11-24-2017, 08:34 PM | #6 |
Rep 1,366
12-14-2018, 10:57 PM | #7 |
Rep 3,807
Drives: Retired 2017 F87 M2
I have the same question. Im on kw v3 clubsport
Retired: |2008 328i Sedan|Montego Blue| |
12-15-2018, 02:09 AM | #8 |
Rep 4,496
MPerf coilovers only - 1.5 deg
As above + oem -30min camber correction hubs -2 deg
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT |
12-22-2018, 04:43 PM | #9 | |
Rep 2,448
Would be interested in what settings others are running lowered without camber plates though I do believe the amount of drop, wheels and tires affect the camber just as much.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
12-25-2018, 01:34 PM | #10 | |
Rep 88
OP: I'd read some guides to get a sense of what geometry you feel is best for you. Your driving style and skill both impact what toe/camber would be best for you. I assume you like spirited driving, which is why you asked the question in the first place. There was a great discussion on these forums a few years ago. Check it out: https://f87.bimmerpost.com/forums/sh....php?t=1278520 |
4
01-06-2019, 12:21 AM | #11 |
Rep 65
As above said, just answer the guy's damn question if not you don't have to reply.
I am on stock suspension, stock wheels but 265 front and 285 rear cup 2s. on stock the most negative camber i can get on rear is -2 degrees, and front -1 degree I track about every 6 weeks (4 days so far), the -1 degree in front chews my tires bad (i have camber plates coming for the front, plan to use -2.5 in front and leave -2 in the rear) Hope this answers your question from me |
01-06-2019, 04:41 AM | #12 | |
844
Rep 1,962
01-06-2019, 09:06 AM | #13 |
Rep 3,681
In degrees:
Track- Front: -3.1, 0.04 total toe in, Rear: -2.0, 0.30 toe in Street- Front: -1.8, 0.08 total toe in, Rear: -1.8, 0.30 toe in Stock- Front: -1.5, 0.16 total toe in, Rear: -1.8, 0.27 toe in I’m lowered 1/2” front & 3/4” rear. |
AmuroRay2165.00 |
01-06-2019, 01:00 PM | #15 | |
Rep 3,681
Haven’t noticed any major turn in or tire wear impacts. Last edited by ZM2; 01-06-2019 at 04:48 PM.. |
01-06-2019, 05:25 PM | #16 |
Rep 65
Rear wear is noticably less than the front, fairly even.
Circuit I track on is anti-clockwise, not many right turns so the front right takes the most damage. Wear is high on the outside edge of the right tire, and looks almost untouched on the inside edge. However I used to run the stock tire sizes (245 front 265 rear) and moving to the larger sizes there is far less sidewall wear/chording on the low amount of camber capable on stock. Still, as I still plan to track frequently the front camber of -1 just isn't enough, from a wear point of view. Hope this answers your question. |
01-07-2019, 11:46 PM | #17 |
Rep 1,261
I've been setting up BMW M cars for 20 years now.
Both for serious BSP solo 2 work and also as a HPDE instructor/driver. The 1st common misconception is lots of neg camber will ruin your tires. Simply not true. I've run between 3.2 and 3.7 degrees of neg camber up front on my last 3 cars with only a small amount of increased inside edge wear. The secret is to run "ZERO" Toe. If your not planning on frequent track & autocross days then you can run less camber, or preset your plates for street and track settings. Run 2-2.5 on the street with zero toe then push them in to the track setting. Don't worry about where the toe ends up. After the day is over push them back out to the street settings. Unless your a track junkie and/or an autocross addict the above works great. Otherwise set them up and leave them with the exact performance alignment you decide on. The number one mod after tires on a BMW for handling is maximizing neg camber at both ends of the car... its eye opening. Not sways, not springs, not C/O's, etc. HTH, HAZMAT
alexng72147.00 |
01-08-2019, 05:02 AM | #18 |
Rep 960
So i ended up running -2 degrees on the rear with my M perf coilovers and whatever the front naturally ends up being. Drives comfortably for street.
01-08-2019, 07:45 AM | #19 |
Rep 3,681
Just want to be clear for the newer guys that zero toe in the front is good for the track, but zero toe in the rear is not recommended. The car gets less stable under throttle the less rear toe you have.
Some guys like less rear toe to help rotate the car in the corner, but I find that comes at the cost of mid corner and corner exit stability while you’re trying to get max power down. The rear toe keeps everything consistent and stable, and if I need some rotation, I just add a little more throttle. |
01-08-2019, 12:37 PM | #20 | |
844
Rep 1,962
01-13-2019, 11:44 PM | #21 |
Rep 65
01-13-2019, 11:45 PM | #22 | |
Rep 65
