12-18-2023, 12:00 AM | #1 |
Rep 154
While working on the suspension in the rear one of the 3 bolts holding the damper on top got damaged (for the life of me I don’t know how)
when I started installing I drove the bolt in by hand felt like it was ok maybe a bit hard going in so I removed it for inspection, one of the threads on the bolt was a bit damaged and must have striped the thread in the chassis, now when I install I can’t seem to torque it up (I stopped when it felt like it wasn’t getting any tighter) Any idea how I can fix it? Will halicoil work on this? I have only used a halicoil on aluminum I couldn’t find access to the thread from on top to see if it has enough meeat around it to be able to drill it out and use a Halicoil. Any idea how to fix this? |
12-22-2023, 01:24 PM | #2 |
3847
Rep 54,376
Drives: F80 M3
Take a look at Time Sert as well. Most forces are in bump anyway.
12-22-2023, 02:59 PM | #3 |
Rep 154
Thanks I’ve looked at it as well ( I’m just not sure there is enough meat) I’m actually starting to think of installing studs since I’m always finding my self dismantling these screws when I’m playing around with the suspension
I must have disassembled the rear damper screws 10-15 times already considering I track the car a lot and I’m always improving and tuning the setup |
12-23-2023, 08:27 PM | #4 |
2432
Rep 11,667
Just drill & tap to a larger size.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
12-25-2023, 02:40 AM | #6 | |
Rep 7,431
Also helicoils are a better solution than tapping to a larger hole because you can retain the stock fasteners and torque specs (helicoils when done right can hold the same torque as the stock threads), this is a benefit because if you are dealing with stretch bolts yielding them is vital to get the correct clamping load. This means with a larger bolt you can't get them to stretch at the same torque + angle as a smaller bolt, meaning a different and incorrect clamping load.
Talx85.00 |
