06-16-2023, 10:17 AM | #1 |
Rep 79
Suspension Upgrade Options Without Coil Overs?
Hi everyone,
Did a quick check and didn't see this brought up recently. I'm looking to improve the handling of the ride, but I don't want to lower the car too much. I live in NYC and the roads here are absolutely horrible. Not sure how many folks we have from the NYC area, but there are broken roads and potholes almost on every road. Due to COVID, and the recent push to discourage people from driving and taking public transportation0--The city has deprioritized reconditioning the roads. Needless to say, it's become very unpleasant to drive around these days. I would like to improve the handling of the car, but I do not have to have it lowered too much, in fear or ruining anything due to the bad roads. I was originally looking into coil overs, specifically the OEM BMW M Performance coil overs (https://www.getbmwparts.com/oem-part...it-33502413033), but now I think just replacing the spring would do the trick. I have a 2019 M2C Does anyone have any recommendations on what I could do? Thank you! |
06-16-2023, 10:46 AM | #2 |
Rep 1,590
I live in the NYC area although I rarely drive into Manhattan for obvious reasons. Other boroughs I do so I empathize. That being said I actually found coilovers to be better all around than the stock suspension, M Performance, Bilstein and KW are options that would fit the bill based on the little bit of info you provided.
06-16-2023, 02:33 PM | #4 |
Rep 484
Drives: 2018 M2 6MT
OP, just to clarify. Are you asking about:
Or, maybe you’re looking for both? |
Hank Scorpio8.00 |
06-17-2023, 09:17 AM | #5 | |
Rep 79
Ideally, I’d like to have both—improve overall handling/dynamics of the car and also ride quality on poorly maintained roads. |
06-17-2023, 09:44 AM | #6 |
Rep 3,806
You need to narrow your focus. No matter what you do, the ride is going to get stiffer as a function of the increased handling. How the car reacts to that is going to depend on how much money you want to spend. You mentioned the M Performance coilovers...those are going to be a little stiffer than stock, but be more controlled than a set of springs. But we're talking $2400 vs. $300. Springs are going to give you a mild drop and 10-20% stiffer ride depending on road conditions, and marginally better handling due to the lower center of gravity.
But all that to say, nothing is going to be better at your ride quality requirement than the OEM suspension. |
jefe2000740.50 imperfectluck426.50 |
06-17-2023, 03:05 PM | #7 | |
Rep 33
jefe2000740.50 |
06-17-2023, 06:53 PM | #8 | |
Rep 420
