11-19-2023, 08:01 AM | #1 |
Rep 584
Boost Leak Test
Looking to gather information about the best way(s) to perform a boost leak test on the N55.
On a car I used to have (DSM) I would have to rotate the crank to a specific degree BTDC (beyond top dead center). I assume the same has to be done with the N55? If so, what is the process? (I could try the process of elimination on this but looking to see what y'all think.) Also, what is the preferred method of blocking off the intake pre-turbo in order to pressurize the intake? I see the various testers out there, but I'll likely build my own to save cost. Thanks in advance! |
11-20-2023, 08:41 PM | #3 |
Rep 97
M2guru I've done a few boost leak tests on mine very recently since I was replacing the charge pipes and inlet and wanted to check that everything was still tight.
I used this kit: https://turboboostleaktesters.com/bm...llet-aluminum/ I highly recommend it, it comes with everything you need and the owner is super helpful if you have any questions. Now the annoying part is that you need to remove the inlet to do that, which is a pain in the ass. |
11-21-2023, 04:36 AM | #4 |
Rep 584
Thanks c0riolis. Did it come with any instructions regarding rotating the engine to a certain degree BTDC to ensure the intake valves are closed? Perhaps my olden days are too old and that's not needed for the N55. I recall having to do that plus plug up the PCV valve on the DSM.
AmuroRay I'll try to do that tonight. |
11-21-2023, 08:59 AM | #5 | |
Rep 4,168
Mods: Yes.
M2guru406.00 |
11-21-2023, 12:50 PM | #6 | |
Rep 4,168
Mods: Yes.
11-21-2023, 01:39 PM | #7 | |
Rep 4,168
Mods: Yes.
11-21-2023, 03:31 PM | #8 | |
Rep 97
Also, you need a decently-sized compressor for this, I had to upgrade my small 1 Gallon compressor as it could not pressurize the system to more than 15 PSI and even then it was constantly running which made it impossible to hear any potential hissing. |
M2guru406.00 |
11-21-2023, 04:27 PM | #9 |
Rep 584
Thanks AmuroRay!
12-06-2023, 12:15 PM | #11 |
Rep 78
Don’t forget to insert thin feeler gauges between the valve cover and head to block off each intake cylinder port that feeds the PCV system or run the risk of rupturing the diaphragms built into the valve cover and get a leak that will be misleading.
12-11-2023, 09:38 PM | #12 |
Rep 97
You don't need to do that, the boost leak test kit is designed to be used in a way that keeps your PCV system safe.
