M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 6MT fluid change
      02-16-2022, 07:14 AM   #67
M Fifty
844
Drives: M2 & 330CI
Originally Posted by vrooooom View Post
I'm on the Redline and my shifts from 1st > 2nd > 3rd when really working it hard is not very smooth (lack of word to describe). Shifting quick seems to struggle but if not in a hurry (gentler), no issues. Never had issues going to 1st from neutral.
"Notchy" or "Baulky" are common choices.
It basically feels like the clutch isn't disengaging properly.
Edit: Oh, and "recalcitrant"
      02-16-2022, 08:05 AM   #68
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Drives: 2018 BMW M2 LCI
Thanks M fifty. Ha3. I had to do a dictionary search for them. Bang-on!
      02-16-2022, 04:26 PM   #69
David.m
Drives: M2 LCI 6MT BSM
Mine shifts fine & the same whether going hard or just normal (have an Auto Solutions SSK)
      02-16-2022, 04:30 PM   #70
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by F87source View Post
Interesting. But to me this sounds like a clutch delay valve issue not a fluid issue.
whoops meant to say clutch delay valve
      02-16-2022, 06:48 PM   #71
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
I’ve taken mine out a while back.
      02-16-2022, 06:50 PM   #72
F87source
F87source's Avatar
Drives: Bmw M2
Hmm interesting, I am not sure then.
      10-03-2022, 01:02 PM   #73
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
Originally Posted by sharpmoney View Post
would redline DCTF have warranty implications? being that i'm on my second gearbox....and the first one went bad for no reason (i did NOT abuse the car or track it, 8k miles in LA traffic).
I would think it does, because bmw specifies MTF lt5 (as the only suitable replacement, unlike oil where you have a choice if it's LL01 approved. Dctf is also suitable for MTF lt5 applications as per redline but it's not bmw approved. I actually haven't been able to find a bmw approved MTF through ista either so I don't think bmw wants you using anything except MTF lt5, even the pentosin equivalent isn't approved and bmw MTF is a rebranded pentosin fluid.
MTF-LT-5 is backordered at FCP Euro and also out of stock at my BMW dealer's nearest two stores (was told 3 weeks to order from Germany). I ended up ordering some Pentosin FFL-3 from FCP Euro where it shows as a "ZF-approved alternative fluid" for MTF-LT-5.
Has anyone seen anything formal from BMW finally approving FFL-3 as suitable for the manual transmission in the M2C?
      10-03-2022, 03:10 PM   #74
F87source
F87source's Avatar
Drives: Bmw M2
I think Pentosin FFL 3 is acceptable, I have heard people use that before. Although I would have upgraded to another fluid like redline dctf.
      10-04-2022, 07:19 PM   #75
Daytona_550
I may use Redline next time around but, for now, still under warranty and trying to stay as close as possible to "OE" fluids.
Fwiw… I asked FCP Euro if they had any documentation of BMWs approval and this was their response:
"I'm happy to help! I took a look into this for you and I was not able to find any information or documentation regarding the fluid being approved by BMW."
      10-19-2022, 08:29 AM   #76
rbahr
rbahr's Avatar
35
Drives: To many & not enough
My $0.02: If you track your car, I would change regularly - say every year - cheap insurance. Otherwise several years, certainly not 'never'.
I have mostly changed my mind on RedLine products other than their engine oil - no data to back this up...
Ray
      10-19-2022, 05:22 PM   #77
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
F87source7251.50
      10-19-2022, 05:38 PM   #78
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by fleetfoot View Post
I'm the opposite, I prefer other engine oils to redline, but I like the transmission fluid.
      10-19-2022, 10:02 PM   #79
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
I'm just going by what's recommended by F87source. . If it's good enough for his car, it's good enough for mine.
Mosfry48.00
      10-19-2022, 10:18 PM   #80
rbahr
rbahr's Avatar
35
My experience with transmissions is that the factory fill is often the best. Found this to be true in Porsche and Subaru!
It is funny how oils become almost a religious topic!
I usually trust the opinions at BITOG... Smart people, in general.
Ray
chris7197334.00
      10-25-2022, 07:37 PM   #81
AlpsRider
AlpsRider's Avatar
2865
My car is 4 years old and has 24k miles on it. I took it in for the last warranty check and had them change the transmission oil. It shifts smoother now. I don't think it's placebo.
F87source7251.50
chris7197334.00
      10-25-2022, 08:22 PM   #82
F87source
F87source's Avatar
Drives: Bmw M2
I don't either, I think it's legit that clean fluid makes a difference. My M2 noticeably engaged 1-2 shifts much smoother after new fluid.
chris7197334.00
      10-25-2022, 08:35 PM   #83
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Did you do your rear differential fluid as well?
      10-25-2022, 10:31 PM   #84
chris719
Drives: '08 M Roadster
I changed my Mazda 3 to Redline and I’m not sure if I felt a difference or not. Honestly, it’s a really smooth shifter anyway and it’s only improved with time. I am eager to try this on my M2C once I get more miles.
      10-26-2022, 12:51 PM   #85
AlpsRider
AlpsRider's Avatar
2865
Not yet, I plan on changing it around 30k since it was changed at the break-in service already. It will probably be another year at my current mileage rate. Then i think I'll change them every 30k or so depending on the time-line. I think lifetime fill of any oil is crazy.
      10-31-2022, 01:13 PM   #86
tenkies
Drives: 2017 M2 LBB 6MT
I just changed the Tranny fluid to Redline with 17K miles on the odometer and I didn't think it would make a difference, but it feels so much better. I did also upgrade the transmission bushing to rouge as well so that could be part of it. Shifting into 1 and 2 feels a lot smoother.
F87source7251.50
chris7197334.00
      11-01-2022, 09:55 PM   #87
F87source
F87source's Avatar
Drives: Bmw M2
I'm likely going to do transmission fluid next year or the year after, so I can't wait to finally get some redline dctf in the car.
      11-05-2022, 07:41 AM   #88
KHAP13
Looks like genuine BMW MTF-LT-5 is back in stock at FCP Euro, Bimmerworld etc… p/n 83222239654
