05-17-2022, 12:15 AM | #1 |
Rep 10
Help ! Rebuilding M performance Coilovers
Hey guys recently picked Picked up a set of used M Coilovers that are leaking and require a rebuild. Contacted KW USA they told me since its a
"private Label" Coilover they don't rebuild them and id have to speak with bmw who will get them rebuilt. So I called Bmw HQ they said I need to speak with a retailer and they can get it done. Called my local Bmw store's and they all have no idea so I'm kind of at a loss lol. I searched on the forums and other members have had them rebuilt in the past so am I dealing with the wrong department ? or just a lazy KW rep? any guidance would be greatly appreciated as I would like to save these and have them rebuilt cheers. ( I am also fine sending them off to someone who is not KW for a rebuild if that is an option.) |
05-17-2022, 04:42 PM | #4 |
3847
Rep 54,376
Drives: F80 M3
The issue might be KW not wiling to provide the necessary parts for the rebuild.
05-20-2022, 01:34 PM | #5 |
Captain Generale
17
Rep 80
Strange, I can confirm that KW gave me the same response when I told them I purchased a used set of MPC:
"Thank you for reaching out to KW automotive with your questions regarding our shock service. If these are M performance coilovers those will be a private label that is exclusive to BMW motorsports and you would have to contact them for service." This makes purchasing a set of MPC second-hand more risky as compared to any other coilover that can be rebuilt (Bilstein / AST / Ohlins / or just a KW branded V3 or clubsport), unless we can figure out who at BMW NA can point you in the right direction for a rebuilt. Maybe Evan@Tischer would be helpful here?
2018 LBB M2: Stock for now. Adding sound deadening and ADS delete soon!
05-20-2022, 01:46 PM | #6 | |
Rep 10
I found a guy to rebuild them in the States will update when i get them back but it was 250USD plus shipping to rebuild my front two |
05-25-2022, 05:33 PM | #7 |
3847
Rep 54,376
Drives: F80 M3
This may be somewhat interesting. We had a customer with a Tesla Model 3 Performance with a private labeled coilovers similar to the M Performance. Basically, it's a KW V3 with different springs. KW confirmed they will perform the rebuild to the spec the dampers left the factory with even though they are not KW V3.
05-16-2023, 12:33 PM | #8 |
Rep 10
Zoran at TWF racing was able to rebuild mine hope this helps anyone in the future with M coilovers cheers
///MPhatic13864.00 |
05-16-2023, 04:43 PM | #9 |
Rep 3,806
This is one of the things that gave me pause about these coilovers. KW seems to have completely disassociated themselves with them (for whatever reason) and BMW just wants you to buy a new set. That leaves rolling the dice on a local person. Annoying because I guarantee all it takes is a generic KWV3 rebuild kit.
05-16-2023, 04:52 PM | #10 | |
3847
Rep 54,376
Drives: F80 M3
Some rebuilders are able to refresh the damper fluid but likely not able to get any soft or hard parts for the dampers. Definitely something to consider when buying mid to high end coilovers. Very few companies provide good after sale support and service these days. |
///MPhatic13864.00 MarlboroM2C237.00 |
05-16-2023, 06:05 PM | #11 |
Rep 10
100% agree with you guys i got the shocks for 200$ cdn so overall after rebuild i cant complain luckily i found someone able to do it but otherwise there is better brands to go with. just hope this thread can help someone else in the future and avoid the hoops i had to go through.
05-16-2023, 06:42 PM | #12 | |
Rep 3,806
05-21-2023, 09:55 AM | #13 | |
Rep 199
06-01-2023, 03:05 AM | #14 |
Rep 130
I had the M performance coilovers and blew he fronts from a spirited mountain run. Contacted KW and they will not rebuild them. "The warranty for your M Performance suspension is with BMW, we have no access to BMW’s performance suspension line I am afraid." I also went to BMW to see if they can be warrantied, but they will only warranty the whole set if it was installed by a BMW dealer. They do not warranty parts that have not been installed by their dealers. I ened up with AST suspension.
06-01-2023, 12:02 PM | #15 | |
Rep 10
06-01-2023, 02:07 PM | #16 | |
Rep 3,604
Current: F80
Prior: F82, F32 |
06-18-2023, 11:29 AM | #19 | |
Rep 166
I had a slight issue with mine, and the BMW service center where I had them installed serviced/adjusted them for free. |
goforwand68.00 |
