08-10-2018, 05:11 PM | #23 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Sure they are. Plenty of European cars have rear fogs in the US (from the factory), look at Mercedes and Audi.
Now, many people that use them are absolute idiots and turn them on when they aren't necessary, but there's no law that makes rear fogs illegal here.
abirmaher840.50 |
08-10-2018, 05:14 PM | #24 | |
I INDIC8
612
Rep 1,286
Any chance you could take pics of the housings - do they have DOT markings stamped on them at all?
08-11-2018, 12:59 AM | #25 | |
42
Rep 51
America is a very litigious country. This is why they also disable the DVD In Motion only in the US market. And also why they keep the color red for the rear turn signals, instead of amber. This guy below explained it best: |
08-11-2018, 04:13 AM | #26 |
I INDIC8
612
Rep 1,286
Red for rear turn signals is a cost cutting measure, plain and simple.
AndrewC198910931.00 |
09-19-2018, 03:34 PM | #28 |
16567
Rep 8,425
Yes but Red looks much cleaner regardless.
09-20-2018, 08:23 PM | #29 |
I INDIC8
612
Rep 1,286
The outside housing on the European-spec lights is still red. So it doesn't "ruin the looks."
Only time you see orange is when an indicator is lit.
09-21-2018, 12:43 PM | #30 | |
Rep 4,551
Drives: 2015 328d xDrive
Correct. With LCI tails they look identical until your indicators are on. I have them on my own car so I would know Having all the indicators orange matches much better and it has proven to be safer as well |
NYC Bimmer259.50 BoltacoreMD3.00 |
10-30-2018, 08:01 PM | #31 |
Rep 43
I coded my left rear fog light today using the following:
ECU Module Option Default New Value FEM_BODY 3060 NSL_Verbaut nicht_verbaut Verbaut REM 3063 Mapping_Nebelschlussl_L_output off nsl_l However, when I push the button to activate, I get the error "Left two-stage brake lamp malfunction." The error clears when I turn the car off and back on. Do I need to code out the Dynamic Brake Force to avoid this error? |
10-30-2018, 08:23 PM | #32 | |
Rep 4,551
NYC Bimmer259.50 |
10-31-2018, 09:57 PM | #34 | |
Rep 1,092
I thought there was actually some good reason for the manufacturers to do it. How is it cost saving when they have to produce two different part numbers instead of just one? |
11-04-2018, 05:34 PM | #35 |
I INDIC8
612
Rep 1,286
So I discovered that if you install the proper European headlight switch in a US-spec car, the FEM (front electronics module) complains (see attached PDF).
Any thoughts on how to fix? I don't want to alter the car's FA / VO to the point where a US dealership has a problem working with it... But I just had my car in for the iDrive screen (phantom touches / they replaced it) and they complained on the work order that they couldn't correctly update software on some piece due to the FEM error.
11-05-2018, 07:59 AM | #36 | |
Rep 682
If that's the case, reinstall your original switch but swap the euro button from the euro switch. It's just a plastic button so no electronics to mess things up.
11-05-2018, 10:25 AM | #37 | |
Rep 4,551
ZPrime611.50 |
11-06-2018, 02:16 AM | #38 | |
I INDIC8
612
Rep 1,286
I mean this is all really anal-retentive nit-picking at this point, but I picked up the European switch because I wanted it to function correctly like a European car. Another option might be to gut the PCB out of the US-spec switch and see if there is something swappable to make the Euro one register as US-spec... but it seems to make more sense to try to code the FEM at that point (And hope that coding doesn't cause problems for the dealership). Or like you said, just swap the switch next time I'm in for service. It isn't that hard, but I also would prefer not to have to mess with it.
XProject25.00 |
11-06-2018, 08:15 AM | #40 | |
Rep 4,551
I would assume the euro part number is the same as it was in the 2018 LCI cars (61316847520) but you would have to double check that.
iRasF8713.50 NYC Bimmer259.50 |
11-07-2018, 06:57 PM | #41 |
Rep 682
I could have swore I responded to this but maybe hit the wrong button. Anyway.....
I KNOW the button won't light because I pulled mine out and tried it. I saw the momentary contact button for the on\off on the right and what looked like a surface mounted LED in a little silicone tube on the left. The LEDish thing in the tube didn't light but it was there on my US switch assembly. I'm wondering if there's some coding in advanced (bimmercode) that would tell the car to activate that LED? It wouldn't surprise me at all. Someone just has to find it. Here's a pic I snapped with the button removed.
11-07-2018, 07:10 PM | #42 | |
Rep 4,551
NYC Bimmer259.50 |
11-07-2018, 08:06 PM | #43 | |
Rep 682
I don’t know if most would go through all of that, but this guy found himself in a pretty unique circumstance.
11-07-2018, 08:12 PM | #44 | |
Rep 4,551
IMO It would be a million times easier to just swap modules before doing any major repair work through a dealership. It's not like you're going to be doing it that often anyways and it literally takes 1 min.
NYC Bimmer259.50 |
