Classifieds Section > Sponsors Classifieds > AP Racing Radi-CAL Competition Brake Kit 9660 - F87 M2 & M2 Competition
      10-20-2023, 07:27 PM   #221
HP Autosport
Drives: F80 M3
bump
      11-01-2023, 03:39 PM   #222
HP Autosport
Drives: F80 M3
bump
      11-22-2023, 06:05 PM   #223
HP Autosport
Drives: F80 M3
Up to $1000 off during November! PM for a quote
      11-24-2023, 01:53 PM   #224
HP Autosport
Drives: F80 M3
bump
      11-27-2023, 07:28 PM   #225
HP Autosport
Drives: F80 M3
Just a few days left to get up to $1000 off on AP BBK!
      12-14-2023, 02:46 PM   #226
HP Autosport
Drives: F80 M3
bump
      12-14-2023, 08:30 PM   #227
HP Autosport
Drives: F80 M3
bump
      01-02-2024, 03:25 PM   #228
HP Autosport
Drives: F80 M3
bump
      01-16-2024, 09:57 PM   #229
HP Autosport
Drives: F80 M3
bump
      02-01-2024, 11:12 AM   #230
HP Autosport
Drives: F80 M3
Part #: 13.01.10045
Brand: Essex & AP Racing
Complete front Essex Designed AP Racing Radi-CAL Competition Brake Kit for the F80 M3 F82 M4 F87 M2 & M2 Competition:
Features AP Racing CP9660 Radi-CAL calipers
Saves 26 lbs. of unsprung weight vs. the OEM M2 Competition front brake package!
Clears 19" OEM wheels without a spacer
372x34mm, 84 vane AP Racing disc
Saves roughly 10 unsprung lbs. from the nose vs. the standard OEM iron brake package
Every component designed to resist the heat of extended track sessions
Pistons sized properly to allow for seamless integration with OEM master cylinder and ABS system
Designed to work with OEM rear brakes or our Essex/AP Racing rear BBK
BMW F8x M3 M4 F87 M2
Front 9660/372- F80 M3 F82 M4 F87 M2
Application: Track
WHAT'S IN THE BOX?
One pair AP Racing CP9660 Radi-CAL Pro5000R six piston calipers
One pair 372x34mm AP Racing CP6084, 84 vane, J Hook racing discs, with fully floating 6061 hard anodized aluminum hats, and attachment hardware
One pair caliper mounting brackets and hardware
One pair Spiegler Stainless Steel Brake Lines with abrasion resistant coating
Detailed installation instructions
Brake pads are NOT included with our system. Racing brake pads are a highly personal choice. Many manufacturers include a set of inexpensive, low quality pads with their brake kits. Rather than artificially inflating the price of our system with a set of pads you probably don't want anyway, we've decided to remove the cost from our system and allow our customers to choose the pads that best suit their needs/wants. When purchasing our kit, you are able to choose one set of front pads at a substantial discount vs. the retail price. Please use the drop-down menu to select your pads.
Advantages Over OEM Brake System
Our CP9660/372mm Radi-CAL Competition Brake Kit offers our customers the following advantages over the OEM brake system:
Approximately 10 lbs. of unsprung weight reduction vs. the OEM standard front iron brake package
AP Racing Radi-CAL calipers are the stiffest, lightest, and most technologically advanced calipers available at any price
CP9660 calipers use a 18mm thick, commonly available brake pad shape
Ventilated, domed back, stainless steel pistons keep heat out of the brake fluid and provide an ultra-firm pedal
Mitigation of pad knockback via anti-knockback springs behind the caliper pistons
Anodized caliper finish that is resistant to wear and deterioration at elevated temperatures
Stainless steel caliper hardware for a long caliper service life under frequent pad change conditions
High temperature, low drag seals that will hold up to track temps= less rebuilding and longer service life
No dust boots to burn up
Simple pad change with two bolts or quick-change spring clip, no caliper removal required
Lifetime professional caliper rebuilding support by Essex (at a fee)- pull off your calipers, send them to us, we clean, inspect, and rebuild them
Available disc burnishing service ensures that your kit arrives ready to be installed and driven hard immediately
Championship winning, 84 vane, fully floating, AP Racing J Hook racing discs with 12 attachment points to hat
Anti-knockback/anti-rattle disc attachment hardware
Replacement iron disc rings available at an extremely competitive replacement price
Disc metallurgy specifically designed to handle the temps typically seen on track offer a long service life
Highest quality, Spiegler stainless steel brake line with clear sheath that reduces compliance over OEM rubber design
      02-14-2024, 07:23 PM   #231
HP Autosport
Drives: F80 M3
bump
      03-05-2024, 03:49 PM   #232
HP Autosport
Drives: F80 M3
bump
      03-28-2024, 06:24 PM   #233
HP Autosport
Drives: F80 M3
bump
      04-14-2024, 06:30 PM   #234
HP Autosport
Drives: F80 M3
PM for quotes!
