09-26-2017, 12:36 AM | #47 |
Rep 48
09-27-2017, 03:44 PM | #48 |
3842
Rep 54,352
Drives: F80 M3
10-17-2017, 07:46 PM | #51 | |
3842
Rep 54,352
Drives: F80 M3
Trackpads are more abrasive when cold so they will wear out your rotors quicker. Ideally, you should swap out the track pads after an event. |
10-25-2017, 03:18 AM | #52 |
Rep 82
Can you recommend some pads that are not that track focused and can be used 90% on the street and 10% at the track? Like Michelin recommends to use the Pilot SuperSports.
As I mentioned in a different post from another thread the stock pads are really really bad even on the street when going a bit faster on mountain roads. I'm getting worried not to ruin my discs with pad deposit. |
10-25-2017, 11:04 AM | #53 | |
3842
Rep 54,352
Drives: F80 M3
rich8566608.50 |
10-26-2017, 12:07 AM | #54 | |
Rep 199
Which of the three has the best modulation/ feel? Which of the three is most like OEM? Thank you
10-26-2017, 11:35 AM | #55 | |
3842
Rep 54,352
Drives: F80 M3
DS2500 has the best initial bite and likely the best modulation in sport/light track day applications. Stoptech Sport is probably the most OEM like, but don't have the initial bite like OEM. Bite at higher temps are better though. |
10-29-2017, 05:20 PM | #57 |
Rep 245
Drives: M2 DCT MPerformance coilovers
PM with quote if you can deliver to New Zealand - Wellington. I am looking for RST3 'reds' to fit AP CP9668 Pro 5000 Radi-Cal – the CP9668 being the Endurance version that takes the 25mm thick pads.
10-30-2017, 11:16 AM | #58 |
3842
Rep 54,352
Drives: F80 M3
01-02-2018, 10:06 AM | #60 |
Rep 155
I'm also wondering this. I acquired a pair for the front and was told some people are running stock rears just fine on the tracks.
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
01-02-2018, 10:44 AM | #61 | |
3842
Rep 54,352
Drives: F80 M3
With OEM or just a sport type of pad there will be a front bias causing ABS to activate much sooner than expected. PM incoming! |
01-13-2018, 08:18 PM | #63 |
3842
Rep 54,352
Drives: F80 M3
These pads are harder on rotors than street pads when cold so street use should be kept to a minimum.
Maximoosh49.50 |
01-17-2018, 03:46 AM | #64 |
Rep 91
Interesting thread, thanks for all the advice. HP Autosport if you ship to Melbourne, Australia please PM me pricing. Don't forget forum member discount if still valid ☺ thanks!
01-18-2018, 12:07 AM | #65 |
Rep 433
Quick question about swapping RS29 and OE pads: is there any issue with the compounds and needing to scrape? Part of the Performance Friction pitch is easy switch street to track (z rated to 08 as an example). Or is there a recommended street match for the RS29? Same question but for the DS2500. Thx.
'07 e90 335i - SG/Black/Alum | 6 MT | Sport | Premium | Nav | CA
Dinan Stage 2 Tune, Stage 1 Suspension | BBS RS-GT |
01-19-2018, 10:14 AM | #66 | |
3842
Rep 54,352
Drives: F80 M3
If you want to use the Ferodo DS2500 on the street, then it makes sense to use their DS1.11 or DSSuno for the track. There is no bed-in required within the Ferodo compounds. |
