M2 Technical Topics > Suspension | Brakes | Chassis > Camber plate installation difficulty?
      10-02-2017, 09:30 PM   #1
serrated
Is camber plate installation easy? Easy meaning a floor jack, jack stands, and some basic hand tools and torque wrench all I need, or is it fairly involved? I just ordered a square track wheel/tire set for my first track day and heard that stock alignment can eat the tires so I decided it might be a good idea to order front camber plates. I'm just trying to decide if I want to get the ground controls and install them myself or if I should get Dinan ones and have the dealer do it.
Thanks!
      10-03-2017, 05:25 AM   #2
CommitConfirm
475
Drives: The Bus
Spring compressors to be able to take the support guides off and for the camber plates.
I'd also allow for an alignment check when your done.
Lastly, torque up the bolts with the car on the me ground.
      10-03-2017, 12:32 PM   #3
serrated
Ugh, I hate messing with spring compressors. Freaks me out every time. Thanks for the reply!
      10-03-2017, 02:45 PM   #4
lax01
Drives: 2017 M2
You absolutely need to do an alignment post install...how are you going to know how you changed camber and caster with the plates?
      11-24-2017, 01:44 PM   #5
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Thanks!
What square tire and wheel setup did you get?
      02-06-2018, 11:21 AM   #6
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Thanks!
Hi, was interested which ones you went with, as I am considering the same. Did you install yourself? Do they make any noise?
