M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Protool - A mobile ESYS and The best BMW coding and diagnostics app available
      04-25-2023, 02:59 PM   #23
thebadboy
Drives: 335i f30
Hello, is this application comparable to ISTA? can it erase the fault codes of all the fault codes of each module and can it be used for maintenance procedures (example: replacement of dkg DTC gearbox oil). THANKS
      04-25-2023, 03:18 PM   #24
F87source
F87source's Avatar
Drives: Bmw M2
No it doesn't have all of the ISTA functions. However I believe it can erase those codes without issue. You can email bimmergeeks (maker of protool) to confirm this.
      04-25-2023, 06:30 PM   #25
F87source
F87source's Avatar
Drives: Bmw M2
I just wanted to let you guys know I just recieved my BM3 wifi adapter in today and tested it with protool, and it works perfectly! So if you were looking to buy a wifi adapter I would highly recommend the BM3 wifi version over the currently available models (review coming soon which will explain exactly why).
Smiler1.50
      04-26-2023, 03:16 PM   #26
thebadboy
Drives: 335i f30
do you know if we know how to modify the coding to avoid the cold start as well as to remove the burbules? is it possible to put the application in French?
      04-26-2023, 04:12 PM   #27
F87source
F87source's Avatar
Drives: Bmw M2
That's a tuning feature, so protool won't be able to do those things. You'd need something like bootmod3.
I'm not sure if it supports french, you could download the app and play around with it if you'd like, it's free to do so. You only pay when you need to code.
      04-26-2023, 04:33 PM   #28
thebadboy
Drives: 335i f30
ok thanks for the info. In my opinion I will just take the license for diagnosis because I already have BIMMERCODE, but I must be sure that PROTOOL can erase all the fault codes (DME and others) before buying it.
      04-26-2023, 04:36 PM   #29
F87source
F87source's Avatar
Drives: Bmw M2
No problem.
      04-26-2023, 04:39 PM   #30
thebadboy
Drives: 335i f30
do you have the information for the fault codes? I emailed them but got no response.
      04-26-2023, 05:01 PM   #31
F87source
F87source's Avatar
Drives: Bmw M2
It'll take them a bit to reply. What do you mean information for the family codes? I don't understand.
      04-26-2023, 05:05 PM   #32
thebadboy
Drives: 335i f30
I want to be sure that the application can erase all the fault codes of the car (like ISTA)
      04-26-2023, 05:35 PM   #33
F87source
F87source's Avatar
Drives: Bmw M2
It should be able to do that, because it'll be able to read all fault codes the car has and clear them. Fault codes will come back if there truly is an error, just like on ISTA.
      04-27-2023, 01:59 AM   #34
thebadboy
Drives: 335i f30
they answered me exactly the same as your answer. THANKS
      04-27-2023, 02:03 AM   #35
F87source
F87source's Avatar
Drives: Bmw M2
No problem
      04-27-2023, 04:35 PM   #36
Smiler
Smiler's Avatar
Drives: M2 LCI DCT
2018 Bmw M2 Lci  [10.00]
Thanks for the info. Is this version 3 of the adapter
M2 LCI DCT
      04-27-2023, 04:55 PM   #37
F87source
F87source's Avatar
Drives: Bmw M2
No problem at all, glad I could help.
Yes this is the V3 adapter (has the sleep mode), the V2A is the cheaper version without the sleep mode.
Smiler1.50
      05-02-2023, 07:37 PM   #38
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Ok-- for someone mostly coding illiterate (I've only used BimmerCode)-- what does this do that Bimmercode won't?
Specifically?
And use small, easy to understand words-- coding illiterate, remember?
Not talking smack-- honestly curious if this is something I'd use on my M2C-- I'm an Apple guy, so I'd have to pick up an old Android.
TIA--
R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600
jefe2000739.50
vrooooom325.00
      05-02-2023, 10:13 PM   #39
F87source
F87source's Avatar
Drives: Bmw M2
Specifically?
TIA--
R.
Vo (vehicle order) coding of all kinds, and coding things like ghas, eps, dsc. There also alot more that protool can do, because it can code anything esys can and that list is extremely extensive that it's impossible to list them all.
      05-03-2023, 09:18 AM   #40
flybigjet
flybigjet's Avatar
Ok, put it like this-- what would I want to use Protocol for on an M2C?
i.e. What are people coding *that can't be coded with Bimmercode* on an M2C?
TIA.
R.
      05-05-2023, 10:19 AM   #41
Altra
Drives: 2016 AW M2
Originally Posted by gphung View Post
Did you use one of the officially supported adapters? Or a different one?
Sorry for the late reply, I'm using bm3's wifi enet adapter, worked perfectly!
gphung193.50
      05-05-2023, 10:32 AM   #42
F87source
F87source's Avatar
Drives: Bmw M2
TIA.
R.
Again that's a hard question to answer because there's so many things that one would/could code - in particular with VO coding. But again things like the eps, ghas, egs, dsc etc are not available on bimmercode but available on protool.
      05-05-2023, 02:35 PM   #43
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
Ok, put it like this— what would I want to use Protool for on an M2C?
This isn’t an exhaustive list. From my understanding, you can code these sorts of things with Protool that you can’t with Bimmercode:
  • Fancy anti-dazzle headlight features that come standard with the adaptive LED headlamps in Europe, but are disallowed in the USA
  • diff and stability control settings (that cause the car to handle slip differently) from other cars like the M2CS or M4 GTS
  • power steering modes (for a different steering feel) from other BMW performance cars
  • etc.
Appreciate 4
F87source7251.50
chris7197334.00
flybigjet6822.00
vrooooom325.00
      05-05-2023, 10:07 PM   #44
chris719
Drives: '08 M Roadster
  • etc.
Just to help clarify for flybigjet, I don't think you will want to code any of that on an M2C IMO.
1. The anti-dazzle may or may not be safe to enable due to hardware differences between EU and NA hardware (many threads on it).
2. 98% sure the M2C already comes coded to F87CS for diff and DSC.
3. Steering is already set to F87CS, though it's possible you could try the F82 settings but seems like it's probably worse.
Definitely makes sense if you have an OG M2.
Appreciate 4
F87source7251.50
flybigjet6822.00
jefe2000739.50
vrooooom325.00
