04-23-2019, 04:34 PM | #287 |
Rep 28
Contrary to what Eibach say, I would be inclined to trim the bump stops when fitting these springs. The car will be running close to them at the lowered ride height which means effective spring rate will ramp up significantly when it hits them, making the damper seem less effective.
For the M Performance Coilovers no bolts need replacing; leave all the top mount bolts in place and drop the damper itself by just undoing the centre nut (have a jack under the hub to lower it down. No messing with spring compressors either). |
06-02-2019, 07:57 AM | #288 | ||
Rep 23
06-05-2019, 04:01 PM | #289 |
Rep 23
Should I be concerned with running through front struts when just doing lowering springs or the Dinan suspension? Feedback here would be helpful.
06-28-2019, 11:55 AM | #290 |
Rep 245
Drives: F10 M5, E36 M3
After reading the entire thread, still to make up my mind. Hopefully more feedback rolls in from you guys with after more miles on them.
06-28-2019, 12:05 PM | #291 | |
Rep 3,007
If you wanting to keep or improve the handling do the BMW M Performance coilovers. On my M2C it has made the ride more compliant--less jarring than my M2--and the car is dead flat on turns. |
06-28-2019, 12:42 PM | #292 | |
Rep 245
If I don't do eibach springs , my top coilover considerations are KW V3(had on my last car) or M performance coilovers(which are developed by KW right?) . Thanks for the input, nice to hear the MP coils are a good candidate! |
08-17-2019, 10:41 PM | #293 | |
Rep 2,448
10-05-2020, 06:30 PM | #296 |
Rep 27
I run Eibachs with different bumpstops front and rear.
The fronts are about 1" shorter and the rear is about 0.5" shorter. Car rides much much better with it. The front is what comes on the Dinan kit. The rears I figured our through trial and error. So good I had to share. Front Bmw f10 M5 Front Bump stop 31-33-7-847-472 Rear Bmw e63 650CI Sport Rear Bump Stop 33-53-6-762-722 |
10-17-2020, 08:28 PM | #297 | |
Save the manuals!
6026
Rep 6,753
On the E9X M3, the Dinan "proprietary" ride handling kit sold with their lowering system simply used E36 M3 front bump stops, and 8mm shaved OEM front top hats with a nice mark up lol. Glad to hear the bump stops are OE again and can be readily sourced!
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-25-2020, 11:57 AM | #298 |
OOOO another former Audi B5 S4 owner OOOO
196
Rep 625
lugs?
I'm going to order some of these springs for my 2017...... if I get 10mm spacers too, will I need new (longer) lugs? TIA
S4. S4. 335i. 435i GC. M2.... all gone. I'm now in my manual 997 Carrera S!
01-28-2021, 05:54 PM | #299 | |
Rep 26
Sadly those part numbers are not what the M2 DINAN HAS kit uses. I will be installing the eibach Pro Kit with "DINAN" specified shorter bump stops on my M2C soon (when wife, kid, work and time allows ). If you download DINAN's installation instruction from their website you will find the Front bump stop part number right there (it is really a BMW OEM bump stop, just shorter). For the Rear bump stop the installation instruction doesn't gives the part number, but tells you the last 6 numbers of it so you don't get them mixed up. Long story short, I was able to get a picture of the rear bump stop and got the correct part number from there. Here they are, and hopefully it will benefit someone else. Front: 33-53-6-784-122 Rear: 31-33-6-776-144 **Disclaimer: I know that eibach claims that shorter bumpstops are not needed for their kit but... Im just using available products to make my own setup and have fun |
01-29-2021, 01:37 PM | #300 | ||
Rep 166
I will follow the recommendation. Maybe we could meet up some time. Saludos |
02-05-2021, 09:03 PM | #301 |
Rep 26
04-18-2021, 11:23 AM | #302 | |
Rep 212
I also have an Eibach pro kit since a few weeks on my M2 and I have no "jumpy" issues but I understand your problem. Actually Eibach's engineers are the ones to blame imho opinion cos i can't understand that they seem to ignore the importance of bump stops. I will try to explain: When the car is on its wheels, the stock gap between bump stop and front damper is about 15mm to 16mm and at the rear 20mm so if the suspension drops 25mm at the front you have the bump stops already pressed in by at least 10 mm and just not/well touching at the rear with a drop of 20mm...and that can never be good, if you think logically! So what did I do...I shortened the bumpstops by 15mm at the front and 10mm at the rear (Both at the top NOT at the bottom!). That means I have now 5mm bump stop clearance at the front and 10mm at the rear. Less then stock but better a bit less then 10mm negative or zero clearance. Result: It feels exactly the same as OEM, I really don't notice any difference, so definitely not bumpy or jumpy and maybe even a fraction less stiff then OEM but that can be subjective. My personal conclusion: I really don't understand Eibach regarding this matter because a 10mm compressed bump stop at rest can never improve the suspension characteristics with the stock dampers... Yes, maybe there could be somewhat improvement at low speeds but that is only a part of the story, because at high speeds it's a totally different story, espacially on poor roads. In any case my advice to all: Make sure the bump stops have somewhat travel freedom with this Eibach springs otherwise it could be go wrong in some drive situations, especially at high speeds or spirited driving on poorer roads...just my two cents....
F87 M2 LCI
EX: e92 335d: 350hp@4400rpm and 698NM/521 ft lb@2760 rpm. Last edited by JMM; 04-20-2021 at 09:54 AM.. |
ddnmkun153.50 Moose_Michaels0.00 |
04-22-2021, 10:16 AM | #303 | |
Rep 209
04-23-2021, 04:00 AM | #304 |
Rep 212
I could have cut off a bit more but I guess this is the best compromise because it could be that your piston rod reaches the end of its travel on hard compression by shortening the bump stops too much, and you don't want that.
Yesterday I didn't pay attention and I hit a speed bump so hard that my both tyres hit the inner mudguards at the front top. I estimate it was a compression of easily 10cm when i later saw where the point of contact was. I was pretty pissed off at myself but on the other hand, I am now pretty sure that the piston rod will not reach his end during hard compression.
F87 M2 LCI
EX: e92 335d: 350hp@4400rpm and 698NM/521 ft lb@2760 rpm. Last edited by JMM; 04-23-2021 at 08:56 AM.. |
04-28-2021, 03:07 PM | #305 |
Rep 44
I just installed the pro-kit last night and so far I'm really happy with the ride and am not experiencing any rubbing. The larger bumps in the road are a tad harsher, but overall the ride quality is similar to stock. However, I did notice that I get less wallowing in the rear(bounciness) on high speed corners, ie highway on ramp, with the new springs.
I originally bought the 6-series bump stops as someone recommended earlier in this thread, however, because I went with wider tires, I opted to not trim the stock stops or use the new shorter ones as I was afraid of rubbing. The tire/wheel combo I'm running is: Front: 19x9.5" ET28 with 265/30-19 tires Rear: 19x10.5" ET45 with 295/30-19 tires |
Sundinisagod107.00 |
05-07-2021, 11:10 AM | #306 |
Rep 63
15k miles so far. Wish the rear sat a little lower but otherwise no complaints.
20' HS M2C | 6MT
leopard print1569.50 |
01-03-2022, 03:12 PM | #307 |
Rep 613
Drives: F87 M2 CS
Reviving this thread to ask couple of questions about the Eibach Pro-Kit.
I just purchased a 2020 M2C, which previously belonged to another forum member. The car has Vorshlag camber plates and Swift springs installed. While it looks and handles amazingly well, it's a bit too slammed for me. Currently, there is absolutely no gap between tire and fender in front or rear. I measured the distance from the bottom of the wheel lip to bottom of fender edge and it's at 590mm (front) and 595mm (rear). I'm looking to raise the car ~10mm, to roughly 600mm (front) and 605mm (rear). If my eyeballs don't deceive me, this should equate to ~1 finger gap in front and 1-2 finger gap in the rear. From all the pictures I've sen, it appears that this is pretty much exactly what the Eibach Springs will provide. Out of curiosity, does anyone know the measurement from the bottom of your 19" wheel lip to bottom of fender edge, front and rear? Also, would you say you have about a 1 finger gap front and maybe slightly more than 1 finger gap in rear?
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
01-08-2022, 10:25 AM | #308 | |
Rep 1,126
