11-18-2023, 12:49 PM | #1 |
Rep 2
Impossible reset front brake pads service! Help please
Hi all,
I cant reset the front brake pads service, If I try to do it from the dashboard I find an unsuccessful reset. I have replaced the front brake pads sensor. I have also tried to reset the service with ISTA, but it is impossible. Reading the vehicle's faults I find 480A11: Brake pad wear sensor: front axle. I can't eliminate this error, it is always present. I have also tried two new brake pad sensors, and always the same. I have also tried joining the two cables of the old sensor and I am not able to eliminate that error either. Any advice? I have done the tests with the handbrake down. I'm a little tired with this issue... The video of the dashboard process: View post on imgur.com And the error in ISTA and the bonded cable sensor: Thank you!! |
12-10-2023, 10:29 PM | #2 |
Rep 75
This may be a dumb question but have you checked for updates and/or re-program/code the DSC system? When I have weird issues like this, once normal diagnosis has failed I program/code the offending control module to verify that isn't the issue.
I'm not sure what voltage the wear sensors operate at but I would also check the wires for voltage and reference to ground to make sure there isn't a short somewhere else in the wiring. |
12-14-2023, 06:42 AM | #3 | |
Rep 2
What is the process to reprogram the DSC? Can I do it with ISTA? Thank you. |
