M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > TuningTech FS BMW M2 Dyno Tuning & Testing (ECU Flash)
Closed Thread
      05-13-2016, 11:42 AM   #89
zenmaster
Drives: '17 M2
Originally Posted by Darkiedm4 View Post
If proven by 60-130 racelogic pbox data i will believe
I need hard data before believing. After all its same turbo as m235i or 335/435i. The 15% higher stock numbers come from increased stock tune. Jb4 logs showed 16-18 psi stock. Hence the higher stock numbers.
I don't think you're following. The m235, 335, 435 simply don't scale to the numbers we're seeing. The M2's increase in power over those models has little to do with its stock tuning parameters.
      05-13-2016, 12:24 PM   #90
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Whatever dude.
      05-14-2016, 10:18 AM   #91
zenmaster
Drives: '17 M2
Whatever dude.
My comments were based on the claim that their dyno is "set to read close to dynojet give or take a few horsepower". If this trivially verifiable claim turns out NOT to be true, then TTFS has an incredible marketing problem. They obviously know what they are doing, so a mistake would be out of the question. So it begs the question why would they risk falsifying data, esp. with a substantial number of potential customers on these forums?
      05-14-2016, 10:57 AM   #92
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
Whatever dude.
Look you seem to be a guy that takes everything for true without questioning.
I am a guy that needs real world proof before believing.
I have seen the M2 turbo and it has same turbine and compressor side as M235i turbo. So it will push the same air volume. Power comes from air and fuel and ignition advance. On N54tech there are people that posted stock tune logs so you can see boost pressure and ignition advance.
So if i take all of the above data and think about it my logic says the M2 just runs a higher stock tune compared to m235i.
We all know all dynos read different. So unless this company provides real world pbox data to match their high hp figures I stand with my statement.
Everybody chooses what he wants to believe. The M2 just like other N55's needs a pure stage2 to get a decent increase in power. My 2 cents.
Appreciate 4
FSociety3812.50
Jadar1754.50
      05-14-2016, 11:49 AM   #93
zenmaster
Drives: '17 M2
Eh, something not making sense here, regardless of turbo measurements. Yes we all know what the standard (or non-B30T0) N55 limitations are, including TTFS. With the standard N55 w/ DP, intake, intercooler, 335i, their tune dynos the typical/expected ~370whp. Nothing seems inflated.
      05-15-2016, 06:43 PM   #94
TTFS
TTFS's Avatar
130
Drives: M2, F10 M5, E46 M3, E90 M3
Everyone should choose what they want to believe and what is best for their m2. Our data is based on our experience with the car as other companies and enthusiasts who actually test things share their experiences. You are correct dynos read different for over a dozen reasons but...We were the second dyno posted on the forum with Active and IND and guys out of Cali to follow everyone was with in 5hp. (Not in that order). The power is nothing shocking the guys out of CA are making similar power with their tuning setup. As for data boost has been disclosed for both 17psi and 21psi runs. Anyways thanks for the input there is nothing wrong with being skeptical of anything in life.
      05-16-2016, 03:15 AM   #95
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
If you post 60-130 pbox data that would be appreciated
FSociety3812.50
      05-16-2016, 03:53 PM   #96
Vtec Abuser
Vtec Abuser's Avatar
35
Drives: 2012 135i DCT
I too would very much like to see some Vbox data to believe that this M2 is running well over 100 crank bhp gains from mapping and DP (or approx 150bhp gains on a 235i N55 if the turbo is the same?).
If you can supply some 60-130mph/100-200kmh data (verified through this site www.vboxverify.com ), it would generate even more interest in your software if the acceleration numbers match the dyno numbers.
A 430whp (480+ crank) M2 would be pulling at least 9.x on a 60-130 run IMO.
Appreciate 5
      05-26-2016, 09:19 AM   #97
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
FYI i installed JB4 on my buddy M2 the other night. We measured 100-200 with pbox. On map0 JB4 disabled we did 11.9. On map1 we did best 10.0.
The car still had stock intercooler and stock downpipe. He was running 93 octane fuel.
      05-26-2016, 09:56 AM   #98
Yellowflash21
Slovenia
370
Nice so you did notice the difference with overall acceleration!
      05-26-2016, 10:03 AM   #99
paradoxical3
Drives: BMW
I am going to the drag strip tomorrow if weather is good. Car has downpipe and intercooler, I will run stock boost and JB4 map 1 and 2.
      05-26-2016, 10:08 AM   #100
Yellowflash21
Slovenia
370
Which IC you got, and how easy it was to fit it?
      05-26-2016, 10:08 AM   #101
paradoxical3
Drives: BMW
Ambient Thermal Management. Very impressed with the quality. Using an ER chargepipe as well. The intercooler takes 10 minutes to install...the chargepipe takes 1-2 hours because of how tight it is.
      05-27-2016, 08:28 PM   #102
135iDCT
135iDCT's Avatar
138
Drives: 135I
stock m2 dct i did 10,5 100-200
      05-28-2016, 01:30 AM   #103
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
Mine did 11.9 on flat surface
      05-28-2016, 09:05 AM   #104
135iDCT
135iDCT's Avatar
138
Drives: 135I
me too flat but i shift at 6500 for better results
      05-28-2016, 10:08 AM   #105
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
I will ask my buddy to do some more runs. He now has decat pipe installed.
      06-01-2016, 03:50 AM   #106
Vtec Abuser
35
One easy way to prove things for both of you..
www.vboxverify.com
Get your results up on there and we will see what's what
      06-01-2016, 10:06 AM   #107
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
How did it go ?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      06-02-2016, 01:38 AM   #108
1azycat
Drives: 2017 F80 M3 CP
Any log of the boost curve? 21psi taper to what? I believe stock turbo will taper to 15 or 16psi max.. If so, that dyno curve does not make sense.
      06-05-2016, 08:03 AM   #109
TTFS
TTFS's Avatar
130
www.vboxverify.com
I will see if I can get it in the next week or two. I am interested as well. The hard part is father time. If you are on the east coast the car will be running at Mpact
What type of data are you using for what you believe. I have a video of the boost hitting 20psi during testing before we raised it another lb. Are you comparing it to dyno graphs of other n55 motors on piggy backs? If so ECU tuning and piggy back tuning are slightly different, but that's not relevant to this thread feel free to pm.
      09-18-2016, 10:04 PM   #110
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Though still a little skeptical about the results posted here, I'm interested to know if any further progress has been made since it's been 5 months.
In addition, have you tested the gains with flash on stock car on 91 Oct?
Thanks.
Closed Thread
