M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > lower tire pressures for wider tire setup?
      02-13-2023, 09:43 PM   #1
dead.pixel
Drives: 2021 BMW M2 Competition
From my understanding, the contact patch area of a tire can be calculated by dividing the weight of the vehicle by tire pressure.
Example: 3500lbs / 35psi = 100 sq in
(4 tires each at 25 sq in)
Does this mean to take advantage of a 255/275 or 265/285 setup you must run lower pressures than a 245/265 setup to actually increase grip?
      02-14-2023, 01:36 AM   #2
Carrera2RS
203
I'd say try and see how they perform, I run 31-32 all round using 9.5/10.5 with stock tyres 245/265. The balance will be sidewall stiffness, camber rolling at the edges and overall suspension and wheel compliance. I usually end up preferring a little less than 'recommended' and make sure I pump them up, if I feel the need to do 150 mph for hours with a heavy family of 4 on the Autobahn.
No wait, I don't go to Germany and dont have a family of four
