06-23-2021, 07:56 AM | #1 |
Rep 1,591
Stumble/Stall on First Start of Day
Car is a 2016 M2 BM3 Stage 2 91oct (about 5k miles) and 60k on the car. Plugs were changed two months ago.
Starting a few weeks ago on the first start of the day I noticed the car stumble, where the revs would drop to almost 500 RPM, then catch back up. Car would run fine otherwise. This only happened on the first start of the day, every subsequent start was fine. Normal bits to check with starting are power, spark and fuel. Battery was tested and checks out fine, spark plugs are pretty new and I ran logs that I sent to BM3 to see if they saw anything and they said logs were all great. One day it actually did stall out and shut off but started right back up. That was early June, then I drove the car and ran another tank of gas through it and it seemed to be quite a bit better. Then I got gas again yesterday and had the stumble this morning. Part of me wonders if there's any truth to the summer gas that is changed over by June 1 and I think the most noticeable stumbles were after gassing up at the same Shell station (93 V power, newer station). A search of this yielded a number of results, many on the M2335 boards even with similar videos. Some people said it was sporadic, experienced it a few times then went away, a few under warranty claimed fuel pumps were replaced but that didn't seem to be the actual solution. I haven't ruled out bad gas but curious if any others experienced this, thoughts on it or recommendations of other items to check. Thanks in advance. |
06-23-2021, 09:23 AM | #2 |
Rep 3,703
How long does the car sit between morning starts? Any idea of the % ethanol content in your fuel?
I have a similar first start stumble, but I run E50 and my car might sit for a week bn starts. |
06-23-2021, 09:29 AM | #3 |
Yoda of mods
1676
Rep 3,007
Drives: X5 RWD
Probably bad gas.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
06-23-2021, 12:36 PM | #4 |
Rep 5,385
I had this EXACT thing happen on my M235 recently. The fix was simple. On a warm motor, turn the car off, open the hood, and then wait 10 minutes. After 10 minutes, disconnect the MAF sensor by the airbox and then start the car. Let it run 10 minutes and then shut it off. Reconnect the MAF.
I'm not sure why these cars do this but it seems to be a mild tuning glitch that doesn't throw a code. Like you, my battery was fine, my plugs were newer and OEM with the stock gap, and I run a quality 93 octane fuel. I'm not one to throw parts at the car like most BMW techs have done to remedy this issue. The fact that this only happens on a stone cold start and the car runs completely fine otherwise points to a tuning issue and not a hardware issue like the HPFP. |
akkando5866.00 |
06-23-2021, 12:51 PM | #5 | |
Rep 3,703
06-23-2021, 01:43 PM | #6 | ||
Rep 1,591
My hope Quote:
Thanks for all the input. |
06-23-2021, 03:05 PM | #7 |
Rep 5,385
I have no idea. I can't reset DME adaptions. I can reset throttle adaptions but everything points to this being a weird air intake/MAF issue. Un and reconnecting the MAF was my fix as well as a couple of other M235s. Given that the N55 and tuning used in OG M2 and M235 are very similar and the issues the same, I'd start with the MAF first.
It wasn't fuel with my M235 because I tried two different brands and stations with no fix. My cold starting issue lasted 6 weeks and got progressively worse to where it was happening on every cold start. I did the MAF dance and the issue instantly fixed on the next cold start. That was over 6 weeks ago now and not a single issue since. I do find it odd that you can disconnect the MAF on a hot N55 engine and it won't throw a code and run weird. I've never had another car be able to do that. I guess the fact that the motor relies largely on MAP is why. |
06-23-2021, 03:12 PM | #8 | |
Rep 1,591
06-24-2021, 11:42 PM | #9 |
Rep 7,470
Do you have an aftermarket intake? This sounds alot like intake related issues, when I had an aftermarket intake on my m235i it would stumble alot and have terrible idles and that was due to the intake allowing a different flow pattern or more air past the maf housing causing stubmles.
Also clean your maf sensor, that can help if it is maf related.
06-25-2021, 05:01 AM | #10 | |
Rep 1,591
06-25-2021, 12:33 PM | #11 |
Rep 7,470
Make sure you use maf cleaner and be careful, mafs are sensitive and break easily.
07-01-2021, 03:44 AM | #12 |
Rep 1,591
Update: Ran the tank down and filled up with 93 from another station and it made a noticeable improvement. Wanted to try that first and take note, but will still clean the MAF.
04-16-2023, 01:23 AM | #13 |
Rep 78
2018 F87 BMW M2
Hello, I am currently getting this issue and I need some help. I had low idles / stalls when in park and low RPMs. I did the MAF trick and it worked for a day but then the issue came back. I also recently got a CEL from “slow response” from my o2 sensor and this could be from my sensor spacers or MAF flow sensor. Any advice is appreciated. I’m thinking since it came back after doing the MAF unplug trick it could mean I need to replace the MAF sensor itself. |
