M2 Technical Topics > Suspension | Brakes | Chassis > Ohlins R&T w Vorshlag Camber Plates
      06-11-2023, 02:29 PM   #1
JM_M2C
JM_M2C's Avatar
64
Drives: BMW M2 Competition
Installed a new set of Ohlins R&T and Vorshlag camber plates.
When setting the ride height of the car, I adjusted the front and rear locking ring 13mm lower from the recommended specs provided by Ohlins. I currently have no issues with rubbing.
You can use your OEM end links but the clearance between the end link and control arm is tight. You might have to raise the front end a bit.
The dampers are set to 4 click (Track). The ride quality is absolutely amazing. Body roll on the car has been cut in half and the amount of confidence I have when taking a corner has raised.
Still messing around with alignment specs but will post an update when I finalize the numbers.
People have complained about the Vorshlag camber plates making a lot of noise but I have yet to witness this issue.
Overall, amazing setup. Would highly recommend for tho spirited drivers and occasional track days.
Jaime
Appreciate 6
Rub1con76202.50
DrKevM52274.50
AmuroRay2282.50
Mr_M//123.50
      06-11-2023, 03:57 PM   #2
imperfectluck
imperfectluck's Avatar
427
Drives: 20' F87
I would think my GC camber plated are noisier than yours but mine came with the car and stock suspension so I could never tell what the normal stock hat sounds like lol.
Can attest to the Öhlins being much nicer than the stock as I always said to myself I could never own a car for long without coil overs after I experienced a set of KW V2’s on my F30. I find HAS kits to be a half assed in my opinion as if you’re going for the height adjustment why not just go for the proper compression /rebound setup from the start.
Haven’t even taken her to the track yet just spirited canyon runs and camber plates + coils certainly let’s the F87 chassis shine.
Love the Arcanine Pokémon plate reference, made me smile looking back to my childhood.
JM_M2C63.50
      06-12-2023, 07:04 AM   #3
Sequence_
Sequence_'s Avatar
17
Drives: M2 Comp 2020
What’s the possibility for the front drop links contacting the lower arm?
      06-23-2023, 01:33 AM   #4
ddnmkun
Drives: F87, G05
It’s closed to touch when the car is lifted, but when it’s on the ground with pressure there’s gap between them, no worries.
      07-09-2023, 07:57 PM   #5
JM_M2C
JM_M2C's Avatar
64
Here’s the alignment specs I went with. Factory alignment with more front camber for now.
Jaime
AmuroRay2282.50
      08-10-2023, 11:31 AM   #6
E90convert
Drives: F87 M2 DCT, F15 X5
Wow, this looks super. Love the forge Apex wheels. Aspirational setup for me!
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Sold in 2023 '12 F30 335i 8AT Sport Line
Sold in 2020 '08 E92 335xi 6MT
Sold in 2016 '08 E90 335i 6MT - FBO
