05-16-2018, 10:55 AM | #67 | |
Rep 1,466
You'll likely need a low profile jack, and one that will be able to pump with very little movement on the handle. I used this one: https://www.harborfreight.com/3-ton-...ump-62326.html. Even with low profile and rapid pump, you still need to get the whole body of the jack under the front bumper because the center jack point is so far back. I did this by jacking the car on one side, as normal, with a shaped hockey puck that I made, and then put 2 inches of wood under one of the front wheels. That was enough to raise the car to put the whole jack body under and raise the car up. For the jack stands, I modified a standard set of these jack stands: https://www.harborfreight.com/3-Ton-...nds-69597.html. All jack stands that I'm aware of, have a cupped shaped head, which I guess would be used to support a rear axle or similar, and are almost entirely useless for most modern cars. I used a diamond grit blade in a reciprocating saw to cut the sides off the head, and then hot glued a section of a hockey puck into the cup to provide some support. This modified head now fits into the factory plastic cup jacking points. I'll go and take some photos to show what I mean... E10, and it's just for the centre exhaust hanger. Unbolt it to move the exhaust to the side.
2018 ///M2 LCI, LBB, 6MT...
05-16-2018, 12:31 PM | #68 |
Rep 1,466
So some photos:
Modified vs Standard Jack Stand Head Modified Hockey Pack Jack Pad
jessetaylor1172.00 |
05-17-2018, 02:13 AM | #70 |
Rep 2,197
any recommendations on a torquing tool for it? my torque wrench is about 40cm long lol..
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
05-18-2018, 02:04 PM | #71 | |
Rep 5,386
http://www.2addicts.com/forums/showthread.php?t=1488578 http://www.2addicts.com/forums/attac...1&d=1524357259 http://www.2addicts.com/forums/attac...1&d=1524357259
05-18-2018, 02:36 PM | #72 |
1006
Rep 1,653
Hey Everyone,
We are aware of both of these issues. We are currently gathering as much information as we can on these incidents, including everything and everyone that was involved the fabrication process. Even after we updated the cone on this product, we have had a perfect fit reported on a majority of the installs, so we still currently believe that most of individual products themselves have not been compromised. If your unit does not fit properly, please contact us immediately so we can rectify the issue and find out more information that will help us ensure each and every one of our customers achieves a perfect fit with their product. |
McGary911480.50 |
05-18-2018, 04:13 PM | #73 | ||
Rep 1,466
I ended up doing the same thing that the OP in that thread did, but I'm not happy about it either. I'm also concerned that I had every intention of re-fitting the stock DP before servicing, and I now have a bent stock bracket as a result of trying to get the Fabspeed Cat to fit. I DIY installed mine, and would be happy to change it out with one that fits correctly once Fabspeed has got to the bottom of the problem. There are some minor costs associated with doing this however, because you're supposed to replace the bolts on the bottom stiffening plate every time you take it off (per BMW torque specs), and you're also supposed to replace the exhaust brackets and gasket. Quote:
05-23-2018, 05:31 PM | #74 |
Rep 1,466
As you all know, I experienced the fitment issue with the FabSpeed Sport Cat, and I'd like to give my perspective on the way that FabSpeed have handled the issue.
My attitude is that accidents like this happen, and FabSpeed reached out to me directly (via PM) before I had a chance to reach them, which in my mind is fantastic customer service. They've looked into the problem quickly and efficiently; discovered the issue, and admitted publicly to their mistake, which is ownership of the problem as well. I've been in touch with FabSpeed via PM, and I'm confident that they will 'make it right' with every customer affected.
05-24-2018, 08:47 PM | #75 |
Rep 27
Any tips on getting this fitted easily? It is a royal ball ache to get the front vband flange on...basically it will NOT go on, and I can't get everything to line up. I think I have one of the "bad" ones as I don't have a dent in the top and the bracket doesn't line up either. I've done way more ambitious projects way easier...I hate to just blame the product but this straight up does not fit well at all.
I seem to have a different but additional issue where the forward flange on the fabspeed pipe is too thick - visibly much thicker than the stock pipe. This results in it being impossible to get the front vband back on. Last edited by diesekte; 05-24-2018 at 09:42 PM.. |
05-24-2018, 09:45 PM | #76 | |
Rep 1,466
I don't deny that it's annoying, because you're effectively doing this with one hand, and supporting the DP with the other. Don't screw the bracket on until you've got the clamps on loosely top and bottom. It's tempting to do that to take the weight, but I wouldn't do that even if it did line up perfectly. Can you post a picture of the top of the DP. If it's cast aluminium, then you might be affected. If it's not a cast piece, then you're probably have one that's new old stock.
05-24-2018, 09:59 PM | #78 |
Rep 1,466
That's cast... You may be affected, get in touch with Fabspeed Motorsport if they haven't contacted you already. They'll sort you out, but as has already been discussed, it is still possible, and safe to fit, if you don't want to wait.
05-24-2018, 10:03 PM | #79 |
Rep 27
Yeah I'm not sure....the fitment on this is atrocious. The thing that really gets me is I just ordered this as well, 2 weeks ago, after they identified and knew about the problem
05-24-2018, 10:07 PM | #80 |
Rep 1,466
I'm not sure that's fair.... Their investigation was only concluded a day or two ago.
It's probably true that they knew there was an ongoing investigation, but it wasn't clear at that point if there actually was an issue or not. Had it turned out that there wasn't an issue, you'd have been annoyed that there was a delay in shipping it. There was obviously a tough decision to be made, and they made one that with the benefit of hind legs may look like the wrong one, but given the available knowledge at the time, would have seemed logical. Last edited by Nezil; 05-24-2018 at 10:26 PM.. |
05-24-2018, 10:19 PM | #82 |
Rep 27
Nah, I've waited months for parts and been fine. What has got me more annoyed is I have now wasted a day and my arm is all rubbed raw from the plastic under the car trying to fit a part that was either poorly designed or is the wrong one for this application.
05-24-2018, 10:21 PM | #83 |
Rep 1,466
The current situation is that it's safe to install, though it will result in some bending of the bracket. If the bracket were ever to fail, it would be covered by the lifetime warranty that FabSpeed offers.
It's not appropriate for FabSpeed to talk publicly about what they are going to do to 'make it right' with their customers, because every customer has different situation / needs. I have spoken with FabSpeed about my situation, and I'm happy, and I'm sure that they will do the right thing with others. So... to summarise, you can stick with what you've got and I'm 99% sure that everything will be fine, and in the unlikely event that it's not you've got the warranty. If you prefer to sort out something else, get in touch with FabSpeed and they'll work out a solution.
05-24-2018, 11:29 PM | #84 |
Rep 27
I messaged them. It actually is not possible to fit. If I could get it on there with slight modification, it would still imo be unacceptable but at least another option. The flange is too thick and will not bolt down whatsoever. The stock pipe went back on in less than 5 mins and the vband closed with just hand pressure. This is absolutely an additional design flaw, unrelated to the fact the dent is missing (not sure how important that is tbh), and the fact the brackets don't line up. If you rotate the stock pipe you can find kind of a sweet spot, where everything lined up and the mating surfaces are flat as well. The fabspeed pipe does not have that spot. Even at best it seems like part of the mating surface doesn't sit flat, or the O2 sensors are banging into something, or the brackets are a mile apart - at no point do things seem harmonious.
I'm sure things will get sorted but I would strongly advise anyone against ordering until fabspeed is able to definitely state they have fixed the supply chain/design/whatever problem and can absolutely guarantee it won't happen again, and/or have removed all effected product. Again, I'm less peeved about waiting 2 weeks to get the part and more about wasting an entire evening/night on something that never should've passed QC in the first place. Last edited by diesekte; 05-24-2018 at 11:38 PM.. |
Who?484.50 |
05-26-2018, 02:09 PM | #85 |
Rep 684
Wow. Sorry to hear about the recent issues. I’m kind of glad I got one of the early ones with the dent. It went on great. Top clamp was still a PITA, but that’s the way it is.
When i installed mine, the dent wasn’t posted anywhere. All I could do was use the fabspeed email form to ask if it was damage. I’m always a little iffy with those email forms but fabspeed got back to me within an hour. Pretty good service. If it was REAL damage, I’d have to settle it through the vendor. That could be hit or miss, I guess. I told the fabspeed guy I bought from x ph. He said you’ll be fine with Mike.
05-27-2018, 07:52 AM | #86 |
Rep 1,644
I read the 235 thread on this as well. The mistake was trying to troubleshoot it via pics and over the internet. The process should be:
1. I think there is a problem with the part so I'll pay to have it shipped back to FS 2. FS inspects it, compares to what they have on hand and sends me report of what they find 3. If part is bad, FS sends me a new part and pays for shipping 4. If part is not bad, FS sends me back original part and I pay for shipping 5. If we can't agree on doing #3 or #4 they keep the part and refund me the cost of the part (or arrange the return through the vendor). |
05-27-2018, 08:53 AM | #87 |
Rep 960
All I want to say is be safe. Jack it up properly. I’ve dropped a car or 2 in my day. None of the times on myself. THe actual downpipe install is relatively easy. If u can get inder the car safely.
05-27-2018, 06:55 PM | #88 | |
Rep 2,197
Im waiting for fabspeed to say they have identified the problem, and it has been with customers reporting the same. So far, they said for the majority, it fits fine, which to me is not really good enough of an answer |
