BMW M2 Forum > BMW M2 Discussions > readiness monitors (not resetting)
      08-28-2021, 12:53 PM   #1
Brad DeMotte
Drives: '91 Porsche 964 C4, '17 M2
Hi all,
Am new to this group, as I just bought a '17 M2 after owning an E46 M3 for 10 years & an E36 M3 for 10 years before that. I'm having a problem passing emissions & would welcome any advice......
The car was modded by the previous owner with BM3 software & a Fabspeed downpipe (with cat). I had the dealer flash the software back to stock, & from what I've read on this forum (& told by Fabspeed) I "should" be able to pass emissions. Since flashing back to a stock tune I've put 1200 miles on the car, but 3 of the readiness monitors STILL haven't reset...being the O2 sensor, the O2 heated sensor & the cat.
My mechanic seems to think it's a software issue, as the monitors should've reset by now. I'd like to think I won't have to find & install a stock downpipe just to pass, but even that may not solve the readiness monitors not resetting.
Any suggestions would be appreciated.....
Thanks,
Brad
      09-13-2021, 06:00 PM   #2
cleveland797
Drives: 16 M2
I am having the same issue. Just flashed back to stock tune and nothing is resetting. I flashed back to stock leaving the DME unlocked, could that be the cause?
      09-13-2021, 07:36 PM   #3
Zeese
a coffee drinker
Zeese's Avatar
Drives: 2017 BMW M2 6MT (LBB)
The BM3 flash used, running rich? Lots of burbles? Might need to replace the O2 sensors.
      09-14-2021, 01:12 PM   #4
cleveland797
Drives: 16 M2
I'm trying to get the car back to stock for emissons. Car runs perfect with both Stg 2 91 oct BM3 tune and the stock tune. I drove around yesterday burning a 1/4 tank of fuel and non of my readiness monitors reset...
      09-14-2021, 01:23 PM   #5
bmxcamel
bmxcamel's Avatar
Drives: F87 LCI, G01 m40i, E90 M3
How are you checking readiness monitors?
      09-14-2021, 03:49 PM   #6
cleveland797
Drives: 16 M2
Innova 3020rs OBD scanner with I/M monitor
      09-14-2021, 05:05 PM   #7
Zeese
a coffee drinker
Zeese's Avatar
None? Odd.
Regarding the O2 sensors, a bad sensor may not trigger a CEL or throw a code. If the air/fuel mixture is too lean or too rich, the readiness monitors will not be reset. If the air/fuel mixture is too rich, the O2 sensors may be fouled or contaminated preventing proper and rapid adjustments (air vs. fuel).
There is probably a link in this forum to the recommended BMW OBD-II drive cycle procedure? Search here, or in the series of tubes, using these terms: BMW drive cycle smog, or similar.
Keep us updated!
Good luck!
      02-13-2023, 09:47 PM   #8
M2CPhilly
Drives: 2020 HS M2C
Originally Posted by Brad DeMotte View Post
Hi all,
Thanks,
Brad
Did you get this issue resolved? I’m having a similar issue
