M2 Technical Topics > Suspension | Brakes | Chassis > M2 Rear Toe Arm Upgrades
      10-26-2021, 05:49 PM   #1
ASAP
ASAP's Avatar
10161
Drives: '23 X3 M40i
Has anyone upgraded to toe arms w steel bushings i.e. the turner toe arms?
I wonder how much nvh they increase into the body.
I think the rear toe has a significant amount of flex that causes the car to waddle a bit on hard acceleration... I wonder if this would fix that.
      10-26-2021, 08:28 PM   #2
AlpsRider
AlpsRider's Avatar
2865
I don't know what tires you're running but stiffer sidewalls and good air pressure could help.
      10-27-2021, 04:50 AM   #3
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
No nvh increase that I have detected
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      10-27-2021, 07:27 AM   #4
ASAP
ASAP's Avatar
10161
Drives: '23 X3 M40i
Sure but does it actually reduce that rear end slop on acceleration?
      10-27-2021, 06:58 PM   #5
slicer
slicer's Avatar
2739
The first 5 things I do to the suspension on all of my BMW's (and recommend):
Quality Coilovers
Camber Plates
Monoball Front Control Arm Bushings
Rear To Arms
Rear Camber Shims
The toe arms reduce rear end slop by deleting rubber bushings and converting to rod-ends. It also eliminates the finicky eccentric bolts for adjusting toe. Eccentric bolts are not as precise or easy to adjust as an adjustable toe arm. Not all are created equally. I highly recommend Fall Line Race Toe Arms. Additionally the camber shims delete the eccentric camber adjustment and replace it with shims which are also more accurate and easy to use.
'23 X7
TripleU170.00
      10-27-2021, 08:38 PM   #6
Fabb
Fabb's Avatar
Drives: 2019 M2C SO
I added the spl toe arm at one point with no additional mods. Apart from more adjustability, I don't see any difference in terms of driving dynamics
IG: M2C_SO
      10-29-2021, 12:38 PM   #7
slicer
slicer's Avatar
2739
The reality is that changing to toe arms will have an impact but it's not going to be earth shattering. That's one of the reasons that I do the 5 things I recommended which will be a noticeable change.
'23 X7
MR RIZK757.50
      11-03-2021, 07:30 PM   #8
TripleU
Drives: 17 M2, 23 Ford F150 Raptor
  [0.00]
2017 BMW M2  [0.00]
Quality Coilovers
Camber Plates
Rear To Arms
Rear Camber Shims
Great to know! I was about to make a thread asking which SPL parts I should get first when I get some coilovers but good thing I browsed this sub-forum for a bit and I guess I will just start with your list.
Current: 2017 Alpine White M2 DCT, 2023 Ford F-150 Raptor
Past: 2015 Lexus IS 250, 2014 Volkswagen CC R-Line
      11-03-2021, 07:59 PM   #9
HP Autosport
Drives: F80 M3
We have sold and install many SPL version of the rear toe arms. Very minimum increase in NVH. Less toe deflections mean more power to the ground.
ASAP10161.00
      11-03-2021, 08:23 PM   #10
slicer
slicer's Avatar
2739
Quality Coilovers
Camber Plates
Rear To Arms
Rear Camber Shims
Please reach out if you need more help!
'23 X7
TripleU170.00
      11-15-2021, 02:30 PM   #11
M2 Slow
M2 Slow's Avatar
what monoballs do you recommend?
2017 BMW M2 DCT Long Beach Blue
      11-15-2021, 07:42 PM   #12
slicer
slicer's Avatar
2739
I like Fall Line best
'23 X7
      02-10-2024, 07:08 PM   #13
Ace604
11
Drives: 2019 M2C
To install, did you have to lower the subframe ?
      02-12-2024, 11:58 PM   #14
3t3p
New Zealand
455
Ah the waddle! Thought it was just me...
      02-13-2024, 02:12 AM   #15
ASAP
ASAP's Avatar
10161
Drives: '23 X3 M40i
I never ended up doing these upgrades.
The waddle is real and it combined with what I thought was a massively sub par stock m suspension thay was very bouncy was the main reason I ended up selling my car.
      02-13-2024, 03:34 AM   #16
3t3p
New Zealand
455
I just assumed it was a naughty trait of the car that makes it a bit raw or exciting. I know my reaction and lateral grip is alot better with coilovers
