M2 Technical Topics > Suspension | Brakes | Chassis > KW V3 Clubsport vs M Performance Coilovers
      06-18-2017, 07:55 PM   #23
ex12psi
Drives: bmw
Originally Posted by cookiesowns View Post
Makes sense. I'll probably settle with +ET25 or +ET28. With the tires I'm going to run, -2.5 to -3 degrees should be fine for the tracks I run.
This is still primarily a street car for me..
Sounds like a safe bet!
      06-19-2017, 01:36 PM   #24
ryem3
ryem3's Avatar
Drives: 2020 MB M2 CS
Wow, crapping all over those m performance coils! For this thread, I thought the m coils are made by kw, so there shouldn't be any material difference, other than the BMW set likely to be cheaper!
If you're in the Ohlins or Moton league, you're going to be spending double the $1900 you can get the BMW set for. And then you need to find a place for reservoirs. And then deal with rebuilding the shocks regularly. If you want to play, you've got to pay! Hope you have the full cage and racing harnesses to go with!
ried791.50
DOMs335D220.50
      06-19-2017, 01:37 PM   #25
ex12psi
Drives: bmw
No fucking shit right? It's a never ending slippery slope and an incurable disease.
      06-20-2017, 08:32 PM   #26
kkakonn
kkakonn's Avatar
612
Drives: M4
I might be the only one not in the Ohlins camp but after owning them on 3 previous cars I'm not the biggest fan. Don't get me wrong, the quality of Ohlins is amazing and you can definitely see where your money is going. But my biggest complaint is that they are too stiff for street use, even at the softest setting. And then when you do get them to the track, the Ohlins are way too bouncy. Personally if I'm going to go with a steerable coilover with an occasional track day I would look into KW's or the M performance ones. If you want a real track capable coilover then go with JRZ's or MCS.
Follow me on Instagram!
      06-21-2017, 04:07 PM   #27
emdeuce
Drives: M2 ZL9 6MT
To stay on topic and address the OPs question, the only things I can comment on regarding the differences are the following:
KW:
Front spring is narrower allowing better clearances if you intend to either run camber plates or larger tires.
Rear spring is 9.25 inches
MP coilovers:
Rear springs are 10 inches and bottomed out with approximately "two finger gap". I measured the spring myself.
The shock body and coil sleeves are built off the exact same hardware. Im not sure if the shock valving is the same.
With that said, if they are both the same price, I'd go with the KW just because there is a "better" range of height adjustment and there is hard data such as spring rates and heights. I contacted KW and BMWNA and they have no technical data on the MP coilovers. If you find a killer deal for MP, new coil springs are about $50 a piece and are easily swappable to achieve a lower ride height.
Living Life Turn After Turn!
[/url]
F87 M2 Performance Edition - 2017-current
F15 X5 35d - 2014-2017
E36 M3 - 2009-2016
rjn43.50
AndrewC198910931.00
      06-25-2017, 07:25 PM   #28
ryem3
ryem3's Avatar
I'm not searching prices, but I'd love to hear if the KW V3s are less than $1900 a set.
      07-01-2017, 07:22 AM   #29
bernstem
bernstem's Avatar
I'm seeing the KW V3 at ~3k USD from multiple sources. I would be surprised if you can find them at 1/3 off that.
      07-02-2017, 01:35 PM   #30
ex12psi
Drives: bmw
KW:
MP coilovers:
Thanks for this. Helpful!
      07-02-2017, 04:14 PM   #31
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Are we comparing apples to apples?
Other than the Olins which have a smaller diameter spring the M Performance, KW V2 (except rears), KW V3 and Dinan HAS have similar diameter springs.
      11-21-2017, 10:43 AM   #32
Danne_485
Drives: BMW M4 2015 AY
Any more news on this? I have ordered an M2 and would like to know which coilovers to go for.
      07-17-2018, 12:11 AM   #33
DLag30
Drives: F80M3 & F36
Any reviews on how they ride and how’s the adjustability?
      09-17-2018, 10:42 AM   #34
K9GunSlinger
Drives: 2016 M2 MG 6-Spd
same ^
      09-17-2018, 01:03 PM   #35
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
926
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
Originally Posted by K9GunSlinger View Post
same ^
i had the V3's w/ GC plates since i thought my car would be daily driven and only see a few track days. this setup offered a good mix of light track and mainly street/canyon use. For the adjustability - on the softer side, it felt smoother than stock dampening; and on the very stiff side, a little bit too stiff for the bumpier tracks we have out here. i had to turn down the stiffness around 2-3 clicks to keep the rear end from hopping around while braking. the GC camber plates really help w/ the tire wear on track and turn-in became more precise. overall the V3 w/ GC plates are a good entry-level track suspension. it's overkill for strictly highway/daily grind use, but will shine on the weekends in the canyons and b-roads, w/ a few track days sprinkled in between. track rats will probably want something w/ more adjustability/stiffness though. But for those who daily drive their cars and want to ease into learning how damper adjustments will affect the balance of the car at the limit, this is a great setup.
when i upgrade to the M2C, i'm going to go w/ AST w/ a little stiffer spring rate due to increased weight, so i'm selling my V3's + Camber plates for $1800+shipping.
      09-18-2018, 09:08 AM   #36
snipersix
snipersix's Avatar
228
Drives: Retired 2017 F87 M2
2017 BMW M2  [0.00]
I actually pulled the trigger on kw clubsport for mine to pair it with stancepart air cups
Retired: |2008 328i Sedan|Montego Blue|
      09-20-2018, 02:03 PM   #37
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
Looking forward to your review
2018 M2 LLB DCT DP Custom Exhaust
2018 Accord Sport Platinum White Pearl
2013 Mini Cooper S Hardtop Pepper White
2006 M Roadster
      09-20-2018, 05:44 PM   #38
K9GunSlinger
Thanks For the review AL.
I picked up the M perf coils but I am debating between going with camber plates. I’m mostly DD with a canyon cruise maybe once every month or two. I see most people saying camber plates only help tire wear on track, not so much for DD. I was curious of this because I do have premature wear on my stock MPSS while the middle of my tire still had a good amount of tread, I would love to even out the wear more..and is there a reason you chose GC over the other brands such as vorschlag?
Thanks!
      09-20-2018, 07:44 PM   #39
UltraMagneticAL
Meh
926
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
Thanks!
if you are mainly driving around town, additional negative camber will only make premature wear worse. i brought in my car to get track alignment, and at the minimum setting of the plates, i was pretty close to -0.5 degrees with my drop before dialing in additional negative camber. i went with GC because i never saw issues with them on cars i installed them on back when i worked at a shop.
      09-20-2018, 08:15 PM   #40
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Ultra, when you say the wear will be worst with camber plates only driving on the street, you mean the interior of the tire will wear faster like the exterior does when your stock ?
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      09-20-2018, 09:18 PM   #41
K9GunSlinger
^ so essentially getting camber plates will do nothing for me as I only DR and canyon a little bit, as far as better tire wear goes (more even wear, less wear on inside/outside)
      09-21-2018, 12:21 AM   #42
UltraMagneticAL
Meh
926
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
i haven't driven long enough on stock suspension to notice any wear on the outside. however, have you tried getting an alignment done on the factory parts? i know people who track their cars without camber plates that get the outsides eaten up, but i'm unfamiliar w/ people who just daily drive the cars having bad outside wear. i think an alignment shop should be able to dial in a slight negative camber to fix that. which tires did you have?
i guess since i was addressing K9GunSlinger i was assuming the coilovers would be lower than stock, which typically introduces some negative camber. the wear on my PSS was pretty much mostly inside.
      09-21-2018, 11:17 AM   #43
18EM2
Public Last Class
18EM2's Avatar
2018 BMW M2  [0.00]
I'm thinking the V3's are the best all around coilovers from what you're saying so I've decided to get them. Unfortunately they're back ordered it seems so I'll need to wait until that gets resolved.
My next question is what tires and spacer sizes? I'll keep the stock wheels for now but I will switch to the PS4S. I'm thinking of going with 255/30 & 295/30 with a 10mm spacer up front. Does this sound like a good setup? I'm open to other recommendations and input.
Thanks
2006 M Roadster
      09-21-2018, 11:23 AM   #44
K9GunSlinger
Thanks
I ended up going with the M Perf coils. Tischer BMW had a killer deal, Brand new M Perf coils but there was cosmetic damage (some scratches on the springs of the coils) got em for 1500 OTD shipped including the hardware kit (80 bucks). From my research the M perf coils are just rebranded KW V3, with some spec changes mainly that the KW V3 allows you a wider range of lowering. which for me i want to keep my car at stock height, maybe a LITTLE bit lower so i didn't care about that. so if these are really just rebranded KW V3, and you dont care about going super low, i would hit up Brian Keller at BMW Sun Motors, he can you you the M perf coils for about 1950 OTD Shipped i believe. cheapest i could find the KWV3s for were like..2150 i think.
