02-27-2023, 12:40 PM | #1 |
Rep 12
M2 6MT Notchy Shifts
Given this is my first manual trans car, I didn't really know what to look for when starting out a couple of weeks back, but as I've gotten more comfortable with the car, I've started to notice some issues. Shifting gears (specifically, 3-2 and 1-2) feels incredibly notchy. I'm not slam shifting, my foot is down all the way, and I have rev match in Sport+ (90% of my driving). I never WOT in 1st, and I always wait 10-15 minutes for the car to warm up before shifting faster and higher in the rev range. Highly doubt this is only a user error.
Reading a ton of posts certainly didn't help and I convinced myself I was having synchro failure. I had a friend who's experienced with manuals take it for a test drive and he said it was totally fine. Nevertheless, I still want to do something about this since it's a somewhat new car with under 30k miles. I feel like this shouldn't be happening. I'm interested in changing the transmission fluid with Redline DCTF (1.6L IIRC). I'm also considering doing the diff fluid with Redline 75W140 (not certain how much to use). Can anyone who's made this change tell me how it affected your car? I looked into the CDV delete + AA SSK but that doesn't really seem like it would fix the root problem here. edit: realized I put this in the S55 section, sorry. Last edited by SS687; 02-27-2023 at 11:09 PM.. Reason: wrong forum |
02-27-2023, 12:53 PM | #2 |
Rep 838
Is it possible the previous owner installed a ssk already? Also would you describe the shift action as resistant as opposed to notchy? Some indications of failed synchros would be resistance between gates as well as crunching and grinding.
02-27-2023, 01:08 PM | #3 |
your average JAMF
3157
Rep 4,101
Your friend is probably right when he says it's totally fine.
'21 M2 Comp
'19 Golf R |
02-27-2023, 01:41 PM | #4 | |
Rep 12
3-2 can sometimes feel 'crunchy' where there's three or four of these clicks but still easy to get into gear and no noise unless I have the windows up and no music playing. There's no grinding sound from the transmission, only a grinding/notchy sensation when moving the shift knob into gear. I've also found that 1-2 is smooth when shifting in the 3-4k range and giving it an extra .5 seconds to let the synchros catch up. |
02-27-2023, 01:48 PM | #5 |
Rep 31
Drives: M2Comp6MT, B9 S4
No matter what, 1st to 2nd is never going to feel like butter. Due to gear ratio etc. I noticed the same 2-3rd (clunk) your talking about and I just got used to it over time but there’s nothing wrong with it. If you wanted to smooth that out you could do a ssk but I don’t really think it’s worth it.
chris7197353.00 |
02-27-2023, 02:11 PM | #6 |
Rep 500
Drives: 2018 M2 6MT
A transmission fluid change, even as early as 30K miles, can make a noticeable difference. Read up on this thread for more:
https://f87.bimmerpost.com/forums/sh....php?t=1982976 |
F87source7302.00 |
02-27-2023, 02:30 PM | #7 | |
Rep 7,310
02-27-2023, 03:13 PM | #8 |
Rep 838
I'm thinking a fluid change at the very least should help. If you want to take it a step further then the Rogue Engineering transmission mounts may help even further.
These transmissions tend to move around a bit so the transmission mounts should help to mitigate some movement. They're cheap enough (about $60) and easy to do. |
F87source7302.00 |
02-27-2023, 05:13 PM | #9 |
Rep 7,466
+1 to the comments above.
Transmission fluid make a major improvement, even at 8,000km doing new stock fluid made a world of a difference. Like it was unreal how much better the car shifted. I have also heard nothing but good things about redline dctf so give it a try! Transmission mounts will help too, and if your gears aren't grinding you should be ok. In regards to diff oil only use the stock fluids, these diffs are sensitive to fluids so don't risk it, I would try to get MSP/A but likely you won't be able to find it unless you're in Europe or Australia, so get Saf-xj (NOT saf-xj + fm).
chris7197353.00 |
02-28-2023, 05:28 PM | #10 | |
Rep 12
02-28-2023, 10:54 PM | #12 | |
Rep 7,466
How I can describe it is: Knotchy is kind of a resistance, then a clunk/pop into gear. Crunchy is something entirely different, it feels hard to pull in all the way through the gate and when it finally engages it feels like there is a gritty sand/"potato chip crunch". That is not a good sign because your synchros are getting ground up.
chris7197353.00 |
03-01-2023, 04:13 PM | #13 | |
Rep 12
In second gear -> revving up ~5k -> moving the shifter forward and left (into neutral position) taking around 1 second -> pushing up into third with literally two fingers on the shifter -> third pops in easily but feels like there's some sand when it finally settles into gear. 3-4 will feel similar as well, almost like there's some sand, and about 2-3 clicks or notches when pushing it into gear. Something I have noticed is all of my shifts are noticeably smoother on the downshifts (with Sport+ rev match). Oil arrived today, hoping to do it this weekend. |
03-01-2023, 04:21 PM | #14 | |
Rep 7,466
Yeah that doesn't sound very good, that gritty sandy feeling might (but not guaranteed) be mechanical and that is never good. When was the last time you did fluid? But overall I would say try the fluid first and hopefully it helps alleviate these symptoms.
03-01-2023, 04:51 PM | #15 | |
Rep 12
03-01-2023, 05:10 PM | #16 | |
Rep 7,466
I would also change the coolant as well if I were you, and I would look over the service report to ensure the diff fluid was replaced with the correct type (dealers are known for botching this) and within the last 4-5 years (as recommended by bmw - well bmw recommends 5 years like 80-100k km iirc but I always do it every 4 years or 40,000 - 50,000 km because bmw always over schedules their service intervals), because most of the time these cars will only ever have 1 diff oil flush and that is the one during break in servicing (2,000 km service).
03-01-2023, 05:55 PM | #17 | |
Rep 12
03-01-2023, 05:56 PM | #18 | |
Rep 74
In my case, stepping on the clutch, moving the shifter and releasing the clutch pedal was in one motion. Rev match is rarely activated.
03-01-2023, 06:02 PM | #19 |
Rep 7,466
Sounds good
03-02-2023, 06:00 AM | #20 |
Rep 2,091
Maybe double check the plastic shifter bushing as well, could have some dirt in it or something
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
03-02-2023, 06:03 AM | #21 | |
Rep 7,466
If the fluid fails, it's time to check the bushings and shifter assembly itself. Especially if the shifter feels sticky.
03-02-2023, 09:45 AM | #22 | |
Rep 12
