M2 Technical Topics > Cosmetic Modifications > M4 seats swapped into my M2
      09-09-2021, 01:49 PM   #67
3t3p
New Zealand
455
Yeh swap them over.
Hope you don't get popping movement with your seats, it's maddening.
I'll have to get it fixed one day by BMW.
      09-09-2021, 01:58 PM   #68
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Managed to get the install completed this week. Thanks to everyone that contributed
Have now swapped the M4 logo for the correct m2 M2 ones 👍
Kattanah137.50
      09-09-2021, 04:17 PM   #69
Poffman
Drives: 2010 M3
How did you get the badges to light up? I have yet to find any info on this just questions congrats!
      09-09-2021, 06:05 PM   #70
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
So you need to add an extra pin into the yellow connector that plugs into the bottom of the seat.
This is pin 7, you'll see a terminal in that location for the seat side but obviously not on the vehicle wiring harness.
The part for the terminal is 61130005197, crimp one of these on to a good length of wire. The wire can then be routed to follow the oem wiring harness. I did this while the seats were still out. Removed the plastic trims at the edge of the carpet, ran the wire up the edge of the car to the footwell.
Removed the lower trim panel under the dash and utilised the feed for the footwell lamp. So the footwell light has 4 wires, one earth brown or brown with a trace. Two others that are mainly white with either red or blue trace (these feed ambient light either white or the orange) and then the final wire is red or red with a trace (sorry can't remember exactly) forgot pics also. This one you can tap into for your seat illumination.
Tidy up wiring, secure in place with zip ties if needed and re fit panels. Then repeat for the other side.
So now the seat light works at the same time as the footwell light. So when a door is opened or the main full interior lights are on.
This is not quite the factory method as this would be wired into the FEM control unit.
But my method I found fairly straight forward as I could keep them separate on each side as the other way would need both wires running to one control unit.
I would recommend doing this with the battery disconnected and the seat out. Any more info give me a shout.
Kattanah137.50
Poffman493.00
      09-09-2021, 06:34 PM   #71
Poffman
Drives: 2010 M3
Wow thank you very much!! I will give this a go and report back for sure. Headed out on express rally next week so it'll have to wait til I'm home!
      09-13-2021, 09:21 AM   #72
3t3p
New Zealand
455
I did a whole driving course two days ago and was never aware of popping from the seat. Only thing different is adjusted my chair to be slightly closer to the wheel, maybe the thread in one area is damaged and has play? Moving it into thread in better condition has eliminated it?
      09-14-2021, 12:21 AM   #73
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
@StealthnShadow
Your pm inbox is full, see above for seat illumination
      09-20-2021, 09:13 AM   #74
rowey
Drives: BMW M2 OG
can you do the m4/m2c swap with no problems into an OG M2?
      09-20-2021, 12:33 PM   #75
M Fifty
844
Drives: M2 & 330CI
Yes. Just make sure you use the underseat modules from your original seats (and make sure the battery is disconnected before you unplug anything...)
      09-20-2021, 12:34 PM   #76
rowey
Drives: BMW M2 OG
Hi could really do with a few pointers from you about this swap for my OG m2
      09-20-2021, 12:35 PM   #77
rowey
Drives: BMW M2 OG
Understood. I'm desperate to do something about it asap as the standard seats are pretty crap
Also just to be certain, the m4 rear seats just need a bracket to then be fitted without any other modifications?
      09-20-2021, 12:46 PM   #78
M Fifty
844
Drives: M2 & 330CI
As I fitted M2C front seats with the blue stitching, I left the rears alone.
      09-21-2021, 01:57 AM   #79
Poffman
Drives: 2010 M3
There's a detailed post on this thread with pics - super easy
      09-21-2021, 04:44 AM   #80
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
See this thread also:
https://www.2addicts.com/forums/show...603&page=8
Has some more info about the rear
      12-07-2021, 01:16 AM   #81
bmwstephen
Drives: 95' M3, 17' M2
for you guys that are swapping these in, does it straighten out the crooked seats?
      12-14-2021, 03:45 AM   #82
3t3p
New Zealand
455
Nope. I have to admit sometimes I do notice this and get annoyed /uncomfortable, stupid BMW
      12-14-2021, 06:36 AM   #83
M Fifty
844
Drives: M2 & 330CI
Well, noting I have the 6MT, it seems more that the pedals are offset than the seat being squint.
Just be happy you didn't try retrofitting the the Carbon Fibre-shelled buckets from the current M4...
      12-14-2021, 07:37 PM   #84
Rick4345
Rick4345's Avatar
472
Drives: 2022 WRX World Rally Blue
How tough is it?
That is if you can find them.
Rick
      12-15-2021, 12:40 PM   #85
M Fifty
844
Drives: M2 & 330CI
Originally Posted by Rick4345 View Post
How tough is it?
Well, availability aside, probably no more difficult as a retrofit than seats from the M2C, it's just that the shape of the seat frame would - in conjunction with the offset pedals - make for a notably uncomfortable driving position.
      12-16-2021, 05:36 PM   #86
Poffman
Drives: 2010 M3
How tough is it?
The buttons may not work. The M2C and M4 are a stupid simple swap into OG.
      12-17-2021, 10:32 AM   #87
Rick4345
Rick4345's Avatar
472
How tough is it?
Definitely.
I have the M2C seats in.
For the price of the G series carbon seats I can do a lot of other mods!!
Rick
      01-06-2023, 10:01 PM   #88
Drifter2090
Drifter2090's Avatar
910
Drives: E90 M3 | E92 335i | E90 335d
Got my comp seats installed! Thanks for all the good info here, it made it very easy.
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
Poffman493.00
Stylin.M2270.00
