09-22-2022, 08:30 AM | #67 | |
Rep 1,657
The Garmin by far is the most user friendly device for bettering your driving there is on the market today.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
09-22-2022, 10:16 AM | #68 | ||
Rep 2,819
Drives: e82 1M, f87 M2cs
09-22-2022, 10:34 PM | #69 | |
Rep 2,819
Blank
09-23-2022, 06:31 AM | #70 |
Rep 371
I've been using the apex phone mount and iPhone 13 wirh m lap timer . Works perfect if you got the app before they took it down😡
09-23-2022, 07:01 AM | #71 |
Mmmm... Bavarian
2129
Rep 1,690
Noth video and data
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
10-19-2022, 08:31 PM | #72 | |
Rep 280
Thanks for the input. A |
10-19-2022, 08:38 PM | #73 |
Rep 4,697
This thread is inspiring. After feeling what it was like when my 200+lb instructor was not in my car. My interest to drop another 100lbs or so has my interest.
10-19-2022, 08:48 PM | #74 | |
Rep 1,657
He called me to vent about the drivers side. Then once he knew what the secret sauce was the passenger side was a cake walk. They are SUPER SOLID and the sliders work with ease. Couldn't be happier with the seat mounts and well worth the effort in importing in my eyes.
10-19-2022, 08:51 PM | #75 | |
Rep 1,657
BMW is going backwards in that department!
F87EVO4046.50 |
10-20-2022, 11:30 AM | #76 |
Rep 4,697
Which Alcon kit did you buy for the front. Is it the same as the M2CSR or is it the bimmerworld 380mm? Are these the same?
10-20-2022, 03:13 PM | #77 | |
Rep 280
After your outing on the track with the "street version" CS I am pretty excited to see what this can do with all the goodies, proper alignment and "fatter" tires on 18". I will order the brackets and will ask you for the shops contact if I see the guys here struggling. |
ptgltw3779.50 |
10-20-2022, 07:46 PM | #78 | |
Rep 1,657
Part number CR6420 or something like that. $4738.00 ish
aatlas202.50 |
10-20-2022, 07:49 PM | #79 | |
Rep 1,657
10-20-2022, 09:45 PM | #80 | |
Rep 280
Apparently the change is drastic. Car is expected to be stable and planted https://www.teamschirmerparts.com/co...37997016580283 Uniball kit including spacers for rear subframe side / lower arm Eccentric Uniball kit including spacers for wheelhub Full adjustable toearm with Uniball and spacers Schirmer Nitron R3 suspension Anti-roll bar links Unibal bearings for front axle strut Will let you know as it is in... |
10-21-2022, 02:11 PM | #82 |
Rep 280
I believe it will be just short of $3K, you can put it together by getting 1) Uniball Bearing for Front Axel, 2) Small Kinematic GT and 3)Adjustable Drop Links - but I think what makes this system ideal is that it has been designed all together, from spring rates and other characteristic on the shocks to the rest of the components.
10-21-2022, 04:48 PM | #83 | ||
Rep 2,208
Drives: G81 M3 Touring (Frozen Black)
10-22-2022, 07:57 PM | #85 |
Rep 280
I assume this is address to "ptgltw" - Had a conversation with Tom Schirmer, he suggested I run 265s front on 10" wheels and 295s rears on 11". He mentioned minor fender rolling would be required (Although I check the CS and not a lot of fenders to roll also I am not sure I am willing to go that far). Also I am sure the flexibility of the camber adjustment provided with their set up or camber plate might be required to minimize/avoid rubbing before any fender rolling.
10-22-2022, 08:57 PM | #86 | |
Rep 371
10-22-2022, 10:30 PM | #87 |
Rep 4,697
Seems like the CS+ step is the carbon buckets, Alcon front brakes, and maybe a lightweight battery, and camber plates.. I think this would be good for about 150lbs. Then maybe 18" wheels,.and better tires. Beyond that I think a cage starts to be in order and further interior stripping.
10-23-2022, 07:25 AM | #88 | |
Rep 371
