09-28-2023, 05:12 PM | #1 |
Rep 57
Less grabby pads
Greetings, does anyone have advice on brake pads that are not as grabby as stock.
Car is driven on the street most of the time,, so i dont need track oriented pad, just something that doesnt have that initial grab. Thanks. |
09-28-2023, 07:44 PM | #2 |
Rep 45
I found the stock brakes on my OG M2
We’re not grabby enaugh 😂 EBC brake pads are great Lots of choice Stop Tech Not bad for the money I |
09-28-2023, 07:51 PM | #3 | |
The Seeker
13989
Rep 3,358
The CarboTech 1521 is your pad, without question. They are a linear pad, as opposed to the crappy progressive stock pad. They dust 80% less, are completely noiseless (just make sure to install the stock rear shims, front shims are not needed), and will double the life of your rotors. They also require no bed-in, just drive easy on them for 300 street miles and you're good to go. Accept no substitute. They prefer to deal over the phone. https://ctbrakes.com/choosingcompounds/ |
///M TOWN20190.00 |
09-29-2023, 09:14 AM | #5 |
The Seeker
13989
Rep 3,358
09-29-2023, 09:29 AM | #6 |
Rep 4,697
I'm probably going to buy a set soon and they are local to me if I need to pick up an extra set while there. It I'm still a few weeks out. Then will probably get lazy and ride with the xp12s for a bit
///MPhatic13988.50 |
09-29-2023, 10:57 AM | #7 |
The Seeker
13989
Rep 3,358
That's awesome. Maybe they'll give you a deal on 2 sets, if the OP wants them.
09-29-2023, 01:37 PM | #8 |
your average JAMF
3158
Rep 4,101
I'll echo the recommendation for Carbotech 1521's.
Most of the driving in my M2c is daily-driver type driving. This isn't all that uncommon, but the 2NH brakes are really not a good choice for a car that's not gonna get driven hard/braked hard on a frequent basis. At 8k miles my rotors seemed to be warped - though in doing research I came to the conclusion that this sensation was being caused by pad residue on the rotors. BMW replaced the front pads/rotors as a "goodwill" job. 4k miles later, same problem with the new ones. By now it was clear what was going on. So, after much research, I went with 1521's. MUCH happier with these pads for MY application. They are not a track pad - Carbotech warns you - but definitely are an excellent street pad. Side benefit is they are much cleaner. No more issues since. They've now been on the car for about 16k miles.
'21 M2 Comp
'19 Golf R |
///MPhatic13988.50 chris7197354.50 |
09-29-2023, 05:19 PM | #9 |
Rep 57
I have standard (blue brakes).
Thanks for the offers, but i would like to find something that i can buy in EU. If i don't find carbotech, are there any alternatives? ferodo, pagid? I assume that any of toose pads will have more stopping power, my main concern is initail bite. Thanks |
09-29-2023, 05:27 PM | #10 | |
The Seeker
13989
Rep 3,358
If your car is street only then there is an even BETTER pad for the blue brakes, and that's the Akebono's (1880 front, 1656 rear). These pads dust like 90% less, the dust is grey instead of orange, they will make your rotors damn near immortal, and they have a much better/linear feel vs the stock pad. However, they are NOT meant for even light HPDE's, they are a street pad only. Hard stops are fine, but multiple hard stops over and over for 20 minutes isn't. The Akebono's were the best street pad I've ever had on any car, even better than the CarboTech 1521's. |
philth222.00 Lost in München43.50 |
09-29-2023, 11:01 PM | #11 | |
Rep 3,540
10-01-2023, 08:15 AM | #14 |
Rep 60
I also found the stock brakes to be sensitive & "grabby" at slow speeds.
Additionally they threw a lot of brake dust & squealed quite a bit. I installed a set of HWAK Ceramic brake pads front & rear Part #'s: (Front - HB828Z.760 Rear - HB193Z.670) All of the issues mentioned above were resolved. The only caveat is that on the rear pads there is no provision for the wear sensor, which for me wasn't a big deal as I just tied it off to the side. BTW, These pads are available from AMAZON Good luck! |
CSBM52754.50 |
10-07-2023, 04:56 PM | #16 |
3885
Rep 54,481
Drives: F80 M3
Porterfield R4-S. Less initial bite and more linear.
https://hpautosport.com/product/port...s-f87-m2-comp/ |
///M TOWN20190.00 |
11-10-2023, 01:36 PM | #17 |
Rep 185
Rather than start another brake pad thread, I figured I'd ask for recommendations for my situation in an existing one. And since this is talking about the blue brakes it seems like as good a place as any...
I have an OG M2 that's mostly street driven, including daily city/highway, plus some spirited runs through the mountains of MD, VA, and WV. I also do the occasional auto-x. I'd love to get less dust and less rotor wear, but I don't really have a problem with the feel of the stock brakes. If another pad is going to be less grabby, great, but it's not a deciding factor. I'd also love to not worry about swapping pads for auto-x, but it's potentially an option. If I decide to do any track time I'd definitely be swapping so that's not an issue for these pads. From what I've read, Akebono and Carbotech both seem close, but would either be appropriate for auto-x? FWIW we don't have long, fast courses around here like they do in, say, Texas. We're talking probably 60mph and around a minute, max. I also saw someone make the comment that they wouldn't run Akebonos for canyon runs. I've never driven in CA so can't make a direct comparison, but I definitely wouldn't want to be lacking confidence in my brakes when driving the mountain roads out here. I also drive the car in cold (but not snowy/salty) conditions, so cold/rain performance is important. I've seen the Porterfield R4-S mentioned and those seem like they might be a good option, but are they 2NH only? I didn't see a set listed for OG brakes. Finally, given my use case, thoughts on brake fluid? SRF? I'm due to change mine, which has prompted me to look into just refreshing the brakes overall. Thanks all! |
11-10-2023, 03:39 PM | #18 | |
Rep 72
11-10-2023, 05:32 PM | #19 |
Rep 7,315
///MPhatic13988.50 ///M TOWN20190.00 |
11-10-2023, 06:09 PM | #20 | |
The Seeker
13989
Rep 3,358
He admitted that they were related, but maintained that per the agreement the exact materials had to be different by a certain percentage. 1. I don't think we can know more than that. 2. I don't think it matters. I have had CarboTech pads on my M2, and currently have G-Loc pads on my Exige and all I can say for sure is that the G-Loc GS1 pads dust a bit less, and the dust is a bit different in color. The 1521's increase in dust could be just because the M2 is heavier, creating more dust, which is plausible. I preferred the Akebono pads to BOTH of them, for the street. In terms of aggression it looks like this... 1. CarboTech 1521 (most aggressive) 2. G-Loc GS1 (less aggressive, but still similar) 3. Akebono (much less dust, much less aggressive, best street pad IMO) Unfortunately, the Akebono pad will NEVER be made for the 2NH because their machine is incapable of handling a pad of that size (I literally called and asked). |
chris7197354.50 |
11-10-2023, 06:26 PM | #21 | |
Rep 7,315
I was told by some guys on Rennlist and Nasioc that they were exactly the same but who knows. Honestly the way the backing plates etc. are finished make me think they are a lazy company and probably the same. Could also be your Exige pads are just from an older run and they tweaked the material. I was sent the wrong rear pads at first and the box was really old looking compared to the fronts. Who knows how old their stock of certain shapes are. They have been selling the same line of pads for almost 20 years now. |
11-10-2023, 06:48 PM | #22 |
Rep 3,540
I wouldn't buy from GLOC. Their customer support (which ended up being their president) was really lacking and took them over a month to get me the correct pads after they sent me the wrong ones.
