M2 Technical Topics > Suspension | Brakes | Chassis > Differential Lift Kit - Amazing sound
      08-10-2021, 12:47 PM   #23
-Eidos
@lbb_kev
491
Drives: 2018 BMW M2 (LBB)
Originally Posted by ebisu8 View Post
It was time consuming but stoked to go through the process at home on my quick jacks. Having a full lift would make things easier but hey, I can't have it all...yet.
Here are the only two pics I remembered to take, I still have the rest of the car to put back together so I won't be able to chime in how it drives for a while.
What's the process on installing this lift kit? Is welding or fabrication work required?
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      08-10-2021, 02:55 PM   #24
ebisu8
Dom
ebisu8's Avatar
Drives: E46 M3 Comp
It is fairly straightforward. Drop subframe, unbolt, press in new bushings and torque then put subframe back up. No welding or fabrication.
      12-18-2021, 06:54 PM   #25
imolam3
Drives: 2004 Imola M3, 2017 AW M2 PE
https://www.akgmotorsport.com/produc...f82-m4-f87-m2/
I’m thinking of getting the AKG diff bushings. Installed all AKG bushings on my e46 M3 track car, they make high quality parts.
1997 Dakar M3
1999 Cosmos M3
2004 Imola M3 CSL clone
2017 Alpine White M2 Performance Edition
      12-23-2021, 05:34 PM   #26
M Fifty
844
Drives: M2 & 330CI
Maybe just get the uprated BMW Poly bush?
      12-26-2021, 11:13 PM   #27
bkd705
bkd705's Avatar
142
Are you guys running the schirmer kit or the turner kit? Or are they the same?
      12-27-2021, 09:11 PM   #28
-Eidos
@lbb_kev
491
I'm running the Schirmer kit on a 2018 M2. The sound is nice with the windows up, radio off, and a full interior. Once you go WOT it's a little harder to distinguish the diff whine from the engine and exhaust sounds if you're full interior on a high flow cat + Remus cat-back like I am, but it's still audible and adds to the overall race car sound track that's playing
Aside from the sound, the most prominent thing that I noticed was a much tighter rear end (less slop). I installed the kit at the same time as full SPL kinematics and Millway rear bushings. The power now gets sent immediately to the rear wheels, which I can attribute fully to the dual mounting points and solid bushings on the Schirmer kit. It literally feels like a motor on wheels.
One of the KMP kits is closer to the Schirmer kit than the Turner one as it actually lifts the differential to improve suspension geometry. This one: https://www.kmpdrivetrain.com/produc...t-bracket-kit/
The Turner kit doesn't do this.
Also just keep in mind that the Schirmer kit comes with solid bushings. So there will be minor variances in terms of sound and feel.
eldogo274.00
Telluride125.00
      02-23-2022, 07:01 PM   #29
jase2addict
Drives: 2021 M2Comp
I'm torn between the Schirmer kit and the KMP offset kit. Im lowered on coil overs and have a few SPL arms. I want to correct the geometry and get the benefits mentioned above. Can you suspension guru's please give some insight to help me decide between the two manufactures?
      02-23-2022, 07:34 PM   #30
-Eidos
@lbb_kev
491
Go with the company that you want to support/ what your wallet can support. Differences are mostly aesthetic.
      10-27-2023, 10:30 PM   #31
Telluride
Drives: 2020 M2C
^This! Had KMP rear diff bracket with offset bushings installed this week and my initial driving impression... excellent upgrade! This is a huge help for the M2's tendency for wheel hop. And I now understand why the BMW factory only used one bolt when attaching the M2's rear diff to the frame. Because the KMP bracket transfers gear whine into the car interior. Nothing to the degree of what is heard from in car camera shots of your favorite IMSA sports car race. But you will definitely hear whine... just at a much lesser decibel and it sounds glorious!
      11-04-2023, 04:53 PM   #32
fourthchirpin
Drives: M2C, VW GTI 3.6, Infiniti G25x
I just installed the Team Schirmer Lift kit. Initially I was like the whine was alil more than I expected. I dont daily drive the car so it wasn't a huge deal to me. but after driving it more and more with the radio on and such I dont notice it as much as my first drive. I do feel more power going to the wheel as the car is losing traction more easily (as im still stock with just an exhaust)
I understand the whine wont be for everybody.
      11-04-2023, 06:12 PM   #33
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
You are confused, the lift kit can be used with stock bushings and you would not have any noise.
This is my kit using oem bushings:
BMW does not use 4-point bracket for another reason, unrelated to noise.
Neither M4 GT4 nor the M2CSR, which are racing cars, use 4-point brackets
Bee Pee1779.00
chris7197334.00
      11-07-2023, 05:48 PM   #34
Telluride
Drives: 2020 M2C
Ahh, cool... I did not know.
For me, I want full engagement when behind the wheel, both physically and audibly. So I appreciate the direct feel and associated noise.
Do you have factory race engineer commentary or other facts as to why this change is not beneficial? It is curious BMW designed and put into production, a 2nd mount point for the F80/F87 diff. In the the couple drives I've done since this upgrade, I had a few instances which previously would have caused wheel hop. Would like to understand why this not considered beneficial or what trade off you believe we've made? Thanks!
      11-17-2023, 11:32 AM   #35
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Rear diff dual mount btracket + OEM poly bushes is the way I'd go if/when time comes to replace the single rubber rear miount bush on my OG M2.
Current '22 X3M LCI..
      01-17-2024, 05:04 PM   #36
WoodyOGM2
WoodyOGM2's Avatar
2017 BMW M2  [0.00]
2017 BMW M2  [0.00]
Started researching this due to needing to lift the diff to achieve more ground clearance, not just to correct the alignment or the noise. Seems the KMP lift kit is only lifting 10mm, which doesn’t sound like a big gain for the money.
Am I missing something?
      01-17-2024, 05:33 PM   #37
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
There is no room to raise more than 10mm.
My lift kit raises 10mm and the front support and subframe has to be filed
      01-20-2024, 02:29 AM   #38
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Millway Motorsport in Sweden has a 10 mm lift kit which uses dual OEM poly bushes in the rear, think they're the cheapest as far as I have seen also on this kit. Very high quality products, use them on several of my cars.
https://www.millway.se/dual-mount-di...f80-m4f82.html
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      01-23-2024, 03:16 PM   #39
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Sorry but no, it's not the cheapest.
      01-23-2024, 05:10 PM   #40
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Please do share.
      01-23-2024, 08:37 PM   #41
Telluride
Drives: 2020 M2C
Please do share.
I am in the U.S. Shipping to Europe might negate the savings... but where I got my KMP for a better price.
https://ind-distribution.com/product...et-bushing-set
      01-24-2024, 12:59 AM   #42
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Please do share.
My kit that you can see above for forum users 750e + 50e shipping.
This kit is not suitable for street use, unless you are 20 years old and you don't care about all the noises.
      01-24-2024, 01:28 AM   #43
F87source
F87source's Avatar
Drives: Bmw M2
+1
Not just noise, the vibrations on solid mounts will be unbareable.
      01-24-2024, 02:10 AM   #44
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Originally Posted by F87source View Post
+1
Yes I know because I have sold several kits with solid bushings for track use and the noises/klonck/vibrations are unbearable.
I would not mount it under any circumstances for street use.
