M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 11" Wheel with 295 or 305 tires in the rear?
      02-13-2016, 09:28 AM   #1
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
What do you guys think? The 1M could easily fit this setup in the rear. The stock setup on the M2 doesn't look like it has much room to grow. Do you think we can widen the rear 1/2" each way?
      02-13-2016, 09:40 AM   #2
Twix
Twix's Avatar
657
Drives: 2011 e91
That's what I plan on running. Problem will be with the front. I want to stick with the same amount of over square, but I think a 10" with a 275 tire on the front won't fit right for everyday street use. Track sure, but my wheel guy is telling me to go with a stock size in the front to keep from rubbing on the street. I'm not sure I like the idea of a 245/35 19 in the front with a 295/30 19 rear, I think that will cause massive amounts of darting and beelining on the roads.
Edit: If worse comes to worse, I've seen a 295 on a 10" and it's not that bad. /flame-suit
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      02-13-2016, 10:10 AM   #3
OrangeCrush
1236
You could probably move up to a 255 on stock size in the front. And no flaming from me, a lot of people run 295 on the stock 1M and E92 M3 rear. I actually think an 11 with 295 would fit better than stock with 295 because the 11 would stretch the tire a little bit. Maybe I'm wrong but it sounds good to me.
The real problem is that BMW stepped up their game on wheels and the stock M2 wheels are pretty light. I don't want to put on a wheel that's heavier so I'm going to be spending a lot of money on wheels if I change them...
      02-13-2016, 10:14 AM   #4
Pol
Pol's Avatar
Belgium
1119
Drives: M2 CS BMS DCT August 2020
Alternative tire sizes with +3%/-2% total wheel diameter:
(WARNING: any wider tires could not fit the fenders and arches, always check it earlier (!) and in most cases you will need new rims, of course)
http://www.automobile-catalog.com/ti...coupe_dkg.html
According to that data, it should even be possible to mount a 255/40 R19 = percentage diameter difference to original = 2,8%
      02-13-2016, 10:33 AM   #5
Pol
Pol's Avatar
Belgium
1119
3th column = preference
2nd column = minimum
4th column = maximum
      02-13-2016, 12:39 PM   #6
Twix
Twix's Avatar
657
Drives: 2011 e91
For my street set I don't care about weight so much, but for a track set if I do decide to go that route, I'll spend the big bucks and get something ultra light, maybe even an 18"
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      02-13-2016, 12:50 PM   #7
OrangeCrush
1236
For me it would be a lot easier if PSS came in 285/30
      02-13-2016, 04:20 PM   #8
Twix
Twix's Avatar
657
Drives: 2011 e91
According to their website
http://www.michelin.ca/tire-selector...uickLinks=true
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      02-13-2016, 06:43 PM   #9
OrangeCrush
1236
Wait....what? When did this happen? Hello yeah!
      02-14-2016, 09:55 AM   #10
OrangeCrush
1236
Ewww...yeah. these are run flats.
      02-14-2016, 10:01 AM   #11
Twix
Twix's Avatar
657
Drives: 2011 e91
Trofeo R comes in a 285 lol
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      06-15-2016, 03:23 PM   #12
eimsteim
eimsteim's Avatar
12
Drives: F87 M2
Can confirm fitment of RE71s
Can confirm fitment of a 255/35/R19 and 285/35/R19 Bridgestone RE71s on stock wheels with plenty of clearance. No rubbing at lock while autocrossing. I would like to go a little wider for street use but still deciding on wheels.
      06-16-2016, 03:05 PM   #13
automotiveaperture
automotiveaperture's Avatar
93
Drives: Frozen Black M3
Pics or it didn't happen
Just kidding, but would really love to see any photos of this setup
      06-16-2016, 04:21 PM   #14
eimsteim
eimsteim's Avatar
12
Drives: F87 M2
I can do that
With pleasure.
      06-16-2016, 04:59 PM   #15
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
How about 265 in front? My observation is that your more likely to rub on the inner fender in front with wheels turned than at the top of the fender.
If you turn the wheels does it look like you'll rub with 265s up front?
      06-16-2016, 07:49 PM   #16
automotiveaperture
93
With pleasure.
Thanks man! Are pics not showing up for anyone else? Tried app and website
      06-16-2016, 08:05 PM   #17
eimsteim
eimsteim's Avatar
12
Drives: F87 M2
My Fault
I'm bad at forums... moved the images to imgur so all is better.
      06-16-2016, 08:26 PM   #18
automotiveaperture
93
Awesome, thanks man, car and fitment, spot on
      06-16-2016, 10:18 PM   #19
Fullofdays
Drives: m
i'm waiting on a set of track wheels to be built now. planning on running forgeline ga1r 18x10 square with re 71's for track duty. unsure if offset up front will clear fender/suspension (MCS 2 way non remotes with GC camber plates) so i plan on doing some test fitments with a test wheel first. more to come in the next 2 weeks.
light rolling of the inner fender up front might be required. not too excited about this to be honest but wont know till i do test fitment...
F87 LBB ///M2 DCT
Forgeline | AP Racing | Ferodo | Ground Control | Hyperco | Essex
      06-16-2016, 10:44 PM   #20
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Originally Posted by Fullofdays
[IMG]http://www.vacmotorsports.com/blog/w...2/08/ga1r7.jpg[/IMG]
i'm waiting on a set of track wheels to be built now. planning on running forgeline ga1r 18x8 square with re 71's for track duty. unsure if offset up front will clear fender/suspension (MCS 2 way non remotes with GC camber plates) so i plan on doing some test fitments with a test wheel first. more to come in the next 2 weeks.
The ga1r is such a nice wheel! Good choice. Why so skinny though?
I would just ask them. My bet is they point you towards a 9.5" square setup
      06-17-2016, 07:14 AM   #21
Fullofdays
Drives: m
Typo on my phone - edited! Meant to type 18x10 square
      06-18-2016, 06:59 AM   #22
spiderman1982
Drives: BMW M550x Drive
New sizes for the 2017
Is it true that the 2017 model will have wider tires? 255s and 275s
