09-28-2017, 07:18 PM | #1 |
Rep 4,551
Drives: 2015 328d xDrive
LCI headlight retrofit
Would the new LCI adaptive LED headlights be a plug and play mod (on a pre-LCI car) that would just require some coding, or is it more complicated than that?
10-02-2017, 03:02 PM | #2 |
Rep 445
I would like to know as well.
10-02-2017, 03:09 PM | #3 |
Rep 549
Drives: The Bus
The lights themselves are a straight bolt on swap.
HOWEVER, it is my understanding, that the new hex lights are only available on LCI cars optioned with adaptive headlights. So you would need a pre-lci optioned with adaptive headlights to make this even a starter. I’m confident it can be codes but someone will need to buy a set to confirm the wiring. |
10-02-2017, 04:31 PM | #4 | |
Rep 4,551
F&F Retrofittings in Germany has done LCI taillights on an M2 and the LCI guages on an M235 so i'm assuming a headlight retrofit is possible. Just wondering if it's as simple as swapping the lights and coding out bulb errors or if more would have to be done. Last edited by AndrewC1989; 10-02-2017 at 05:30 PM.. |
NYC Bimmer259.50 |
10-02-2017, 06:09 PM | #5 |
Rep 549
Drives: The Bus
It was that easy for the rear lights yes, I've done a few cars now. Only gotcha with the rears is the old lights use an 8 pin connector and the new lights use a 6 pin connector. You need to order the new plugs and re-pin them with the existing wires.
My concern, which is unfounded, is that the new front lights are similar. And at £2k for none refundable parts I've yet to find anyone in the UK willing to find out. LCI gauges are simple. I have one guy 90% ready to buy the parts but as yet I've not done one yet. Anyone in the UK want to be the first? |
10-02-2017, 06:22 PM | #6 | |
Rep 226
Wish I lived in the UK I would definitely give you my car to try it out on. Hopefully you will get someone.
10-02-2017, 06:33 PM | #7 |
Rep 4,551
NYC Bimmer259.50 |
10-02-2017, 07:41 PM | #8 |
Rep 549
Drives: The Bus
LCI instrument cluster retrofit http://f87.bimmerpost.com/forums/sho....php?t=1427173
AndrewC198910931.00 mjsaville101.00 |
10-03-2017, 10:02 PM | #9 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Are the clusters physically compatible? The LCI has the whole dash redesign, I thought maybe they wouldn't physically fit between the two holes. Also, WTF is the blue FAKRA / coax connector for on the back of the cluster?? I see a multi-pin connector, and then a 2-position plug that I'm guessing is MOST / optical bus, but what does the cluster need an antenna connection for? Only thing I can guess is that it's connected to the keyless / convenience start, and that is all run through the cluster? (I know that stuff related to engine start & key security runs through the cluster on VW/Audi cars which is the only reason I'm thinking maybe BMW is similar...)
10-31-2017, 02:02 AM | #10 | |
587
Rep 898
11-18-2017, 06:16 PM | #11 | |
Rep 445
11-19-2017, 03:29 AM | #12 |
Rep 8,364
11-19-2017, 07:37 AM | #13 |
Rep 445
Ordered brand new. Sorry but what's the difference between 6WA and 6WB I don't know what that means.
11-19-2017, 01:15 PM | #14 |
Rep 8,364
11-19-2017, 01:18 PM | #15 |
Rep 445
Guessing 6WA since it's still analog.
11-19-2017, 05:30 PM | #17 |
Rep 4,551
question is with many of the LCI cars having gauge cluster issues and needing a software update, will that affect those of us who retro fit them on our Pre Lci's
NYC Bimmer259.50 |
11-19-2017, 09:34 PM | #18 |
Rep 8,364
01-22-2018, 10:31 PM | #19 |
Rep 4,551
Just found the required part numbers for the LCI adaptive LEDs
LCI LED Adaptive Headlights (w / o Control Units) 63 11 7 469 783 LED AHL High - left 63 11 7 469 784 LED AHL High - right Control units 63 11 7 457 875 Control unit front light electronics (x2) 63 11 7 494 851 LED daytime running light module - left 63 11 7 494 852 LED daytime running light module - right 63 11 7 955 318 fan (x2) Price for everything not including install and coding is $5157.95 Looks like i'll be keeping my stock headlights, lol Good news is the rest of the lci parts are more affordable. Tail lights are around 500 and the gauge cluster is around 1000. |
02-26-2018, 11:09 AM | #20 |
Rep 25
I'm curious how many of the above parts are needed for a LCI car that did not come with the adaptive headlights. Would it be as simple as swapping out just the headlight assemblies?
02-26-2018, 11:23 AM | #21 |
Rep 4,551
Maybe cosmetically the assemblies would be plug and play, but If you actually want them 100% functional as adaptive lights and VLD etc. you'd need the control units changed as well.
02-26-2018, 12:19 PM | #22 | |
Rep 830
Unfortunately, as others mentioned, it is not possible just to do a simple plug & play swap, even if you have the pre LCI adaptive headlights. You need the new parts mentioned above, coding and so on....so the quote for doing the retrofit was around 7k : A lot of money for just upgrading to LEDs, €but beside the part costs here, it seems BMW has no interesst, that people just easily can upgrade to the LCI options....at least it always makes that impression if you ask for something like this....surely not every dealer is like that, but I have the feeling it comes as a instruction from BMW to „scary off" people from doing such mods |
