10-16-2022, 05:15 PM | #1 |
Rep 151
M2C AP Racing Fronts - Strange Wear Characteristics
Hello All,
I installed the AP Racing front kit on my '19 M2C a couple of years ago. A few months later I noticed that the outboard pad/disc face are wearing at a 3x rate to the inside pad/disc face. This issue is present on both front wheels. About a year later I had some suspension work done at my performance shop, and had them buy new discs and re-install the brake kit, but the issue is still there. They reached out to AP, but they have yet to offer any suggestions as to what might be causing the issue. My shop has installed over 100 of these kits on various platforms and has never seen the issue. Has anyone encountered this problem, or have any idea what could be causing it? Thanks. |
10-17-2022, 10:59 AM | #2 |
4693
Rep 2,542
Not uncommon to see a bit of inner/outer pad wear difference on any setup - rotating them about half way through their life is good practice. But 3x is obviously way too much. What calipers are you running?
10-19-2022, 08:11 PM | #3 |
Rep 151
I am running the AP 9660 with Cobalt XR2 pads. I would be fine if it were just the pads since, like you say, I can swap them around and even out the wear. But the outboard sides of the discs are wearing quickly, which is quite a bit of $$ and no workaround for that. I wore out the outside of the discs with 9000 road miles and six track days in one year. Is that normal disc life? If so, I will just deal with the issue. Thanks.
10-20-2022, 07:59 AM | #4 | |
4693
Rep 2,542
12-11-2022, 02:12 AM | #5 |
Rep 886
AP knows damn well what the issue is. It is a documented issue with their calipers, they flex, not stiff enough, and you get bad pad taper, which leads to already high pad costs now effectively doubling or more in cost. The issue is made worse if you run their anti rattle clips.
Get 2NH (albeit heavy) for a street/track combo or an Alcon BBK through Bimmerworld for race performance
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
DrKevM52274.50 Daytona_550463.50 |
12-12-2022, 09:27 AM | #6 | |
1026
Rep 842
I'm not sure if you had a poor experience with our product that couldn't be resolved, or what the situation is, but your blanket statement about the quality of AP Racing calipers is both ridiculous and baseless. Pad taper is a fact of life with any caliper. We see it at every level of racing from every manufacturer. Some conditions promote taper more than others. Please check out our Track and Racing Pad Owner's Guide to get the most out of your brakes, regardless of who made them. |
12-12-2022, 09:32 AM | #7 | |
1026
Rep 842
12-12-2022, 09:41 AM | #8 | |
Rep 886
12-12-2022, 09:44 AM | #9 | |
1026
Rep 842
When race pads are hot, they work in an adherent manner and stick to the disc face. When they are cold, they work in an abrasive manner and wear down your discs. That's why the best route is to have a set of road pads for the road, and save your race pads for the track. Yes, you can get away with running some track compounds on the street if they have good manners (some of our customers use Ferodo DS3.12), but there are always tradeoffs with brake pads. There is no magic pad that will do everything well in every environment...simply doesn't exist. Race pads are great on the track but eat discs, are loud, etc. on the street. Street pads are gentle to cold discs on the street, but fade and wear quickly at track temps. There is no pad that does everything well in both arenas. Our suggestion is using the Ferodo DS2500 for the road/autox/sport driving and the DS1.11 or DS3.12 for track use. All those compounds play nice together on the disc face and work well in their intended environment. Nobody likes changing pads...I hate to do it on my own cars, but at least our calipers make it much faster and easier than OEM. Again, you need to use the right pad in the right environment. There is no free lunch with pads and there will always be tradeoffs. This is no different than tires. If you run Hoosiers on the street they aren't going to last very long. If you run 400 treadwear all-seasons on the track, you won't have much grip. It's the exact same dilemma with brake pads. You need to pick the correct tool for the environment. |
///MPhatic13862.50 |
12-12-2022, 10:07 AM | #10 | |
1026
Rep 842
Do you deny that just about every person in this discussion likely has different alignment settings? Do you deny that every person here may be running different tires of differing sizes with different inflation pressures? Do you deny that they are possibly on different suspensions, have different driving styles, different power levels, are running on different tracks, for a different number of laps? The list of variables goes on and on... A mountain of evidence (the thousands of satisfied clients we have, including many on this forum) suggests that there is no inherent problem with our brake kits, calipers, pad tension kits, etc. Every weekend people are out happily winning races and championships on them, HPDE, etc. A quick peek at our blog proves that. I'll go back to my tire analogy. Does everyone always see the same tire wear? Why did the inner Nitto tire on my Corvette cord early on one side, but not at all on the other side? My buddy's Hoosiers didn't do that. Is it fair for me to now try and publicly crucify Nitto Tire because their tires are inherently flawed? Have you demonstrated via controlled laboratory testing that our kits have some type of inherent problem? If you haven't, then you're simply making wild accusations and slandering our company and brands. |
12-12-2022, 10:16 AM | #11 | |
Rep 886
12-12-2022, 10:34 AM | #12 | |
Rep 3,540
Really? I guess my experience must be atypical... I have very very slight pad taper in front. Nothing a simple pad flip/rotation won't fix when I swap between street/track pads anyways.
12-12-2022, 10:41 AM | #13 |
Rep 886
For my own internal reference point, what taper do you see and what treadwear tires and pads do you track on?
12-12-2022, 11:54 AM | #15 | |
Rep 886
Taper thread All other variables the same, a non AP BBK swap fixes the issue ^^ Again I will ask, why do these AP calipers have more taper than others? I truly want to know. When pads can cost $900/set and be gone in a weekend, throwing away pads at half use or less seems like a direct route to double cost pads and a light wallet. Don’t even get me started on the wear characteristics you have historically had w/ your rotor metallurgy. Swiss cheese comes to mind. There’s a reason the bmw gt4 race teams swapped to Girodisc rotors.
12-13-2022, 12:26 PM | #16 | |
Rep 151
12-13-2022, 12:54 PM | #17 | |
1026
Rep 842
https://www.m3post.com/forums/showthread.php?t=1907146 "Again I will ask, why do these AP calipers have more taper than others? I truly want to know." Again, one person's experience in a completely uncontrolled environment is simply that. I don't know what else you want to hear about that. As for a team switching to Girodiscs...did it ever occur to you that there might be some type of commercial agreement involved? Girodisc has been trying to get their product on professional racecars for years to add to their street cred. We see that sort of thing at all levels of the sport. In NASCAR Cup in the years leading up to the switch to the current Next Gen Car, Raybestos/Alcon gave millions of dollars worth of free brake products to various teams in an attempt to gain market share. Another example would be the recent the Le Mans-winning Porsche 911 RSR that runs AP Racing Radi-CAL calipers. They sometimes pair them with Brembo Discs as shown in the photo below. Brembo owns AP Racing, and both companies both certainly like the exposure that accompanies a Le Mans win. Oh, and BTW, after winning Le Mans, Porsche didn't report any abnormal taper wear on their fundamentally flawed and flexible rear AP Radi-CAL calipers. |
12-13-2022, 12:55 PM | #18 | |
1026
Rep 842
12-13-2022, 01:03 PM | #19 |
The Seeker
13863
Rep 3,325
He's not deflecting, he doesn't agree with what you're saying, and doesn't have an answer to the problem, but has agreed to look into it, which is all anyone can expect.
jritt@essex1026.00 F87source7253.50 |
12-15-2022, 08:35 AM | #20 |
1026
Rep 842
Also of note, just yesterday BMW Motorsport posted on Facebook about one of their M4 GT4 customer cars being on the podium in all three races of its debut weekend in the GT Winter Series. Guess what brakes they've been using...AP Racing Radi-CALs and J Hook discs.
https://www.facebook.com/BMWMotorspo...RRCC2Yx3F9wZYl |
12-26-2022, 10:05 PM | #22 |
Rep 555
Could be installation issue. Did you measure the rotor is at the true center of the caliper? My ap kit has been flawless, but the previous owner had taper wear, which turned out that the shop installed the caliper at the wrong side.
IG: M2C_SO |
