M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Brake Reservoir Ran Dry, DSC Fault Code
      01-09-2024, 01:48 AM   #1
boba7523
Drives: m2c
Hi guys,
I was doing brake fluid flush and accidentally left the reservoir dry. I've filled it up and connected to ISTA+ to do the ABS bleed, but it detected the below fault codes. I was able to continue with ABS bleed procedure with success.
I did have a Ctek MXS 5.0 charge the car battery while doing this. Not sure if this could've contributed?
Does anyone know if the DSC and Low Brake Fluid fault codes will clear up after I start the car and do a test drive?
