M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 285 or 295 rear tire size selection? (M2C)
      04-17-2021, 09:33 AM   #67
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
Originally Posted by jase2addict View Post
Is there anything I can do to run the AD08R? What size would work?
Stock size tyres would work but I guess you don't want that and I really suggest running the 275/295 30 combo or at least the 265/295...
I think you could go for a different set of wheels with the right offset or just put 275/295 on first and camber out the rub
Note with the 275 AD08R on the front, tyres will rub with the front fender liners at certain steering lock angles but after 1 week of driving 99% of the rub will go away
      04-17-2021, 09:42 AM   #68
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
Originally Posted by 2020M2Competition View Post
I've been thinking about trying the A052 in those sizes on my M2C with stock suspension and stock sized wheels (763M)
I'm currently running PS4S 255/35/19 which do not rub, but I'm a bit disappointed in their performance and steering feel
According to TireRack both tires are 26.0" tall (versus 25.8" stock) and both have a section width of 10.2" (versus 9.8" stock)
The tread width of the PS4S 255/35/19 is only a little bit wider than stock @ 8.9" (versus 8.8" stock) which is why I suspect they don't rub
However, the tread width of the A052 255/35/19 is significantly wider @ 9.5" according to TireRack and 9.6" according to Yokohama
As result, I'm a little concerned that they will rub
Anyone have any experience running the A052 255/35/19?
I have seen quite a few M2C running 255/35R 19 Potenza RE-71RS front on stock wheels or 763M with no issues.
According to BS and Yoko they are both 260mm wide on a 9 inch rim and the RE-71RS is actually a teeny-weeny bigger with the outer diameter at 663mm vs 661mm with the Yoko
So my guess is you are good with the A052
      04-17-2021, 04:51 PM   #69
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
I had similar thoughts because people around here have been running the now discontinued 255/35R19 RE-71R on front M2C stock wheels supposedly without issue
Anyhow, section width is the same at 10.2" (260mm) for the A052, RE-71R(S), and even the PS4S, so I think the deciding factor will be tread width
Unfortunately, TireRack no longer lists the tread width of the 255/35R19 RE-71R because they have sold out
I have found the RE-71R tread width listed elsewhere at 9.3" but it is hard to compare tread widths from different sources as I don't believe there is an industry standard
Based on what I've been able to find, the 255/35R19 A052 MIGHT be approximately 0.2"-0.3" wider at the tread
Karmic Man1996.00
      04-17-2021, 10:31 PM   #70
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
I know where you coming from now...
Different tyre manufacturers have different standards to measure tyre tread widths so don't worry about using the tread width as an indicator of whether the tyre will fit or not...if the tyres are from the same manufacturer then yes it might mean something but if they are from different manufacturers, don't sweat on it
The shoulders of the RE-71R and Re-71RS are very broad so if you compare the build of the RE vs A052, they are not un-similar. The diameter of a 255/35 is only about 5mm more than a 245/35 so really I don't think the A052 in 255/35 will cause you any issues on the front especially since treads will wear down with usage
The A052 is probably THE Tyre to run on right now for serious track work...only motorsports tyres (A050 and slicks) are faster in the Yokohama catalogue
      04-20-2021, 04:12 PM   #71
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
I just got off the phone with Michelin Customer Care and the news isn't great.
The MP4S 285/30/19 HAS officially been released in North America as of 1 April 2021.
BUT..... they're on back order and NOT being produced for at least the next four weeks (which is as far out as their production computer shows). The next update on production will be the week of 9 May 2021.
Apparently "due to Covid", Michelin has shut down a lot of plants, and the others are "cycling through tire sizes/models" at a reduced rate.
So, these are unicorns unless you happen to live in Europe.
I've asked that someone higher up the food chain reach out to me with a definitive answer on a reasonable date of availability, but I'm not holding my breath.
R.
      04-20-2021, 06:09 PM   #72
243Racing
1448
dUe tO cOvId
people need to pull their fingers out of their asses
      04-20-2021, 08:30 PM   #73
AlpsRider
AlpsRider's Avatar
2865
Originally Posted by BeastieBombRacing View Post
dUe tO cOvId
What do you mean?
      04-20-2021, 08:42 PM   #74
243Racing
1448
Originally Posted by AlpsRider View Post
What do you mean?
Too many companies are using it as an excuse for their poor/slow customer service.
The people I do business with because they're reliable have not slowed down at all.
      04-21-2021, 11:08 AM   #75
Rapture1
Rapture1's Avatar
69
Drives: 2021 BMW M2C
2018 Audi TTRS  [8.00]
2017 Porsche C4S  [9.50]
2011 BMW 1M Coupe  [10.00]
2007 Audi RS4  [5.50]
2004 VW R32  [6.50]
2021 M2 Competition  [9.50]
R.
Thanks for this.
Rapture
      04-21-2021, 11:10 AM   #76
bngcruiser
bngcruiser's Avatar
Drives: '89 Land Cruiser, '18 M2
2018 BMW M2  [0.00]
Hmm, I was hoping to grab these in the first half of May in prep for a road trip from Denver, CO to Bend, Oregon - but I guess I will need to find an alternative.
      04-21-2021, 11:11 AM   #77
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
R.
Germany has them, not that it'll help us.
      01-31-2024, 02:26 PM   #78
FIDDIE
Drives: M2 LCI
Anyone tried to fit 265/35/18 + 295/35/18?
All specs I see are running 30!
Thanks!
