M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Tire size help M2C Titan7 T-D6E
      01-13-2024, 01:27 PM   #1
BigYak
BigYak's Avatar
Drives: 2019 M2C BSM DCT
Found some M2C spec Titan7 T-D6E wheels and wondering if my tire choice would work. I have searched and see plenty of APEX specs with the 265/285 combo but wondered specifically about these wheels with my Eibach springs.
Wheels sizes are 19x9.5 +27 and 19x10.5 +44
Am I safe with the 265/285 35 or do I need to go down to 265/285 30?
Suspension is completely stock except for springs.
      01-13-2024, 06:06 PM   #2
Mjpl
Drives: 2020 BMW M2 Competition
I would recommend the 30 series option over the 35 series on a 19' wheel set up.
I'm running 265/295/30 on the same offsets with no rubbing (lowered on EMD lowering springs with camber plates in the front).
The 35 series tire may work for stock height with the 265/285 but probably not lowered.
My front tire at full lock looks like it almost hits the fender liner but it doesn't, a 35 series most definitely would at least on my setup.
      01-13-2024, 06:15 PM   #3
BigYak
BigYak's Avatar
Thanks. Camber plates necessary to run the 265 up front?
      01-16-2024, 02:06 PM   #4
Mjpl
No Camber plate needed, i'm only running -2.3 up front for the moment with lots of room. I 'm only on camber plates to get a better alignment not for fitment needs so you should be good.
Running PS4S btw.
BigYak79.50
      01-29-2024, 07:59 AM   #5
BigYak
BigYak's Avatar
Following up and confirming, no rub.
      02-08-2024, 09:50 AM   #6
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Stock rolling diameter is better matched with the 35 series tires. The front is smaller by 3% and the rear larger by 1.1%. The front is significantly different at 3%. The 35 series would have provided more comfort than the 30 series.
      02-08-2024, 01:18 PM   #7
BigYak
BigYak's Avatar
I checked the diameter for the tires I got and got an exact .5 reduction for front and rear vs the sock PSS 245/265 combo. I don't believe I can fit 35s without rubbing.
Any examples of 265/285/35 and lowered?
      02-09-2024, 09:08 PM   #8
Mjpl
This looks damn good man.
BigYak79.50
