M2 Technical Topics > Track / Autocross / Dragstrip > Harness for M2
      02-20-2017, 11:19 AM   #1
GinsMarc
GinsMarc's Avatar
Drives: 2017 BMW M2
Harness for M2
I'm looking for a harness for my 2017' M2. I don't want to install a bar. Looking for something that can lock into the rear seat infrastructure, that can be easily installed and removed. Ideas?
      02-20-2017, 01:43 PM   #2
Tano
Tano's Avatar
Hungary
375
I think this will fit.
      02-20-2017, 02:56 PM   #3
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
It will.
      02-20-2017, 03:31 PM   #4
rwalker
Drives: the wheels off
Schroth QuickFit for an E82/E92 fits, but you have to mod the bolt covers for the outboard front anchors a bit...
      02-20-2017, 04:46 PM   #5
GinsMarc
GinsMarc's Avatar
Drives: 2017 BMW M2
Thanks. I'll take a look.
      02-20-2017, 06:36 PM   #6
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Mine dropped in straight from my E82 with zero mods.
Appreciate 9
DrKevM52276.00
rwalker329.50
BAN_M2C4185.00
AndrewC198910932.50
ddnmkun153.50
SebsM2652.00
CrashFL137.50
      02-21-2017, 09:06 PM   #7
Twix
Twix's Avatar
658
Drives: 2011 e91
These look like they'd be a lot more comfortable than the stock belt. I'm short and stocky, the belt digs into my neck
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      02-21-2017, 09:15 PM   #8
rwalker
mine
      02-22-2017, 04:32 PM   #9
LBBDrew
Drives: 2017 LBB M2
Are these 100% safe to use on stock seats and without a bar? I recall reading something on the S4 forums a while back that these can actually be more dangerous than the standard belts
      02-25-2017, 10:10 PM   #10
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Leduardol
      02-25-2017, 11:22 PM   #11
Pyrat 2
Pyrat 2's Avatar
They were designed specifically to be used as mounted in my posting above with no bar. Take a look at the schroth site.
      02-27-2017, 09:13 AM   #12
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Anyone know if these quick fits are HANS compatiable?
Is the E82/E92 the same model?
      02-27-2017, 12:55 PM   #13
rwalker
Their website and packaging implies this is indeed the case.
      02-27-2017, 03:42 PM   #14
CommitConfirm
475
Drives: The Bus
This is SO dangerous. Darwin awarding winning stuff! Do not use over the shoulder harnesses with a reclining seat! Especially one not designed for them....
      02-27-2017, 04:57 PM   #15
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
I thought this too until Pyrat 2 post about his harness and I called Schroth.
I feel their web site does not explain the belts well. Part of the ASM technology is a special stitch in the right (?) belt that tears when force is applied (e.g. accident), creating slack in the one belt and allowing the body to rotate similar to a normal three point belt. This avoids the roll over roof crushing spine scenario.
Additionally, these are not the same as routing a normal 5/6 point harness. Normal belts need to be used w/a harness bar or better roll cage.
The Schroth Quick Fit belts (Pro and regular) that were designed for the E82/E92 may fit M2 but Schroth has not tested them w/the M2 and therefore they will not "recommend" them.
Only the Schroth Quick Fit Pro is designed to work with the Hans device not the "regular" version.
I'm planning to purchase a set of the Schroth Quick Fit Pro for autocross.
      02-27-2017, 06:32 PM   #16
Pyrat 2
Pyrat 2's Avatar
Not sure I understand. These harnesses were made for this by design. The e82/92 fitment also has reclining seats. Recommend you look at the scroth site and talk to them. These harnesses were designed not to be used with a bar.
      02-27-2017, 06:33 PM   #17
Pyrat 2
Pyrat 2's Avatar
Correct The e82/92 is the same.
      02-27-2017, 06:33 PM   #18
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
When I talked with them they specifically stated they were not designed (i.e. not tested with a bar) to be used with a bar.
      04-19-2017, 08:53 PM   #19
Dirtboy
Dirtboy's Avatar
Drives: F87, F97
I have these harnesses in my E46; used them all the time on the Nürburgring.
But I've heard most tracks in the states won't allow 4-point harnesses??
      04-19-2017, 10:55 PM   #20
CosmosMpower
2051
Never heard this. I've not had an issue. These are even DOT legal.
      04-21-2017, 12:12 AM   #21
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Anyone know if the Schroth belts are identical across car models except for the mounting tabs / buckles?
I have a set of QuickFit Pro in my TTRS. I have a deposit down for an M2. If I can just buy new "tails" for the QF Pro that attach to the M2, that saves a ton of money on new harnesses... (I can always turn around and sell the ones from the TT, but that's a hassle I'd love to avoid.)
I'm also kind of surprised that Schroth hasn't moved to using the LATCH loops to attach the belts in the rear. Instead of having to bend tabs and bolt the "tails" into the factory bolt points, they could use something like an actual climbing carabiner (screws shut) to clip onto the LATCH hooks. Unless those aren't rated for the force/mass of an adult since they're usually designed for child seats... I dunno.
      04-21-2017, 12:29 AM   #22
rwalker
I found that belt lengths differed greatly between e90 vs. e92.
Obviously you don't want to skimp here, perhaps you should ask Schroth what leverage you can realize.
