01-14-2019, 04:57 PM | #23 | |
Rep 258
The center trim piece just pops off too. You need to use trim panel pry tools and go slowly so you don't scratch anything. |
RocketBoots1860.00 tenkies147.00 |
01-14-2019, 05:53 PM | #24 |
Rep 15
Thanks for the reply. I still haven't made up my mind...
04-01-2019, 07:08 PM | #27 |
Rep 258
04-21-2019, 03:53 PM | #29 |
Rep 258
04-21-2019, 07:31 PM | #30 |
Rep 780
Yep. Installed today. I used a 3/8" plexi ring and broke the "wings" off the bottom of the box. The speaker was hitting that with the ring. Definitely way more bass. But missing some detail. I have 160 watts per channel so they have plenty of power!
05-05-2019, 09:58 PM | #31 |
dentite
339
Rep 760
Drives: 718 GT4, M2C, JLU392, e92 M3
Did you have any trouble mounting the Morel crossovers in the door? Do you have a picture of the crossovers mounted? I'm getting ready to do a similar install.
Thanks, |
05-12-2019, 09:38 AM | #32 |
Rep 258
No trouble mounting the crossovers. I didn't get pics, but they mount in the front corner of the door panels. There's a sticker on the backside you need to get rid of and then clean the area with rubbing alcohol.
04-23-2020, 01:53 PM | #33 |
2024 m340i, 2022 X5 M50i, 2019 m550i
24
Rep 115
Damaged PP82DSP
Need some advice. My stuff:
2019 m550i (HK) Morel Hybrid 402 Earthquakes PP82DSP Mobridge DA-1 JL RD 500/1 JL Audio 10W3v3-2 Visual Ice enclosure Had a 2016 F10 550 (HK). All this was installed, minus the Visual sub enclosure. I had a Musicar enclosure. They don't make one for the G30. VI made one for me (much cheaper). Everything worked perfectly in the F10. Everything installed in the G30, but the remote out from the DA won't power on the DSP. Assuming the remote wire connects to the remote OUT on the DSP. Not sure why there isn't a remote IN on this model. I decided to tap into a 12v outlet and run the wire to the remote OUT on the DSP. It worked! Not sure why. Any thoughts? During the install, the USB cable, which was connected to the USB port on the DSP, got caught and snapped off the connector. I tried soldering it back on with no success. During the process, I dropped some solder onto the motherboard, and now it won't power on. I know, rookie mistake. Now I'm debating whether to get another 82 or "upgrade" to another model. Any suggestions would be greatly appreciated. I searched the 5 series forum, but couldn't find what I was looking for, that's why I'm posting this here. Hope that's cool. Thanks! |
04-26-2020, 05:13 AM | #34 |
Rep 18
@jpt99
The morel hybrids are very power hungry, I’d change out the pp82dsp for the improved P Six DSP, it has the latest DSP software and provides the necessary power for this system, you’ve got great hardware on the speakers, they deserve a premium amplifier |
05-05-2020, 12:18 PM | #35 |
24
Rep 115
My 82 crapped out. Going to get the UP7. Little more power, especially for the Earthquakes. Looking at the different accessories (Director, UC3, hecBT (not sure worth it I have iPhone) hecUSB (Anyone use this with an iPhone?).
05-06-2020, 11:30 AM | #36 |
Rep 2,104
As previously mentioned, I'd go with the P-Six, especially if you have a dedicated sub amp. While the UP7 is a good unit, the P-Six is in another league. The UP7, like the PP82, is geared more for convenience, while the P-Six is geared more towards Sound Quality.
05-07-2020, 11:03 AM | #37 | |
24
Rep 115
05-07-2020, 12:48 PM | #38 |
Rep 2,104
Decrease?! I'd say they were severely UNDERpowered, depending on their impedance. As for the rears, disconnect them
11-01-2020, 03:53 PM | #39 |
Rep 8
Does anyone have experience with the eton stealth 7.1 bmw amplifier in an f87?
Is it a better alternative to the match up7? Looks convenient as it's plug and play, and you can also adjustable it via app instead of USB and laptop... |
11-01-2020, 11:16 PM | #41 |
Rep 75
I can't answer your question Ridinwide1, but I recommend posting something in the 2addicts version of this forum. They have a lot more traffic and their audio system is obviously the same as ours.
It would be nice if bimmerpost found a way to merge forums for stuff like this. |
11-03-2020, 04:50 PM | #42 | |
Rep 8
12-02-2020, 09:30 PM | #44 |
Rep 1,337
What doesn't work? Works fine in my M2C with the Match Up 7BMW.
The technic harness only loops the audio wires so there no reason it shouldn't work. There was an issue years ago where the harness was pinned wrong but that was a long time ago.
