M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Brake dust cleaning
      03-13-2024, 07:49 PM   #1
BluOGM2
BluOGM2's Avatar
37
2018 bmw m2  [10.00]
Brake dust cleaning
Hello everyone,
So I’m cleaning my wheels thoroughly to ceramic coat them due the brake dust it forms frequently, and to make my cleaning easier.
I have cleaned well for the most part and clayed it as well, but at the very edges there’s still a tiny bit of dust that’s stuck and is hard to clay or brush.
I have been using iron decon and brake cleaners.
What do you guys suggest?
      03-17-2024, 06:10 AM   #2
Philly_sweden
Philly_sweden's Avatar
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Originally Posted by BluOGM2 View Post
Hello everyone,
I suggest to just drive it and and forget about it because it is impossible to Keep them 100% clean
      03-18-2024, 08:52 PM   #3
BluOGM2
BluOGM2's Avatar
37
2018 bmw m2  [10.00]
That would be a good option but it always lingers in the corner of my head whenever I wash the car, but I eventually cleaned out most of the caked up brake dust.
      03-20-2024, 01:27 PM   #4
chris719
Drives: '08 M Roadster
What cleaning products have you tried? There may be something stronger I can recommend.
      03-21-2024, 12:41 PM   #5
stlb5
stlb5's Avatar
220
Drives: '19 M2C MT, '15 X5 Msport
Plastic razor blades my friend. Back when I had my 07 STI, I would use my fingernails to get all the stubborn brake dust spots and then looked for something that mimicked nails and found plastic razor blades. I use those with a wheel cleaner as lube. I've gone up to Meguiars Wheel Brightener (acid) with great results.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers)
2014 M235i MT, BSM, MPE, Dinan Springs (Sold)
chris7197334.00
      03-24-2024, 07:27 PM   #6
chris719
Meg's WB is strong but poisonous (contains HF/ABF). Make sure you use gloves and don't breathe it in if at all possible.
I would recommend clay vs a plastic razor probably but whatever works.
BluOGM237.00
      03-24-2024, 07:39 PM   #7
stlb5
stlb5's Avatar
220
Thought he said he had tried clay. As always, start with the least aggressive approach and work your way up.
BluOGM237.00
      03-24-2024, 07:49 PM   #8
BluOGM2
BluOGM2's Avatar
37
2018 bmw m2  [10.00]
Yes so I did use clay with wheel cleaner and iron decon, but took quite a while, and also fingernails.
chris7197334.00
      03-24-2024, 08:40 PM   #9
chris719
I would try a more aggressive clay. Clay can remove paint overspray so it's hard to imagine it wouldn't remove brake dust.
BluOGM237.00
      03-24-2024, 09:53 PM   #10
BluOGM2
BluOGM2's Avatar
37
2018 bmw m2  [10.00]
Will definitely do for my other wheels,
I had a set of medium one so I believe the aggressive one would be much better.
chris7197334.00
      04-05-2024, 08:08 PM   #11
mike082802
Drives: 2010 135
any recommendations for a good aggressive clay?
      04-06-2024, 07:23 AM   #12
BluOGM2
BluOGM2's Avatar
37
2018 bmw m2  [10.00]
Went with chemical guys “heavy clay bar”
But I believe any heavy clay bar should work and you don’t need clay luber, water is fine.
