M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Rennline ExactFit Magnetic Phone Mount
      08-14-2021, 02:03 AM   #45
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Drives: 2018 BMW M2 LCI
This doesn't get in the way of a manual stick?
      08-14-2021, 07:24 PM   #46
jello
jello's Avatar
Drives: LCI M2
2018 BMW M2  [8.33]
Not at all. I just installed mine today and it's way to far to hit the stick!
      08-18-2021, 10:25 PM   #47
sharpmoney
Drives: NA
Originally Posted by sharpmoney View Post
iphone 12s magnet not strong enough to hold without the steel plate?
anyone?
      08-18-2021, 11:08 PM   #48
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
i think (not sure coz visual only) the magnets on the iPhone-12s are laid-out in a bigger diameter than this holder. if they're not aligned, wouldn't really work. IMHO.
People w/ this holder and 12 can chime in better.
Rennline should adapt a version that has that functionality.... ideally. Incorporate the charger too while at it.
      08-19-2021, 09:03 AM   #49
sevenmarc
sevenmarc's Avatar
Drives: 2017 LBB f87 M2
If the ball joint is a standard Garmin-style one, you could swap out the magnetic part for a MagSafe compatible charger.. I just did something similar with a different mount using a Spigen charger in my wife's car. Worked like a charm!
      08-19-2021, 11:16 AM   #50
CoffeeLife
Coffee Every Day
CoffeeLife's Avatar
397
Drives: 2021 M2C
2021 BMW M2C  [10.00]
No because magsafe has a different layout vs the tiny magnet holder that comes with the mount.
You need to buy a magsafe specific charger or mount end to put on the Rennline.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter
-TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox
-Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter
-Remus Race + BR EL Mid
      08-20-2021, 02:24 AM   #51
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
      08-20-2021, 12:35 PM   #52
[Cyanide]
Drives: '20 X3MC / '21 M2C
I just installed this in my (BRAND NEW only 241 miles, yes it was stressful yanking on the trim piece) '21 M2 Competition, yes the top piece pops out as one whole piece, yes it's going to make a lot of not so pleasant sounds, just go slow and you'll be ok.
I replaced the stock magnet/ball combo with a MagSafe one I had laying around and it popped right on with zero modifications.
chris7197334.00
      08-28-2021, 10:02 AM   #53
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
How did you guys install it on an LCI M2? which panel(s) will need to come off?
      08-28-2021, 10:06 AM   #54
Foggins
Restless
1335
Drives: M2C
I bought the mount but am kinda freaking out at the thought of popping out that top carbon fiber trim piece...any tips on where to start prying? Are there clips all around it or only in certain areas. Thx
      08-28-2021, 10:24 PM   #55
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Which top piece needs yanking—the whole carbon trim w/ the centre vents? Did you just those plastic trim tool and jammed it between that and the softer dash material? Did you start at the bottom of the chrome strip?
Thanks.
      08-31-2021, 05:08 PM   #56
[Cyanide]
There are clips all around. It freaked me out too, as I had mentioned previously, it still had new car smell when I did it, lol
Thanks.
I used a plastic trim tool, stuck it under the left vent and popped that side out first, slowly moved the plastic trim tool over to the right, sticking my finger underneath as I went to slowly pop out the tabs. Eventually I reached the end of the right side and I had to grab the entire piece and VERY VERY SLOWLY started tugging on the tabs and it all comes out as ONE piece.
I just held the dash trim piece and I loosened the 2 allen bolts on the sides, pull the lower dash trim piece that you just loosened up towards you, slip the bracket in and reverse directions.
I've highlighted the trim piece you need to pop out. That trim piece with the 2 main vents and your CF trim is ONE PIECE.
There WILL be cables attached to the trim piece (your hazard switch and the blend switch) so be CAREFUL when you pull it towards you.
Go slow.
Foggins1334.50
      09-01-2021, 05:16 PM   #57
Foggins
Restless
1335
Drives: M2C
Go slow.
Thanks so much for the step by step! I just did mine, it worked out great. I took your advice and went slow, and there were no issues. Great bit of kit for sure.
chris7197334.00
      09-01-2021, 05:23 PM   #58
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Has anyone wired in/tried the inductive charger that fits to the Rennline mount?
Sort of considering it, but not sure what to do with/how to do the wiring.
https://www.rennline.com/Wireless-In...qtSY%3D.H89tmP
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600
      09-01-2021, 05:26 PM   #59
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Originally Posted by ChiTownM View Post
With CarPlay, as an iPhone user, I have been wondering what functions are being still used directly on the phone? This looks awesome and it seems pricy compared to Amazon products. Is this high quality?
Picking up my CS at the PDC and will have to drive 750 miles, this may do the trick.
^ This.
I use Apple CarPlay exclusively and I prefer to put my phone in the armrest charging cradle, not an option for the CS
Keeps me from playing w/the phone while driving.
      09-01-2021, 05:30 PM   #60
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
You can hack something together like this if you want...
chris7197334.00
Stylin.M2270.00
      09-01-2021, 07:15 PM   #61
chris719
Drives: '08 M Roadster
Just be aware that you can probably only get 10W from the USB ports in the car. I haven't measured it, but I would be shocked if BMW allowed you to draw more than 2.1A from the USB A ports.
Apple MagSafe will charge at 15W, but only if your source can supply it, and only then through a USB C connector without an adapter to A.
If you want the full 15W you will have to use a standalone 12V cigarette lighter to USB-C charger that can legitimately source 3A @ 5V.
      09-13-2021, 01:50 PM   #62
calspyderman
SR-71 Pilot
Drives: 2020 BMW M2CS
Originally Posted by Holmes870 View Post
Received an email blast from Rennline today, stating this new product was available.
I had this mount in my F80. I liked it so much, I immediately pulled the trigger for the M2 version.
Highly recommend for a clean, factory looking phone mount.
https://www.rennline.com/BMW-M2-Exac...nfo/PM01%2E58/
How strong is that magnet? Any issues knocking the phone or it falling off easily? Thnx.
      09-13-2021, 02:44 PM   #63
Foggins
Restless
1335
Drives: M2C
Very strong...I have used this setup many times before in different cars. They do give two magnet options for mounting on the phone/case. There is a smaller round one which holds in place pretty well, or a much larger rectangular one that is really strong. Great mod.
chris7197334.00
      09-28-2021, 07:10 PM   #64
sharpmoney
Drives: NA
anyone have a video on how to use the trim tool to remove dash on a comp model? seems much easier on the OG ones. i really dont want to f this up.
      10-11-2021, 02:03 AM   #65
sharpmoney
Drives: NA
installed today, pulled it off with just my fingers, magnet strength is
no idea how i made it 9k miles without this phone mount.
chris7197334.00
      10-11-2021, 10:33 PM   #66
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Just installed this yesterday on my og m2. Very happy with it. Sits in a very accommodating position and best of all, no more blocking a vent and/or radio knobs with vent mount solutions! Lost a clip on the vent assembly when removing but still seems very secure.
