M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > What Brake Fluid Recommended for Track?
      05-11-2018, 09:33 AM   #23
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
I use RBF600 and Hawk DTC 70 with no issues.
      05-16-2018, 02:48 PM   #24
gsrbri
gsrbri's Avatar
Drives: F87 6MT
+1 Motul RBF 600 or 660
SRF is great, too.
Although I flush regularly given the heat stress to the fluid, so I don't go the SRF route
      05-25-2018, 06:37 AM   #25
dcmac
dcmac's Avatar
442
Drives: '18 LCI M2
Originally Posted by TampaF87 View Post
You could use the F80 guide for the M3/M4. Same brakes.
As for which fluid, Motul RBF660 is great if you are only going to track. Updated performance slightly over the RBF600, but if you are regularly driving on the street, the 660 will pick up more moisture and require more frequent changes. RBF600 is a better dual-purpose fluid. I hear great things about on-track performance of the Castrol SRF, but I haven't heard much about how it is to drive on the street.
I've always used RBF600.
Did you have a link to the F80 guide you speak of, per chance?
Thanks!
      09-18-2019, 12:28 PM   #26
Insane_Dawe
Drives: 18 White ZCP M3
Everyone recommends SRF but it's Silicon based instead of Glycol based.
Does that raise any concerns?
      09-18-2019, 01:21 PM   #27
kpaso
Drives: BMW
I believe it's not actually Silicon based, that's a common misconception. Silicon based is DOT 5.1. I think.
      09-18-2019, 10:08 PM   #28
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Been using Gulf R1000 on a few cars and on M2 with great success !
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      09-19-2019, 01:49 AM   #29
bentom2
It’s a DOT3/DOT4 fluid and compatible with all DOT3 and 4 fluids. Not DOT5 (silicone).
https://msdspds.castrol.com/bpglis/F...JAE-B8VK5T.pdf
I’ve been using SRF for roughly 25 track days from June 2018 to last weekend. I’ve gotten the brakes hot enough to discolor the calipers (as many have), and to heat check the rotors. Pedal has never gone soft. I’ve done a full flush twice, and a couple bleeds in between. The fluid I’ve removed has been close enough to new in color that it has been difficult to identify the fresh fluid when flushing. First flush was at the start of the season, and second was when I rebuilt the front calipers due to slightly uneven pad wear on one side and cooked dust seals.
I’m confident there’s no need to flush more often than 1x/year. Agree with others that it’s long life and consistent performance is worth the added cost, and probably comes out cheaper in the long run vs more frequent flushes with other fluids.
      10-01-2020, 02:34 PM   #30
edycol
Drives: 2011 328i xDrive
People should be careful with SRF.
All brake fluids on the market, except SRF, are hygroscopic (yes, hygro) and they absorb moisture. Wet boiling point is indication of boiling point at 3% moisture in fluid. However, SRF is hydrophobic (yes, hydro this time) which means it repels water. That is good. But, that means that you have to flush your brake system thoroughly as it will repel moisture from old fluid and create bubble. So, if using SRF, thorough flush is a must. Now, SRF will not perform any better than ATE TYP200, RBF, TRW Racing etc. when new. What will do due to wet boiling point is allow you less to flush less often, once a year maybe. But, IMO initial flush should use 4 bottles, and they are expensive.
