
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
      10-04-2022, 02:06 PM   #44
Toroinu
Drives: BMW M2c, BMW 528i, Audi RS5
Were you able to get them tight and secured? Also did the camber plates make any noise? I’ve heard some camber plates clunk.
I’m planning to go for the SA 300/600 setup for comfort over stock with some track time once in a blue moon. What wheel/tires specs are you running for you to be rubbing?
