M2 Technical Topics > Suspension | Brakes | Chassis > Öhlins spring rates
      09-17-2021, 01:43 AM   #45
Poffman
Drives: 2010 M3
Originally Posted by DonPedron View Post
Going full softie now with 60front and 120rear
Would a revalve (or any other modifications) to the shock absorber be necessary? Race shop here in Sweden will supply parts and install everything for me
I have 70/140 (which I'm very happy with) swifts and was told any lower I would need a revalve which can be quite expensive. I would really suggest the 70/140 as a start and you can always go lower and revalve if you decide it's too stiff. I am in the 10-13 click range these days even on rough roads and very happy with the ride.
      10-20-2021, 12:33 AM   #46
DonPedron
DonPedron's Avatar
57
Drives: BMW m2
Now equipped with 60/120, and all I can say is, WOW!
Feels way less "toppy" but still very connected.
The DFV valve keeps everything in check; re-valve was not necessary. Very happy with this mod, suits me well. Great with the 513m wheels, previously the 513m with 90/190 made everything quite bouncy at 20 clicks. Underdamped.
M2 Csl (Coupe, Sport, Lounge) is now in the works!
Poffman493.00
      10-27-2021, 08:58 AM   #47
nando_514
Drives: None
Is a shorter spring required in the front to run wider wheels? I ordered a set of ProTrack Ones @ 18x10 ET 20 in the front and I'm concerned that Ohlins front spring length may interfere (?)
Anyone have experience running a similar wheel setup?
      10-27-2021, 07:02 PM   #48
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
Shorter springs are not required. There really isn't much room to go to a shorter spring anyway. The factory spring length has very few threads showing after pre-load is adjusted. 10 et20 will be close to the spring but may not need a spacer depending on the tire size/brand. What camber do you plan to run? If you are running in the -3 or more range you can add spacer without fender clearance issues. I run about -3.5 camber with Ohlins R&T (standard springs) and a 10.5 front with 275 hoosiers.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      01-18-2022, 11:48 AM   #49
TripleU
Drives: 17 M2, 23 Ford F150 Raptor
  [0.00]
2017 BMW M2  [0.00]
I'm picking up a set of MR40 coilovers. Since the MR40 rear valving appears to not be suitable for anything softer, I'm thinking of just changing out the front springs only, to 70 n/mm Swift springs as Brian from Ohlins suggests 70/190.
Would that seem to be ok or should I also change the rears?
Current: 2017 Alpine White M2 DCT, 2023 Ford F-150 Raptor
Past: 2015 Lexus IS 250, 2014 Volkswagen CC R-Line
      01-18-2022, 07:02 PM   #50
usc335
Drives: '21 M2C, '08 E92 335
For what it's worth, I'm very happy with 80 Front and 160 rear. I drove a car with the standard setup and I thought the standard 190 was too stiff.
      01-18-2022, 08:57 PM   #51
Poffman
Drives: 2010 M3
I'm very happy with my 70/140 swift setup. I think 190 rear would be too firm personally. If you have tons of power mods then you may want a stiffer rear 🤷*♂️
      01-19-2022, 02:33 AM   #52
David.m
Drives: M2 LCI 6MT BSM
I'm another very happy with 78/160Nm. I do a bit of spirited driving on average/undulating twisty country roads, for me I think the stiffness of 190 rears would cause traction issues.
      01-20-2022, 10:58 AM   #53
M1500Z
M1500Z's Avatar
423
Drives: a white BMW
Not sure where you're getting them from, but I would give Barry at 3DM a call for purchasing or revalve/respring if you're buying used. He's very informative and would get you squared away.
For my own opinion—I've been running a set of R&Ts on... track and road (a bit backward), and find them excellent for road use and the occasional track usage. On track, my personal feel is they're too softly sprung. The nice bit is either through just their damping characteristics or the DFV, they handle bumps and curbing quite well.
I'm pretty sure I have the higher-rate rear spring and am running a 550lb front spring from Swift—a small increase from the standard front spring. If I only drove them on the road, I'd probably reduce the spring rate and have the rears revalved.
      01-20-2022, 02:43 PM   #54
Poffman
Drives: 2010 M3
My rears are not revalved for my 70/140 setup. Harold at HP Autosport here on the forums was super helpful getting me sorted as always.
      01-20-2022, 09:19 PM   #55
Anonymoose
Anonymoose's Avatar
541
Drives: BMW M2C
I'm running ohlins with 3DM RoadSport spring set using Swift springs: Front: 70 N/mm - Rear 160 N/mm:
revalve to RoadSport specs:
M1500Z423.00
      01-21-2022, 10:13 PM   #56
HP Autosport
Drives: F80 M3
That is too drastic of a difference between the front and the rear. With a 70 front you should be at 140 or 160 rear. 80 front and 160 rear is another popular combo. No need to revalve with the above mentioned rates.
PM, email or call us if you have any other questions.
Poffman493.00
      02-17-2022, 02:37 AM   #57
bmwv
Drives: 325i Manual, M2 LBB DCT
2017 BMW M2  [0.00]
2006 BMW 325i  [0.00]
How is the nvh with 70/140 compared to stock?
Poffman493.00
      02-17-2022, 11:39 AM   #58
HP Autosport
Drives: F80 M3
At the rate the vehicle will likely feel more compliant than stock. Reduced impact harshness from freeway expansion joints and small sharp bumps.
Poffman493.00
      02-17-2022, 05:24 PM   #59
Poffman
Drives: 2010 M3
Super happy with it. I drove my m2 from WA to CO, all around CO, and back to WA. 4000 miles in 8 days. It was great and I would have been worse off with my stock suspension.
      02-17-2022, 08:21 PM   #60
bmwv
2017 BMW M2  [0.00]
There were some people complaining about noise and had to replace some bushings i think. Are all these issues resolved now?
      02-17-2022, 10:51 PM   #61
Poffman
Drives: 2010 M3
I haven't had any issues. I have about 12k miles on them and pretty much no complaints. Around town at slow speeds it gets unsettled on bad roads but it's a lowered m2 on coilovers. The swaybars caused some of that before the coilovers were on.
      02-24-2022, 02:29 PM   #62
GrandMasterKhan
GrandMasterKhan's Avatar
Drives: Evo9, '22 X3Mc, Turbo S2000
Location: BMW Southpoint, Durham NC. Dinan/Carbahn authorized Dealer.
Is anyone running the Ohlins with front and rear Aero? Id love to hear your feedback.
      02-24-2022, 02:45 PM   #63
HP Autosport
Drives: F80 M3
That was a few years ago with one batch of kits. All resolved.
Poffman493.00
      07-28-2023, 09:35 AM   #64
jayk12
Drives: bmw m2 comp
Nice thread to read. I have R&T on mine with 90/190 springs. When the road is perfectly flat its so nice to drive, but in UK the roads are terrible, contant bumps, dips, undulations. I tried softening it up but you get a horrible bounce over undulations, if i stiffen it up then i loose that bounce but the ride in general is very firm.
So it sounds like you guys have resolved this by going 70/140 or 80/160. Is 90 classed as too firm on the front, is it both front and rear that are too stiff? I did think of dropping the spring rate down to 160 on the rear.
I am going to try my buddies M2C with M Performance coilovers tonight so it will be interesting to see what they are like. I want to track my car 4 times a year but prefer the compromise on the track not the road.
Cheers.
Bee Pee1779.00
      08-08-2023, 12:16 PM   #65
swagon
swagon's Avatar
Drives: F80 6MT
Cheers.
Next week, I am having 80/160 installed, going from 90/190. Standard setup was way too stiff at low speeds on my F80.
I'll report back...
      08-09-2023, 07:48 AM   #66
jayk12
Drives: bmw m2 comp
I'll report back...
Hi, I have switched to M Performance coilovers now. There rough road ride quality is fantastic, its nice than my Macan which has PASM. I have stiffened them up a bit so will see tomorrow how it feels a bit stiffer. Ohlins for me was just too stiff, on good roads it did feel mega though.
