BMW M2 Forum > BMW M2 Discussions > M2 DCT holding on the first gear for too long after startup
      02-18-2024, 09:50 AM   #1
spavlas77
Drives: BMW M2 (F87), X4 M40i (2020)
Hey guys, I have a question regarding the DCT - I have had my M2 for a little over the year and I have noticed some weird behaviour of the DCT which is more pronounced in winter months.
When I start my car, I have to go out of a garage and then drive up a small hill (approx. 100 metres). If i leave my DCT in drive (no paddle shifts), it changes gears only after reaching approximately 4000 RPMs or reaching the flat surface (and even then it revs high before shifting into second). I guess it is not good for cold engine to rev so high so I usually change it manually. After that first shift, it usually quickly goes into second, third, and fourth and after that it shifts completely normal.
Is this behaviour normal? And should I be using manual shifts to override that first shifting procedure?
Thanks so much!
      02-18-2024, 04:41 PM   #2
Andrew2
Scotland
180
Drives: M2 OG DCT
Mine is the same and all OK for it ...
      02-18-2024, 04:51 PM   #3
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Sounds normal to me.
      02-18-2024, 05:54 PM   #4
qnet
qnet's Avatar
Drives: 18 Jeep Wrangler, 18 M2 LBB
I waited for others to chime in because my situation wasn't identical. When cold, the DCT does hand up a little in first gear, but I'm not going uphill after backing out of my driveway.
      02-21-2024, 07:14 AM   #5
Sled2105
Drives: 17 AW M2, 16 Miata
It would be nice if the car would automatically rev limit in cold conditions but I believe it's just sensing the throttle required and load on the transmission to get up the hill and gives you more revs. Not knowing that in that moment it should go to 2nd.
      02-26-2024, 11:38 PM   #6
bmwstephen
Drives: 95' M3, 17' M2
Are you guys puting it in sport mode out of the gate?
      02-27-2024, 03:28 AM   #7
Andrew2
Scotland
180
Drives: M2 OG DCT
Originally Posted by bmwstephen View Post
Are you guys putting it in sport mode out of the gate?
No ... SPORT only selected when the temperature gauge is at OK
Also:
From cold start on level ground it hangs on to first, if changed up manually and then back to auto it remains in second (at < 10mph)
When hot and going slowly (< 10mph) up our long driveway in COMFORT auto it will drop to first and not accept a manual upshift until a slight increase in speed (~ > 10mph)
I accept this as standard practice ...
2017 M2
2000 B5 S4 Avant
1982 Mk1 Golf GTI
      03-01-2024, 07:40 PM   #8
E90convert
Drives: F87 M2 DCT, F15 X5
I've noticed this too on the first upshift when the car is cold and your driving uphill. Maybe next time I run into some colleagues who work in the DCT engineering department, Ill ask what they think.
      03-01-2024, 07:46 PM   #9
bmwstephen
so in all the automatics I own with a ZF5HP, they do stay in 1st longer for "cold start" behavior. Think it is emissions related.
      03-12-2024, 01:34 PM   #10
Jayden_F87
'20 M2 Comp.
Jayden_F87's Avatar
Drives: '20 M2 Competition DCT
Mine does the same when I'm driving out of underground parking garage at my apartment. I limit the revs by driving up really slowly. I tend to not manually shift when the DCT is cold because it puts itself into the fastest shifting mode, which doesn't help with the longevity of the transmission.
'20 BSM M2 Competition DCT
IG: @porky_m2c
      03-20-2024, 06:52 AM   #11
E90convert
If you’re in comfort mode, the transmission stays in comfort as well with manual shifting. Also, faster shifting means less clutch slip, which means longer clutch life. So ironically, faster shifting is better for the trans.
      03-28-2024, 10:50 AM   #12
asiflicious
asiflicious's Avatar
Afghanistan
691
2018 BMW M2  [10.00]
All bmw autos do this in my experience. Probably intentionally set that way from factory to warm the transmission fluid to operating temp quicker
      03-28-2024, 01:33 PM   #13
Ata_T1T
Drives: 2017 M2
Clutches are slipped a little more on startup to warm up transmission temperature.
If it bothers you, shift into 2nd manually.
      04-12-2024, 08:08 AM   #14
ElaineDinges
Drives: BMW
You are right, I agree with you. For the past few days, I have been searching for a writing service provider website, and from tons of websites, I have selected this https://stateofwriting.com/uk/dissertation-proposal website to write my dissertation for me, their work says it all: why they are at the top. They were affordable and professional, and I was impressed with their work. You can also try them.
Tags
dct
