06-18-2019, 08:33 PM | #1 |
Rep 309
Drives: 2018 M2 LBB - 6MT
Novus Plastic Polish on LCI Cluster?
First time creating a thread on bimmerpost, sorry in advance if it's in the wrong place .
I searched throughout the various subforums (M3/M4, 3 series, etc) regarding micro scratches on the instrument cluster, and many have reported success with Novus plastic polish, particularly #1 and even #2 in some cases. However, I feel like the LCI cluster in the M2 and M2C use a different material compared to your standard cluster with the plastic "shield" looking cover which I suspect is what everyone who reported success was dealing with. The LCI cluster is not exactly glossy and smooth to the touch; it's rather matte and porous IIRC. Has anyone used Novus plastic polish (or something else with success for that matter) on their M2 LCI cluster? I purchased the Novus already and will definitely use it on the gloss black trim around the HVAC. But I have my doubts with the LCI cluster. Thanks! For reference, here's one of the M2 threads where people have talked a bit about it, but I'm not sure if anyone there has actually tried it for themselves: https://f87.bimmerpost.com/forums/sh....php?t=1483239 3 series thread but AFAICT, they have that glossy smooth cover overtop of gauges that most clusters have: https://f30.bimmerpost.com/forums/sh....php?t=1074263 M5: https://f10.m5post.com/forums/showth...ighlight=novus |
06-18-2019, 10:55 PM | #2 |
Rep 3,256
The problem is the M2 screen is kind of textured, as you mentioned. I personally wouldn’t use any sort of polish. I suspect it’ll either get glossy at minimum or at worse wouldn’t be uniform. I’m personally not brave enough to try it on my car. Godspeed to any who try.
gphung193.50 BallHog5873176.50 |
06-19-2019, 12:49 PM | #3 |
Rep 212
That polish is waaaay too aggressive for either the LCI display or the piano black HVAC surround, especially if you try to use it by hand. You're going to shred your gauges and get nothing but micro scratches on your HVAC surround if you use that stuff. Better to remove the surround and machine polish it (with an orbital) and some very fine compound like Menzerna 4000. Just leave the gauges alone and if they get dirty blow them off with compressed air or, at most, lightly wipe them with the fluffiest microfiber towel you can find.
There's nothing you can successfully polish the gauges with. They have a matte texture/coating on them - hand polishing will scratch them all to hell and machine polishing will make them shiny and illegible in daylight. Either way you'll get to buy a new gauge cluster for $1K. I've had luck polishing the piano black surround in my wife's X3 with a 1" pad on a Flex rotary polisher but honestly it's quite a PITA if you don't remove the trim first. If you leave it installed, don't mask properly, and are otherwise not careful the compound slings everywhere and it's hard to clean up. Heed my words - don't polish glossy plastic by hand! You'll be sorry you tried! Either just buy a new HVAC trim piece, remove and machine polish it, or leave it alone. |
gphung193.50 |
06-19-2019, 01:32 PM | #4 |
Rep 2,956
At all costs you try to avoid anything coming into contact with the LCI cluster. It doesn't matter if it's the most gentle microfiber cloth or what lubricant you use. It will scratch. If your display has scratches (many of us got them right on delivery) just live with them as trying to fix them will make it worse. Use a compressed duster if you want to clear dust build up but nothing should ever come in contact with the cluster film as it's quite possibly the most delicate surface known to man.
06-19-2019, 09:54 PM | #5 | ||
Rep 309
06-20-2019, 09:33 AM | #7 |
Rep 308
Omg I'm so glad I read this thread.
I'm not going to try to polish now. But, at the same time, feel my pain — I took my car in to have it washed and TOLD the guy not to touch the LCD display ... and he did it anyway, and left it with horrible swirls. FML. |
06-20-2019, 09:53 PM | #8 | |
Rep 212
I’ve very gently used these MF towels on my LCI cluster to remove water spots. I only have a few very minor scratches on my cluster that can only be seen under direct LED lighting so I’ve been lucky compared to others. |
gphung193.50 |
06-20-2019, 11:14 PM | #10 | |
Rep 309
Thanks for your help! |
06-21-2019, 11:40 AM | #12 | |
Rep 212
You don't necessarily need a Menzerna polish if the Novus doesn't work out; those just happen to be the automotive polishes I have lying around so that's what I use. A gentle swirl remover or something a little finer plus your red (or a white) pad should work great also. |
08-27-2020, 08:01 PM | #14 |
Rep 73
Used 1 to clean off but really only 2 removes the scratches.
Under most lighting the scratches are gone but in heavy glare situations you will notice that the matte finish is gone from where the buffing is done. However, I rather have that then the scratches in your face most of the time. |
4
02-13-2022, 02:57 PM | #15 |
Rep 613
Drives: F87 M2 CS
Bumping this thread to see if anyone else has had success with Novus #1 & #2 on the M2C LCI cluster.
acl26's results look great. However, I'm curious if anyone can chime in with how bad the sun glare truly is with the matte finish removed. As I posted in the other LCI scratch thread, my Speedo and Tac are so caked with micro scratches from the dealer that I can barely see through it when there’s sun glare anyway. Making me think it's worth the risk. However, if removing the coating makes the gauges truly unreadable with direct sun glare, I may just have to live with the scratches.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
03-10-2022, 04:07 PM | #16 |
Rep 63
Here is a guy who polish the hole cluster with a heavy polish. Now its glossy, but no scrathes. He also tried an additional windows (at the end of the tread).
https://www.2ertalk.de/threads/4647/page-9 My cluster has a few small scratches. Only use air to clean but if it will get worse i also will polish it glossy. |
Tags |
cluster, instrument, lci, novus, scratch |
