08-25-2020, 03:26 PM | #221 |
Rep 428
Had a great day again on the track. Managed to improve my best time by 2 seconds! I like the Westlake Sport RS tyres, they are easy to handle on the edge.
08-27-2020, 01:22 AM | #222 | |
Rep 775
08-27-2020, 02:25 PM | #223 |
Rep 428
Well, it was a long time ago, but as i remember it didn't take a long time, less than 30 minutes, especially if you get some help and use a wider masking tape.
09-24-2020, 03:05 PM | #225 |
Rep 428
Today i installed the MMR OCC kit. It's better quality than the BMS OCC kit and looks way better in the engine bay.
Also received some MMR dress up and functional bits, like billet oil filter housing, magnetic diff plug, magnetic oil sump plug, and oil thermostat cover. I will install them on my next oil change, which is due in a 1000 km.
10-03-2020, 04:26 PM | #226 |
Rep 428
Today we were at the Fritzenfest car meet and I measured my car at a portable dyno there. It showed 362 HP and 639 Nm at the wheels. These are in conform with my own previous measures which were made with OBD+VBox+Racechrono.
My only surprise was that this dyno (V-tech VT-2) measured only 8.3% loss on the drivetrain, which seems a bit low for me based on other's experience. With this number my crank Hp is 395. If i calculate with a more usual 15%, then my crank is around 426 HP. After my last service visit I also switched back to 91RON map, because it holds power much better above 6000 RPM and it's visible on my chart too. Also my car won a second place in the beauty contest and I had some exhaust loudness measurement and it showed 123,7 dB.
12-09-2020, 03:07 PM | #227 |
Rep 428
After 2 months break due to some foreign work i have some time again to deal with my Bimmer.
The next project will be to install the Zunsport sport grille to reduce debris to the radiators and the IC. Will install it in the following days as time allows, stay tuned.
///MPhatic14041.50 |
12-11-2020, 09:23 AM | #228 |
Rep 428
Today i had the opportunity to install the Zunsport grilles. The installation procedure was quite easy and can be done in a short time. The fitment is perfect and i think the look is also great with the smaller holes.
12-23-2020, 08:33 AM | #229 |
Rep 428
Today I did an oil change so i had the opportunity to install some accessories which I've bought in September. They are the MMR Performance oil thermostat cover dress up kit, the MMR Performance billet oil filter housing and the MMR Performance magnetic oil sump plug. Here is the result.
02-26-2021, 03:01 PM | #230 |
Rep 428
After some winter brake i got some new parts for the next season. It will be time for a front brake disc change so i bought the EBC front set and I'm planning to change the brake pistons also at the same time.
For some visual upgrade i acquired a blue tow strap too.
03-14-2021, 02:40 PM | #232 | |
Rep 428
It holds up very well, still no need to repaint it. For good effect make sure to apply several layers then it will be durable.
04-09-2021, 09:18 AM | #233 |
Rep 428
My bumper had to be welded and repainted because my front splitter got stuck on a roadside. It's a shame but this can happen with low splitters.
Anyway, for the new one i've ordered the TRE winglet style splitter, but it will take a few weeks to arrive. Meanwhile for the front brake disc change i had to take the car to a service, because the disc bolts were stuck so i couldn't change it myself. These EBC discs look good, I hope they will perform well with RP1 pads too.
05-30-2021, 03:38 PM | #234 |
Rep 428
After a long wait finally the brake piston kit arrived so i installed it at the weekend.
Fits perfectly and i hope it will perform well too. The factory dust boots were totally gone.
06-26-2021, 10:58 AM | #235 |
Rep 428
After a long wait due to production delay i received some good stuff from AutoID. First step was the installation of the oil and expansion caps. They look gorgeous.
Tomorrow i will install the TRE front lip.
06-27-2021, 07:43 AM | #236 |
Rep 428
And here is the result:
09-29-2021, 07:26 AM | #237 |
Rep 428
It's been a while since my last post, but I hadn't got time and opportunity to develop my car recently.
But today i changed the oil in the differential (MSPA) and the manual transmission (MTF-LT5) and also installed on these the magnetic drain plugs I've bought previously. The fluid in the trans was full black after 55t Km, so it worth to change. Also i installed the Turner transmission shaft rear bushing. Now the gear change is a bit louder but more solid too.
gphung193.50 |
12-21-2021, 09:46 AM | #238 |
Rep 428
It took a while for the next upgrades, but here are my newest mods:
- I bought a WiFi Enet adapter so i don't always need a cable. - I bought the speed limit info retrofit box and coded up the car. It works well, it uses the map database since I don't have KAFAS2 camera just the base for High beam assistance.
12-22-2021, 02:29 PM | #240 |
Rep 428
I can recommend them, they look good and filter good. Much less debris on the radiators.
12-22-2021, 02:32 PM | #241 |
The Seeker
14042
Rep 3,369
12-22-2021, 03:57 PM | #242 | |
Rep 428
