BMW M2 Forum > BMW M2 Discussions > Picked up M2 LCI. Interior and Improved Gauges in Action
      07-21-2017, 03:08 AM   #67
M2018
Originally Posted by hoyasaxa View Post
I would be really curious to see OP's bimmer.work VIN report and images.
This is what mine shows:
Would be interesting to see who is getting the piano black interior trim, executive package? non Eu spec? or nobody?
      07-21-2017, 03:17 AM   #68
johanva
johanva's Avatar
Drives: BMW M2 MY2018
Originally Posted by OzWoz View Post
Thanks Johanva, appreciate the time you'e taking to show us the changes!. I would imagine if the throttle blip can be disabled, it would be via iDrive and should be in the manual somewhere. Given that the throttle is drive-by-wire, it should be the easiest thing for them to code.
My suggestion...link it to the redundant "M Button" so when you press it, you get a sport+ mode that stops the blip!.
I'm just an enthousiast like all the rest and this is my chance to give something back to the community.
Appreciate 5
ZPrime611.50
OzWoz75.00
Aust350z243.00
Spa2k1194.00
      07-21-2017, 06:47 AM   #69
Artemis
Artemis's Avatar
29419
Drives: BMW M2 Competition
johanva thanks for the info and your videos.
Tip: add your videos to the first post (video 1, video 2, video 3 and video 4).
How is the readability of the M2 LCI instrument cluster with the headlights switched off ? One of your videos seems to show that the backlight of the instrument cluster is permanently switched on, as soon as you activate the car. Correct ? Does the instrument cluster light up stronger in darker lighting conditions (for example when going through a tunnel) ?
Gear shifter of the pre-LCI 6MT M2 has no light. On the gearshifter of your M2 LCI a video shows the shift pattern: is your gearshifter lit or is that just the effect of the white 'waterfall ambient lighting' ?
Some quick tips (pre-LCI M2):
  • Changing the 'waterfall ambient lighting' color (ambient light radiating down from the roof near the rear view mirror):
    iDrive: "Settings" | "Lights" | "Ambient" | choose "Classic" (amber/orange) or "Sport" (white)
  • Changing brightness:
    iDrive: "Settings" | "Control display" | "Brightness" | adjust the controller
  • Activate/deactivate the 'Shift Point Indicator' (ideal timing for each gear change for lowest fuel consumption):
    iDrive: "Settings" | "Instrument Cluster" | (un)tick "Shift point indicator"
  • Avoiding the 'SPORT' message from 'disturbing' your SATNAV screen each time you push the 'SPORT' button:
    iDrive: "Settings" | "Control display" | untick "Driving mode info"
  • Avoiding automatic start/stop:
    push the button above the start/stop button (button light on = deactivated)
  • Achieving the lowest possible fuel consumption:
    Sell the car
///M is art Artemis
      07-21-2017, 07:04 AM   #70
Artemis
Artemis's Avatar
29419
Originally Posted by johanva View Post
I don't have the adaptive LED's (too expensive for what you get imho).
Shape of your headlights: the pre-LCI coronas or the hexagonal coronas ?
In fact, it was rumored that only the M2 LCI with adaptive LED's get the hexagonal coronas, instead of all M2 LCI.
///M is art Artemis
      07-21-2017, 07:43 AM   #71
Aust350z
Aust350z's Avatar
243
Drives: F87 M2
Attachment 1660528
    Sell the car
I don't have the driving mode option button? Annoying as. Thought this was an easy fix!
      07-21-2017, 07:55 AM   #72
Artemis
Artemis's Avatar
29419
M2 GTS.
///M is art Artemis
JTO245276.00
MadViper141.50
      07-21-2017, 08:23 AM   #73
johanva
johanva's Avatar
Done
It's always on and I didn't notice any difference in the brightness of the cluster when going through a tunnel.
It's not lit but indeed just the effect of the waterfall ambient lighting.
Already found those
Can't find that option. I think my car has a new version of iDrive and therefor the menu's are different. I looked like crazy in the menu's but can't find anything to turn it off :-(
Too bad you have to press that button every time you start the car.
    Sell the car
That is not going to happen very fast :-)
If you like, you can PM me to meet somewhere so you can see all the differences yourself.
      07-21-2017, 08:27 AM   #74
johanva
johanva's Avatar
The pre-LCI coronas (which I like more and another reason (for me) not to choose the adaptive LED's).
Artemis29419.00
StephGOD218.50
AndrewC198910931.00
      07-21-2017, 08:39 AM   #75
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
The North American cars keep it as the last setting, I've only pressed mine once, the day I picked up the car. You can program yours to have the same behavior. I highly recommend Bimmercode for coding, easy to use and cost effective.
AndrewC198910931.00
      07-21-2017, 08:43 AM   #76
SW19
SW19's Avatar
2458
Drives: 2016 Alpine White M2
Thanks for confirming that the non adaptive LED headlights still have the full corona rings.Do you have any exterior pics of the headlights and tail lights of your car?
stefan2354.00
      07-21-2017, 09:38 AM   #77
DoZZa
DoZZa's Avatar
82
Drives: MY17 | M2 | DCT
It can be coded to be off by default every time you start the car.
You need software and a OBD adapter to do it.
Bimmercode and a V-Link OBD adapter is whats needed to do this.
You can also code various other items with Bimmercode and the V-Link.
      07-21-2017, 09:44 AM   #78
Alby_416
Alby_416's Avatar
Drives: BMW M2 Coupé (BSM)
[*]Activate/deactivate the 'Shift Point Indicator' (ideal timing for each gear change for lowest fuel consumption):
In the "old" E82/E92 you can do that by pressing and holding the BC button for at least 3 seconds... maybe it'll work on this newer model also
      07-21-2017, 10:16 AM   #79
Nine Lives
Nine Lives's Avatar
602
Drives: Austin Maxi
Originally Posted by reppucci View Post
Also they got the M "red" needle correct this time even for the fuel gauge!
Artemis' pre LCI F87 M2 dash with white fuel gauge needle.
M2 F87 LCI with proper M Red fuel gauge needle!
Non-M F22 LCI dash needles are white.
It was certainly a bugbear of mine at the time with the gauges but great to see it's been sorted...
But now comparing side by side I think I like the m240 cluster better...
      07-21-2017, 11:37 AM   #80
hoyasaxa
Drives: GTI | 982 4.0
Chrome trim :-/
If you run your VIN at http://bimmer.work does it come back shadowline?
Well, that's rather disappointing then. Thanks for checking.
2014 228i (lease return) | 2018 ///M2 - ED Thread (sold) | 2023 Cayman GTS 4.0 (ordered)
      07-21-2017, 11:50 AM   #81
SW19
SW19's Avatar
2458
Even the picture that BMW Canada shows in the MY18 M2 ordering guide has the piano black trim but in the description it says new interior trim with chrome application.
      07-21-2017, 12:49 PM   #82
thaalrasha
Drives: G81
I love that is says : Adapative LED is highly recommended for "the aggressive styling"... not that it well help you see better at night
I had LED headlight on my F30 LCI and I was disappointed by the unnatural color and strong shadow producing source from the LEDs... Much prefer Xenons, but too bad they are not efficient and expensive...
JustChris17489.00
SW192457.50
      07-21-2017, 01:06 PM   #83
Artemis
Artemis's Avatar
29419
Regardless of the design shape, Adaptive Headlights and High Beam Assist will definitely help you to see better at night.
2012 explanation:
Demonstrations:
///M is art Artemis
      07-21-2017, 01:37 PM   #84
hoyasaxa
Have you removed the US coding? (i.e., have you removed the anti-dazzle "decoding")
      07-21-2017, 02:19 PM   #85
Artemis
Artemis's Avatar
29419
That ain't me in any of those videos. But I think I understand what you mean.
BMW promotes High Beam Assist as being dazzle-free, though got already tapped on its fingers for its claim that "oncoming traffic is never dazzled and you can keep your hands on the wheel and your eyes on the road": https://www.motoringresearch.com/car...ist-technology
///M is art Artemis
      07-21-2017, 02:25 PM   #86
hoyasaxa
No, I just didn't notice your location because I was on mobile. Sorry.
In the USA, this feature is disabled.
5AP Decoding For No-dazzle High-beam As Dekodierung Blendfreier Fernlichtas
8S4 Decoding Variable Light Distributio Decodierung Variable Lichtverteilun
It has to be re-enabled by coding.
      07-21-2017, 02:46 PM   #87
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
[*]Avoiding automatic start/stop:
Is there an option to keep start/stop always off?
      07-21-2017, 02:47 PM   #88
Franzino
Franzino's Avatar
Belgium
860
Looks much better with the black trim.Hopefully the bimmer.work vin info is correct and that is what your M2 will have.
The black trim is so much nicer then the chrome around the carbon insert. I don't like that chrome piece.
