08-07-2017, 04:19 PM | #1 |
2919
Rep 21,727
▀▄ eas | AST Coil Overs - Authorized Dealer - Now shipping
The newest addition to the M lineup, nothing defines the BMW legacy more than the M2 Coupe. This latest M harks back to the original E30 M3 and the even earlier 2002 tii models from the 1970s. With this legacy in mind we are excited to announce that the full line of AST 5000 series systems for M2 is available from AST. AST's inverted design allows for wide wheel and tire clearance without the need for wheel spacers and adapters. Our kit is a favorite among BMW M owners who incorporate aggressive wheels, tires, and low front splitters. The inverted technology produces an extremely strong damper, providing better suspension geometry under heavy lateral and braking loads in either a spirited road or track environment. Using a 45mm inverted piston design increases damper strength in all directions, optimizing cornering and braking forces under high-stress conditions. Proven during countless competitions around the world, our design provides an ultra-strong strut with low frictional resistance. PM today for fitment info and pricing AST 1-Way 5100 Series shock absorbers The 5100 Series shock absorbers utilise inverted / upside down technology. The inverted design is race proven technology and produces an extremley strong damper, providing better suspension geometry under heavy lateral and braking loads as seen in a road and track environment. The 5100 Series shock absorbers give your car a better performance than the standard twin tube design. With the 5100 Series suspension you can adjust rebound with one knob. The adjust platform allows you to adjust the ride height of your car. AST suspension shock bodies are specially designed to keep maximum stroke, even with a lower ride height. Features: High-end, track ready suspension that is totally streetable Rebound Adjustable (“Singles”), without reservoir 44.5mm diameter shaft struts, Inverted New low friction seal on all AST dampers Rubber bushings for “eye” shock mounts Optional Spherical lower “eye” shock mounts Optional spherical upper shock mount assemblies Optional DLC Coated shafts Optional DDP piston (double digressive) AST 2-Way 5200 The 5200 Series are 2-way adjustable shock absorbers which are based upon competition 3-way adjustable shock absorbers. The 5200 shock absorbers are adjustable in compression and rebound. The design of the compression adjuster is an evolution of the compression adjuster we provided for the American Grand-Am series for the last few years. The 5200 shock absorbers were designed to achieve a quick and easy set up, allowing separate adjustment of compression and rebound. In the 5200 Series AST uses an external canister. Throughout testing and competitions, the 5200 has been praised for its performance and capabilities, surpassing other major, more expensive brands and setting a new standard of 2 way damper. Its no surprise that the 5200 is fast becoming a favorite damper amongst race teams and track day enthusiasts world wide. Features: - High end, track ready suspension that is totally streetable - Fully upgradeable to 5300 spec - Rebound and Compression Adjustable (‘Doubles’), with a remote reservoir - Remote reservoirs allow additional travel and heat dissipation - 44.5mm diameter shaft struts, Inverted - New low friction seal on all AST dampers - Spherical lower ‘’eye’’ shock mounts - Reservoir with hose or piggyback - Spherical upper shock mount assemblies - Synthetic hydraulic fluid - Optional DLC Coated shafts - Optional DDP piston (double digressive) AST 3-Way 5300 For the best performance on the track, AST Suspension designed the Competition 3-way adjustable series. The 5300 Series shock absorbers are rebound adjustable in 12 positions on the strut. The highspeed compression is adjustable in 12 positions and the lowspeed compression is adjustable in 14 positions. Both compression adjustments are made using an external canister. All adjusters work completely independent. Many years of technical knowledge, testing and experience has been refined, fettled and brought together to create a perfect balance between the choice of springs and the corresponding damping characteristics. This makes it a versatile product for every customer. The 5300 series shock absorbers are the best solution for every race team. Once installed the shock absorbers are easy to setup, highly reliable and require low maintenance during the season because of the high grade of materials used. All of this together makes the 5300 series shock absorbers a championship winning damper, over and over again. The AST 5300 Suspension is worldwide renowned for its performance at every level. Features: - High end, track ready suspension - Rebound, Low & Hi Speed Compression Adjustable (‘Triples’), with a remote reservoir - Remote reservoirs allow additional travel and heat dissipation - 44.5mm diameter shaft struts, Inverted - New low friction seal on all AST dampers - Spherical lower ‘’eye’’ shock mounts - Reservoir with hose or piggyback - Spherical upper shock mount assemblies - Synthetic hydraulic fluid - Optional DLC Coated shafts - Optional DDP piston (double digressive). Models Supported 2016 BMW M2 Ordering: Phone: You can reach us directly by calling 866.669.0705 x31 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM to 2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-23-2017, 11:45 AM | #2 |
2919
Rep 21,727
AST 5100 series
In Stock and ready to ship PM today to get yours
12-28-2018, 02:02 PM | #3 |
2919
Rep 21,727
Hurry time is running out on AST winter sale
PM for details and pricing
03-28-2019, 06:37 PM | #4 |
2919
Rep 21,727
EAS your #1 source for AST coil overs
04-08-2019, 06:45 PM | #5 |
2919
Rep 21,727
PM today for details and pricing
04-24-2019, 06:39 PM | #6 |
2919
Rep 21,727
PM today for details and options
