08-27-2020, 05:33 PM | #67 |
Rep 1,336
Do you know what the approximate minimum camber you could get with these v.plates. On mine 20mm lowered the minimum I could get is 2.4*.
08-27-2020, 05:35 PM | #68 | |
Rep 160
Drives: 17 M2, 23 Ford F150 Raptor
Current: 2017 Alpine White M2 DCT, 2023 Ford F-150 Raptor
Past: 2015 Lexus IS 250, 2014 Volkswagen CC R-Line |
09-08-2020, 11:16 PM | #69 | |
Rep 69
ZM22819.50 |
09-09-2020, 12:51 AM | #70 | |
Rep 3,699
I always have the shop take care of it, as that’s the only way to get it dialed in correctly. |
KHAP1364.00 |
03-05-2022, 09:27 PM | #73 |
Rep 160
When I had my Ohlins Road and Track coilovers installed. I also did get some arms from SPL Parts installed with them too though.
06-05-2022, 07:53 AM | #74 |
Rep 8,629
Had anyone been able to get rear alignment somehow in check to prevent tbat rear end side to side sway / flex on acceleration? Sometimes it feels like the car wheels aren't entirely connected to the body.
06-12-2022, 05:48 PM | #76 | ||
Rep 82
09-28-2022, 03:37 PM | #80 |
Rep 155
09-28-2022, 05:30 PM | #81 |
Rep 1,341
09-29-2022, 03:50 PM | #82 |
Rep 71
Front: -3.2° camber and 0 toe
Rear: -2.1° camber and 3/32 toe (Ohlins R+T, Vorshlag Camber Plates)
Ohlins RT/SPL/Millway
Paragon/Pagid BMC/Active EL/Remus Race BBS e88/513m IG: @aatlas_M2C |
09-18-2023, 04:11 AM | #83 | |
Rep 12
Considering going down the same route, to avoid any NVH increase and also give any future owner an improved OEM setup… |
09-18-2023, 04:16 AM | #84 | |
Rep 4,521
Yes my car is my DD. Tyre wear is fine as toe-in angles are low up front. Good option - it’s main reason I went for camber correction hubs and will do it again on my next BMW….Pretty much all the chassis upgrades I’ve done have been oem/oem+ so it’s a warranty friendly / fit and forget approach
Current '22 X3M LCI.. |
WoodyOGM21.50 |
