M2 Technical Topics > Suspension | Brakes | Chassis > Center lift point on rear?
      02-04-2019, 02:52 AM   #45
specka
Drives: M2 LCI BSM
2017 BMW M2 LCI  [0.00]
Originally Posted by David.m View Post
Originally Posted by specka View Post
That looks like a good solution, what's the product?
QuickJack but down here it will set you back $2500 Had been thinking about one but yesterday watching the Bathurst 12HR saw the Supercheap Auto sale & I've picked up a ToolPro low profile 3ton trolley jack & 4 stands for $260 (all half price), a saving worth the extra work.
Yeah they're super expensive and seem to be backordered as well.
It will be great if you can report back on how well the Toolpro works with our car, in terms of accessing front and rear centre lift points?
I really need a solution to take to track to change between road and track wheels.
Thanks
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
      02-04-2019, 07:33 PM   #46
David.m
Drives: M2 LCI 6MT BSM
Thanks
Just tried the Toolpro low profile, access to rear cross-member is easy, the jack has a built-in rubber pad which seemed to provide a secure & stable grip on the cross-member (contact point was roughly midway between middle & edge of the rubber pad).
Lifting the front (stock suspension), the back part of the jack catches on the underside of the bumper, I drove the car onto 30mm timber pieces which gave 10mm clearance at the lowest point where the bumper joins the undertray. Reaching the centre jack point was then easy and lifting quick with the dual-pump jack.
Jack weighs 45kg (if you're loading it into the boot).
If you get the jack, the half price deal is for the jack & bottle of Gulf Weston hydraulic oil (all up $185)
      02-04-2019, 07:39 PM   #47
specka
Drives: M2 LCI BSM
Thanks
Thanks mate, this is exactly what I needed to know.
I think this is going to be the solution for me.
I wonder how I'll go transporting 4 wheels, jack and stands to the track in my car
      02-04-2019, 09:58 PM   #48
David.m
If you’re just changing wheels at the track I think you could leave the stands at home
specka71.00
      02-05-2019, 05:41 AM   #49
specka
Drives: M2 LCI BSM
you make a good point
      02-09-2019, 07:04 AM   #50
Karlosm2c
Karlosm2c's Avatar
291
Drives: M2 Competition
Originally Posted by BAN_M2C View Post
If you are talking about this one, yes.
After Pyrat 2 put this up and people cleared on how to lift the back I have used those points to lift with jack and then just place jack stands on the lift points in the corners.
Sorry if someone has already answered this, but what length jack is needed to reach the centre front lift point?
Cheers,
Karl
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
      02-09-2019, 01:49 PM   #51
M Fifty
844
Drives: M2 & 330CI
Karl, it's not so much the length, as what you do with it. Just saying.
More seriously, the total height is going to be more important. And not just because being the Lock Forward will make you more popular than being the Scrum Half - you have to be able to get the jack under the car.
So, if you own a low jack with a big lift you're always going to get the job done...
      02-09-2019, 04:23 PM   #52
BAN_M2C
BAN_M2C's Avatar
4185
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
Cheers,
Karl
For reference this is the one I use on my car:
https://m.harborfreight.com/3-ton-lo...ump-64264.html
Both the M2 and the M2C were lowered. Reaching the front center point was a painful process because on top of being lowered I had a carbon front lip.
Pretty sure if the car was stock height and had no lip you could reach the front center mid point no issues with a jack like mine.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      02-09-2019, 04:38 PM   #53
Karlosm2c
Karlosm2c's Avatar
291
Cheers,
Karl
Thanks Ban, I'll check out the link to see if that jack is available in the UK
BAN_M2C4185.00
      02-09-2019, 04:40 PM   #54
BAN_M2C
BAN_M2C's Avatar
4185
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
You are welcome! Might not be available but check something similar specs, as long as it's a low profile jack with similar length it should work!
Follow me on IG
Karlosm2c290.50
      02-10-2019, 12:59 AM   #55
Karlosm2c
Karlosm2c's Avatar
291
Looking at the dimensions of that jack it gives me good information to go on in the UK market. I won't be lowering my car with coilovers any time soon and I don't think I'll add a splitter so hopefully I'll have no issues with whatever I go with.
One other question I wanted to ask: as the car is well under 2 tonnes are there any benefits of having a jack that can lift 3 tonnes over one that can only lift 2? I've found some highly rated 2 tonne jacks similar to the one you have listed.
BAN_M2C4185.00
      02-10-2019, 04:12 AM   #56
M Fifty
844
Drives: M2 & 330CI
A 1.5 tonne jack will safely lift the car as you are never going to be trying to lift the full weight even using the centre lift points discussed here. Even then, that's the SWL, so it will lift a lot more but at the risk of damaging the jack.
It might be easier to lift with a higher rated jack, but that will depend on the design.
Hence, a 2 tonne jack will be fine.
HTH
      02-10-2019, 05:07 AM   #57
Karlosm2c
Karlosm2c's Avatar
291
HTH
Thanks Fifty.
I have found this one, which I think I'll buy:
LiftMaster 2.5 Ton Aluminium and Steel Low Profile High Lift Floor Jack (Gold) https://www.amazon.co.uk/dp/B07G8NB4..._YoayCbXY3G886
It's the lightest low profile jack I could find at 29kg/64lb, with an entry point of 75mm. Reviews on this outside Amazon seem good it'll lift 2.5 ton.
BAN_M2C4185.00
      02-10-2019, 04:45 PM   #58
atlas
383
That won't reach the centre middle point, fyi.
      02-11-2019, 10:29 AM   #59
Karlosm2c
Karlosm2c's Avatar
291
Hi, why not?
I am looking at a different jack now:
https://www.amazon.co.uk/gp/product/...KL5A1OLE&psc=1
      02-11-2019, 02:01 PM   #60
greasypeanut
Drives: F87
I have the same jack, and mine is stock height with no lip. Still need to drive them up some wood to get it underneath to reach.
BAN_M2C4185.00
      01-16-2021, 04:49 PM   #61
pal
pal's Avatar
433
Drives: Z4 M Coupe
I've been using the rear subframe bar behind the diff to lift the back of the car without issues. However, it does need focus and care to ensure the jack does not slip or slide backwards during lifting. I've used a couple of layers of duct tape on the jack (without the pad so there is the metal lip exposed) to minimize chances of slip. Works well as Pyrat2 shows.
I wanted to share another method that is not as hair raising, though it's a touch more expensive as it requires buying a cross-beam adapter. Below are some pics of me using it for reference.
[IMG]https://media.fotki.com/2v2HrVMC5xu6LVA.jpg[/IMG]
[IMG]https://media.fotki.com/2v2HrVMLNxu6LVA.jpg[/IMG]
[IMG]https://media.fotki.com/2v2HrVMgrxu6LVA.jpg[/IMG]
bentom2335.50
      01-17-2021, 03:46 AM   #62
widetyres
279
Drives: M3 E92 DCT, 2012
That looks pretty neat! Did you use it in some way to get the fronts onto the stands? Or, did you swap the cross-beam on after they were raised?
      01-17-2021, 09:56 AM   #63
pal
pal's Avatar
433
Drives: Z4 M Coupe
I raised the front using the center jacking point and the jack in it's usual state. Once the front was on stands, then I swapped the cross beam adapter over onto the jack for the rear. I like this as it works on my other cars as well.
widetyres279.00
bentom2335.50
      03-04-2024, 10:22 AM   #64
besfa001
besfa001's Avatar
Drives: Bmw m3
Can you attach or pm the link for the stands , jack , and cross beam adapter? Thanks!
      03-17-2024, 09:29 AM   #65
Maynard
Drives: 228iX & M2C
I think this area in blue is actually the best rear jack point (either side). Center of the bar would work, if you have a jackpad saddle that will fit (most won't, and sliding off is no bueno). Using the lower control arms like in those spreader-photos is quite iffy - I know that older M cars are known to bend the control arms if you try this, or try using them to pull the car up on a flatbed.
Andrew2180.00
      03-17-2024, 05:39 PM   #66
ggggbmw
Drives: 2017 M2 Manual
Maynard, I totally agree that the lower control arm stubs on the subframe on either side of the diff are the way to go. (The blue circle in your picture.) The left is probably the better choice as there is more clearance. There is a bit of twist jacking off center, but it's less than an inch at the rear jack points when you place jackstands.
There just isn't enough clearance between the middle of the subframe at the yellow arrow and the back of the diff to safely lift there. Especially if you are using any sort of rubber jack pad to protect the finish.
I found this video which I think does an excellent job of how to jack the car up. It's an M3, but it has the same subframes. This is the same process that I've been using.
Maynard3848.00
