M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > How to un-tune a car you bought tuned?
      08-24-2021, 05:20 PM   #1
Q_Subsub
Drives: 2018 M2 AW 6MT
If you bought a tuned car from a dealer and you are trying to un-tune it, what's the best way to go about it? Can you bring it to a dealer to flash back to stock? Or would either BM3 or MHD have a stock map that you can flash?
Thanks in advance.
      08-25-2021, 08:10 AM   #2
EDWYER
Yoda of mods
EDWYER's Avatar
1679
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
What tune is on the car?
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      08-25-2021, 08:43 AM   #3
Enabled
Drives: 328xd Wagon, M2 Competition
Dealers can only really perform updates, if there's no update, then the dealer software will not overwrite it (as it sees no reason to). In short, dealer can't always return it completely to stock.
Esys with an ENET cable can.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
F87source7367.00
      08-25-2021, 04:30 PM   #4
CalAcacian
Why are you looking to return it to stock? You will never be able to get warranty coverage for the powertrain without a fight as dealers can tell if a car has been tuned (this is my understanding), even if it has been returned to the stock software.
Are you unhappy with the current tune, or do you just want to reduce stress on the engine? Depending on what you want, the answer may vary.
      08-25-2021, 05:50 PM   #5
Q_Subsub
Thanks for the responses. I'm looking to go back to stock mainly so I can pass emissions as my car failed the readiness test.
      08-25-2021, 06:44 PM   #6
F87source
F87source's Avatar
Drives: Bmw M2
If you get a new ISTEP update from the dealer or do it yourself then it will erase any tune and bring it back to factory spec.
RideM317.00
      08-25-2021, 06:47 PM   #7
neonbrown
neonbrown's Avatar
MHD does have an option to flash back to stock. However i'm not sure whether a license is required to perform that function.
I would look into where or not you are running a catless DP as to the reason why you failed your emissions test.
cheers
      08-25-2021, 06:53 PM   #8
F87source
F87source's Avatar
Drives: Bmw M2
+1
Then you force it to write a new ISTEP.
VGSON222.00
      08-25-2021, 06:54 PM   #9
F87source
F87source's Avatar
Drives: Bmw M2
cheers
You need a license for that, and the stock ecu files which he probably doesn't have.
      08-25-2021, 09:16 PM   #10
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
If it was a BM3 tune, you may be able to reach out TO proTUNING Freaks and get them to transfer the license with the stock map, or at least let you know how to revert it.
Do you know what mods were done to the car? Depending on what was done, the car may not run right without said tune.
Motorcity BMWCCA Member
Instagram | YouTube
      08-26-2021, 07:40 PM   #11
Q_Subsub
Thanks all. Not sure what tune is on it, which is why I'm curious but not 100% confident that buying a BM3 or MHD license will help bring the car back to stock tune.
The car has Dinan big turbo, Dinan intercooler and stock cat with M Performance Exhaust, which I think will run fine with stock tune. Another option I think is to go Dinan Stage 2 Flash route, which I think is 50 state legal for emissions, but I was hoping for a more convenient option in terms of ability to switch between maps.
      10-31-2023, 02:19 PM   #12
Houranimd49
Houranimd49's Avatar
Drives: F10 535i xDrive, F25 xDrive35i
Not to revive a threat from the dead, but I am having this issue as well.
I purchased a car that has down pipes without a check engine light. Therefore presumptuously the car is tuned. The previous owner did not do this. I have no idea what tune is on the car but I would like to remove it and put it all back to stock. n63TU engine. any ideas on how to at least find out what tune it is?
      10-31-2023, 03:33 PM   #13
AmuroRay
AmuroRay's Avatar
2378
Drives: M235i
You can email MHD and BM3 and see if they have your vin.
Mods: Yes.
      11-01-2023, 10:09 AM   #14
Houranimd49
Good call. I emailed bootmod3 and they don’t have my VIN. What other common n63 tuning companies could I email?
Or maybe a better question is how I can just revert to stock map?
      11-01-2023, 10:41 AM   #15
AmuroRay
AmuroRay's Avatar
2378
Drives: M235i
MHD
Mods: Yes.
      11-01-2023, 10:59 AM   #16
Enabled
BM3 and MHD, and some other tuners can be reverted to stock easily with esys or other factory programs.
I have noticed that ECUTek causes a huge mess, because they block any type of overwrite with their custom rom. Flash to stock attempts may then cause a lot of issues.
Others:
F87source7367.00
